Question about Maytag Bravos MTW6600T Top Load Washer
Our top loading Maytag Bravo is howling - sounds like it's about to launch! We've had it slowly getting louder for about 2 months. We bought it 1 1/2 yrs ago. Very disappointed with the noise - sounds like a bearing maybe. Can't be normal HELP!
    Problem Solver:
  • 8 Answers
Just can,t believe they would put a product in the store that falls apart in a few years,I have the loud noise,yes the bearings like so many others who have written in,on many different webs,A honest repairman will say buy something new,I guess I will ,It won,t be a maytag ` = ever again,,mw,minn
Posted on May 10, 2012
  • mike wisneski May 10, 2012
    just can,t believe they would put a product in the store that falls apart in a few years,I have the loud noise,yes the bearings like so many others who have written in,on many different webs,A honest repairman will say buy something new,I guess I will ,It won,t be a maytag ` = ever again,,mw,minn
    Sergeant:
    Champion:
  • 202 Answers
Hi... You have the tub bearing going bad.. Its going to cost lots to fix it
Posted on Apr 01, 2011
  • VeryJ Jun 09, 2011
    We have the same problem with our 2 year old Maytag Bravos and the estimate to fix it was around $500. Maytag won't do anything to fix it, although 2 repairmen said that most of these washers will eventually need the outer tub assembly replaced because of an engineering defect in the design. I will NEVER buy a Maytag again and next time I'm getting a cheap washer with an agitator.
Maytag bravos top loading washer; LD error and all lights blinking. It seems to be draining now after I turned off and tried rinse only
Why is my Maytag Bravo washer Model #MTW6600TBO ...
www.shopyourway.com > Manage My Life > Questions
May 12, 2010 - LD error please check for the following: Check for kinked or clogged Drain Hose: ... Bravos® Top Load Washer w/ PowerWash® System.
Aug 08, 2015 | Maytag Washing Machines
My Maytag bravo is leaking out of the rear left side, any ideas?
I think I'd be checking the dispenser in the left rear for a crack or rub mark. Also the hoses going to and from the dispenser. They are plastic and fragile.if the top has been lifted or an extremely
off balance load ,one may be damaged.
Jan 18, 2015 | Maytag Bravos MTW6600T Top Load Washer
I have a maytag bravo and it making a humming sound and wont drain water
There isn't much I can add to Gordon's Appliance solution.
thats exactly where I'd go for the solution .
Dec 11, 2014 | Maytag Bravos MTW6600T Top Load Washer
Put car on jack stands and A howling noise comes from passenger side when spinning at 10 mph and gets louder at 20mph
Sounds like a bad hub bearing ! This is the bearing that the cv axle goes through ! If bad you will need in most cases to remove the k uckle and take to a machine shop to have a new bearing pressed in ! Some hubs are a bolt in which you can do at home !
Mar 15, 2011 | 2001 Oldsmobile Alero
I have a Maytag Bravo top load glass washer and a f51 code. Top wont open and machine has stopped
Defective hall sensor most likely, The cabrio bravos and Oasis machines are all basically the same.
MORE here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 19, 2010 | Maytag Bravos MTW6600T Top Load Washer
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
John
Jan 15, 2010 | Maytag Washing Machines
Strange sound Maytag top load washer about 4 yrs old
It sounds like your bearings went bad. Using powder soap kills the bearings. THis also depends on the model of maytag. IF you lean the washer back look to see how many belts it has. if it has one it is really a maytag made by amana. Those are known for bad bearings. So good luck with your bearing problem. You will probably have to call out a technician Its a big job.
Nov 18, 2008 | Maytag Washing Machines
Noise while spinning
The bearings are going out. Im having the same problem right now. The cost to fix is over $900. Needs a new outer tub and clutch assembly.
Jun 19, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag washer
The lock at the center of spinner fallen /return it and tight it.
Dec 18, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Bravos MTW6600T Top Load Washer Logo
680 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
