Question about Honeywell HZ-709 Oil Filled Radiator Heater
Honeywell 709. tried to move to another room. forgot to turn off before pulling out plug. wont start. plug is ok, works for lights. wont turn on. what do i do ?
    Master:
  • 403 Answers
Let sit overnight, most likely disturbed the internal t-stat.The oil has to settle again. And make sure power oi off before turning on.
Posted on Apr 01, 2011
Reset a Honeywell HZ-709 portable electric oil room heater?
I'm going to ask the first "obvious" question: are you sure the socket you're plugging into is delivering power? (Sorry to ask but it's an Occam's Razor kind of situation) Have you tried a different socket in the same room? Next, does the main power switch for the heater have different settings i.e. high, medium, low, high-high, high-low, low-low and have you tried those combinations? Next, pick up the heater (if it won't hurt your back) and give it a robust shake. Try the power again. Any luck? Keep us posted.
Mar 06, 2015 | Honeywell HZ-709 Oil Filled Radiator...
My honeywell hz 709 heater tipped over slightly and now it will not come on. How do I fix this?
Hello, Usually unplugging the unit and letting tho oil settle for about an hour will reset the unit. Hope this works for you. Please reply and let me know , so if need be I may assist you further. Thank You!
Feb 14, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Does this thing have a fan? i turned it on its getting warm but im a bit confused on how the heat is to move around!
Hello, I can understand your confusion. This type of heater is a radiator, there is no fan. How it works is by the oil heating inside the unit. You will feel it actually get so hot, that it is uncomfortable to the touch. The air right near the heater will get warm and then it starts to rise. As it rises, more air moves in to take it's place, and then this air rises and the cycle continues as long as the heater is running. This is the same principle as the steam and hot water radiators. I have used these heaters and they really do warm up a room.
Joe
Jan 21, 2011 | Honeywell HZ-709 Oil Filled Radiator...
Turned on new heater last night, according to instructions. It was on high all night and never got above 56 degrees.
We need a little more information:
When you say 'never got about 56 degrees'--
are you saying the heater never got about 56 degrees?-
or the room it was in, did not get above 56 degrees?
Can you hold your hand on the heater?-- is it hot, or is only lukewarm?
Are the indicator lights on the heater indicating that you have power, and the heater is working? (Or trying to heat the room, at least?)
What other sources of heat do you have for the room-- and how cold is it outside?
Tell us more--
Mack B
Jan 10, 2011 | Honeywell HZ-709 Oil Filled Radiator...
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual you need. Hope it helps. If you need anything else, let me know.
Dec 29, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
How do I program my Honeywell HZ-709 radiator heater
Is there a seperate control for the timer and temp? If so, turn the temp off first and then the timer.I think they need each other for safety.
Oct 30, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Radiator won't turn on..at all
Try swapping the fuse in the plug, If not that I would contact seller and or manufacturer for replacement / repair under warrenty.
Oct 26, 2017 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-709 Oil Filled Radiator Heater Logo
254 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
