Question about Gateway NV5215u Notebook
My NV52 lap top computer shut down on me the other night and now i can't get it to power on. The charger works fine but when i plug it into the computer the light for the charger turns off.
  • 62 Answers
Remove the battery and try to power on the computer using just the charger. if you can try to use a different charger. if the charger light still goes off when plugging it in your computer then it might mean that there is a short in your motherboard. you can try removing the peripherals (i.e. memory, harddrive, DVD or CD drive, wireless card, battery or modem) to check if it is one of the peripherals causing the short. if you have removed all the peripherals and the system still doesnt turn on or if the power light on the charger still turns off and you have tried the charger on a different computer then it would mean the motherboard is damaged.
Posted on Apr 01, 2011
Laptop shut down seconds after pushing power botton
first thing that you need to determine is has your battery run flat and is your charger working...you will know this simply by leaving your lap top off and plugging in your charger...if you get charging lights come on then the charger is fine and it implies something is going on with the laptop which i can get to next....if you dont have any lights come on at all then it implies either your charger is faulty/broke/or fuse in the plug is faulty or the charging port in the laptop may have a fault/loose connection....if you do have lights (hence power) then you need to know at what stage of the power up it fails at...as boot up happens in stages....first bios (black screen with the text that flashes up)...then hardware (just at the end of the bios screen) then once it detects no faults or issues it will go into software mode (the point when your operating system i.e. windows screen starts up...and knowing the stage of shut down could help determine whether you are looking at bios/hardware or software problem...sorry if any of this is patronising...not sure what level of user you are...hope this helps
Jan 29, 2012 | Computers & Internet
My computer shuts down without any warning at all. The problem has occurred 4 times this week when charger is unplugged but power icon still shows me approximately 50% battery. Sometimes computer lets me...
Check you power settings. It is possible that it is set to shut down at 50% battery power.
If it is overheating, that too will cause a shutdown. What is happening at the time of shut down? Are the vents on the laptop being blocked in any way?
Sep 04, 2011 | ASUS Computer International U35jc A1...
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
Sony VGN-SZ470N Lap top will not power up -The charger green light is on. It has been plugged in- tested the outlet- Tried a second charger just to be sure. No charging light on the computer Just...
try removing the batteries for a minute and put it back. try to power it up again.
it happened to me may times now, and i hope it will work with yours also.
try it...
Dec 29, 2010 | Computers & Internet
Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
May 20, 2010 | Lenovo 3000 G530 Notebook
My laptop was fine last night. i always use it on the charger but needed to take it off and use it. i did so and it ran out of battery so i put it on the charger but then it shut down. i just thought ill...
Remove the battery and mains adaptor. Press and hold the power button for a few seconds. Replace the battery and plug in the mains supply, press power for a few seconds and it should start up.
Aug 31, 2017 | Acer Gateway NV5814u Notebook
Compaq C500- Will not turn on no lights except for battery LED lit. It was working fine last night. The computer was left on and the battery ran down so it did not shut down correctly. When i push the...
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
   and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 22, 2009 | HP Compaq Presario C500t Notebook
Monitor will not turn on
does the pilot light go on?if there are no lights on,check plug,if your on a power bar,maybe you turned it off by accident,if it's new and none of the previous works ,run back to the store and RETURN IT
Jan 13, 2009 | Computers & Internet
Dell Inspiron 6400 charger not always working
u r very correect its the time for new 1 to be bought. u can get the new 1 from radio shack websites. and also dont try to use that faulty charger again as it can possibly blow the laptop electrical parts internally due to any over power short circuit.
Jan 04, 2009 | Dell Inspiron 6400 Notebook
Gateway NV5215u Notebook Logo
233 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
