Question about Whirlpool Dishwashers
Water gose in and drain but force from buttom jets no water for top jets
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Apr 01, 2011
The bottom of my fridge is filling up with water. I noticed its leaking from the top back of my fridge. Someone suggested its a condensation problem.
Check the drain tube that runs from the freezer to the drain pan, my guess is that its plugged with goo, connect a bulb like you use to asperate a child nose ect and see if it plugged, you can use hot water from the drain pan end and force the water up forcefully to break it loose or you may have to remove the bottom pan in the freezer and clear the drain. If its got ice built up blocking the drain then use hot water to cut the ice and clear the drain first if possible, then the water pan will catch it, but don't let it over flow.
Jun 26, 2011 | Kenmore Top Freezer Refrigerator
My washing machine can't store water. When I press the start buttom, water was coming in, and just keep draining. It didn't stop until press the pause buttom or unplug it. It worked very well before...
Hi- It sounds like the water is siphoning out the drain hose. Make sure the Drain Hose has a loop in in above the level of the highest point of water inside the washer tub. Hope this helps.
Sep 23, 2010 | Haier Washing Machines
We have a dreammaker spa, how do we drain it? the model is Fantasy
The Fantasy has a drain located in the toekick of the spa. You have to first remove the drain cap, attach a hose if you wish, spin the outer black ring counter clockwise to start the water flow, then pull the outer ring out away from the tub to increase the drain to full flow.
I understand that a screw driver is often needed to pull the outer ring out to achieve full flow. Therefore, I suggest another method. Take a garden hose and place it in front of the jet while the spa jets are on. This will force water flow thru the hose and prime the hose. Once you see water running from the other end of the hose, drop the hose in front of the spa jet into the footwell and as long as the loose end is lower than the end in the footwell, a siphon will drain the spa as fast as the spa drain will. Remember to turn off electric to the spa once you have established a siphon. You may have to bucket the last bit of water in the footwell. Goodluck.
Oct 31, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
No Spark to a 1994-1995 Polaris SL Jet ski
first have you done what is necessary for that such as draining the oil (unless it's a two stroke) draining the gas and refiling it with fresh gas and a couple bottles of gas line antifreeze (it sucks up water) ... for the electrical parts ... spray them with wd40... that will force out any moisture at all and oil does not conduct electricity.
Mar 16, 2009 | Interactive Toy Concepts Polaris Sportsman...
Washer will not drain water out of drum
Your drain pump is bad. If you give me the Model # of your Machine, I can help you find the part.
Feb 27, 2009 | Washing Machines
Water left standing inside the buttom of dishwasher
It depends on What kind of Dishwasher you have. If the pump is old it may very well be bad or it could be a drain hose routing issue. The drain hoseshould always be looped up in the cabinet under the sink. If the drain hose is laid down low, the water could be backing up from the hose back into the dishwasher.
Feb 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Washing machine
Sounds like you have some sort of obstruction in the drum, and this is stopping it draining, thereby when it goes into spin the water is being forced out of the dispenser by centrifugal force.
Try turning the drum by hand, and if you feel a lot of resistance, then you have got something stuck in the drum.
Please rate this comment.
thanks.
Dec 10, 2008 | Tricity Bendix AW1000W Front Load Washer
Water leaking around machine
ck belt or replaced belt is designed to slip to a point if belt grabs too quickly the tub rpm come up to fast not giving tub time to drain down far enough to prvent climbing over the side also be sure drain hose is not plugged reducing water flow to drain
Jun 04, 2008 | Amana ALW880WH Top Load Washer
Kenmore heavy duty 70 series washer
The washer starts on a fill cycle. If it's not getting any water check the screens in the valve where the water line hooks to the back. If it is getting water but not filling up pull up on the drain hose. If it is to far down the drain it can **** the water right out of the unit.
Apr 23, 2008 | Kenmore 24032\24036 Top Load Washer
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
