Question about Kenmore Dryers
My dryer stopped heating up, so i called a repair man out and he found the heating element was burned out. So he left to get the part and came back and had his trainee to put it on. So when he turned the dryer on it threw the main breaker in the house. So he said he wired it backwards and changed it and now it still will not heat up. so he says now it must be the breaker or the plug. So i ask a electrician out and he says the plug is good and the breaker is good. So i call therepair man back out and he is saying there is nothing wrong with the dryer. So now what do you think
  • Kenmore Master
  • 43,501 Answers
I would be checking the element out again....either a wire burnt off or the element was shorted and that blew the element out again...
heatman101
Posted on Apr 01, 2011
  • 4 more comments
  • rel5150 Apr 01, 2011
    Well he said he did check it and the fuses in the dryer also
  • D. Floyd Kolb
    D. Floyd Kolb Apr 01, 2011
    If you have power into the dryer and not heat then either the element is not getting power or the element is bad....
    If the element is not getting power now, then the wires need to be traced back to find out where the power is getting stopped at...
    It could be that the power surge fried the timer/control board also....
    This could get interesting... especially who is going to pay for all of this...
    But at this point the only way to find the exact cause of the problem will be to be handy with the electrical meter and do some detective work....that can be very time consuming and confusing to an inexperienced person...even a good person with a meter may take a while to find the problem(s)
    So probaly the best thing is get a new or used dryer then. so i am sure of the plug, do you think it could be maybe the plug
  • D. Floyd Kolb
    I would highly doubt that something happened to the plug, but it could happen...
    The Electrician should have checked the power at the back of the dryer where the plug connects to the terminal block.....this would eliminate anything outside of the dryer...
    not sure if he did that or not. just not know where to go from here, because i know nothing about either of them
  • D. Floyd Kolb
    Before doing anything i would make sure there is power to the back of the dryer...so use getting a new one and finding out that there is a problem outside the dryer...
Dryer runs but does not heat up
The heat element may need replacing. They burn out once in a while. Check all fuses as well and if you have it apart make sure all wires are plugged together where they are suppose to be. We had a wire that pulled apart and the repair man came and five minutes later he left with me paying a bill.
Mar 07, 2015 | Maytag Epic z Front Load Electric Dryer
Indesit idc85 will not work or heat up
follow this steps and fix it. God bless you
. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gWEW0sFp
Oct 01, 2013 | Indesit Dryers
Heat starts and then dies and never goes back on but dryer keeps spinning
1. No power to the dryer
2. Heating element
3. Thermal fuse
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2gV3bBWAa
Oct 01, 2013 | Whirlpool LGR6611L Gas Dryer
Dryer spins, but no heat...please help :)
follow this steps and fix it. GOD BLESS YOU
2. Heating element
3. Thermal fuse
Read more: http://www.appliancepartspros.com/repair-help/dryer-repair-help.html#2-2#ixzz2Ybcyu6Us
Jul 09, 2013 | Samsung DV419AE Dryer
No heat in dryer model # 96591420
Check the following to address this issue.
2. Heating element
3. Thermal fuse
Jul 31, 2009 | Kenmore Dryers
Dryer won't heat, otherwise functions. we unplugged the dryer and reset the circuit breaker although it did not trip. is there anything else that we can do before we call to have it repaired?
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective. It can be tested with a Multimeter.
Jul 29, 2009 | Kenmore Dryers
Our Kenmore model 96292810 clothes dryer has stopped heating. What is the likely problem?
1. No power to the dryer(If you have power, skip to the next possible issue)
2. Heating element
3. Thermal fuse
Jul 18, 2009 | Dryers
No heat at all.
Hello Friend, Your problem is very simple to fix. You need a thermal fuse and or heater element, both very simple and affordable to replace. Try replacing the thermal fuse first to see if that's the problem. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. If this don't solve your problem you will need to replace the heater element. To replace the heater element, with the back cover off of your dryer just look down and to the right of were the air blows out. You will see the electric heating unit with two fat red wires plugged into it. Unplug these wires and you will see on the sheetmetal housing two screws that hold it on, one on each side. On older elctric dryers there is only one screw that holds element in place, it is on the bottom center of element screwed in from behind. Remove screw(s) and remove old heater element. Now, lay the new element next to the old one and take notice that there is a heat sensor attached to the old element where one of the red wires unplugged from. Gently remove this sensor and install it onto the new element in the same location as the old one. If you have an older electric dryer, the old heater element doesn't have the heat sensor on it, just skip this step. Now, plug in your two red wires and re-install your heater element. Your dryer will run like new. Happy to help, Tim.
Jun 26, 2009 | Roper REX3614KW Electric Dryer
Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
2. Heating element
3. Thermal fuse
Jun 18, 2009 | Whirlpool Dryers
Not heating
you have a dead short somewhere or someone monkeyed around the dryer to repair it
Jun 18, 2009 | Amana DLE330RAW Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
