Question about Ducane 30400040 Stainless Steel Grill
Burner igniters spark but do not ignite the burners. Do I need to replace them or is there some way to clean something. Also, the rotisserie burner will not ignite, and it has never been used.
    Brigadier General:
  • 4,736 Answers
All the ignitors work (spark), but none of the burners light ... is usually caused by and inadequate gas supply. Since you didn't didn't mention what the grill is fueled by (Natural Gas or Propane Gas), I going to assume it's Propane. So, turn the propane tank valve to OFF and disconnect the hose from the tank, Wait 5 minutes and reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (slow motion, slow) , until it's fully open. Try lighting the burner farthest from the tank first. If it lights properly, turn the burner knob to the highest setting and continue to light the remaining main surface burner(s) the same way. If all lightt and the flame height is as it should be, you solved the problem. If it doesn't, either your tank is empty or the grill hose/regulator assembly needs to be replaced. You can purchase one from any home center or hardware store that sells gas grills. Take your old one with you for comparison.
If it's fueled by Natural Gas, make sure the gas line shutoff valve is turned ON all the way.
Hope this helped you to solve the problem.
Posted on Apr 01, 2011
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Can not get rotisserie burner to light
There may be several reasons the rotisserie burner will not light. First, the orifice to the burner itself may be clogged or partially clogged preventing gas flow. There may be a problem with the spark generator, the wire running from the spark generator to the electrode, or the electrode itself. The first thing to check is the gas flow. When you turn on the valve for the rotisserie burner you should hear and smell the gas if it is flowing. Light the rotisserie burner with a manual lighter, if it lights manually, then the gas if flowing.
The seconc thing to look for is a spark from the electrode when you turn or push, depending on the type of spark generator you have. If there is no spark, the it is most likely an ignition system problem. If you have a battery operated spark generator, replace the battery and try again. If the spark generator is a piezo, you have to repalce the spark generator. If you install a new battery, or replace the piezo spark generator, and there is still no spark, then you have to get to the wire and the electrode. Look for bare spots in the wire insulation that would cause a short. Check the electrode for a cracked or broken insualtor. In either case, the wire and/or the electrode will need to be replaced.
Jul 04, 2011 | Jenn-Air JLG7130A
Rotisserie burner has to be lit with a match and will not stay on by itself. I have to push control knob in, even after it is hot. Also looking to replace igniter for left burner. Thanks.
From what you are describing, it sounds like your rotisserie burner may have a bad thermocouple. You can order the parts from Viking, the igniter for the left main burner will require you to remove the front panel to replace, but is fairly straight forward after that. To replace the thermocouple, you will have to fish it down from the burner and under the grill to behind the front panel, not hard, just time consuming.
Jun 19, 2011 | Viking VGBQ410-3RT Grill
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
CalFlame 4-burner convection BBQ rear rotisserie burner does not work. Converted to natural gas. There is a spark but gas will not ignite. Held match to burner and it would light but would go out when...
Check the air shutter adjustment on the rotisserie burner. It may be starving for air. Also make sure the burner is properly positioned over the orifice. When it was converted, it may not have been put back into place correctly. Also, it's possible the orifice may have been re-drilled out at the wrong size for natural gas. If you know the rotisserie burner BTU rating, I can look up the correct orifice hole size to check if it's right. Douglas
Sep 12, 2010 | Cal Flame 5-Burner
Rotisserie burner won't light
It could be a dirty or inop spark electrode. Also could be weak batteries in the spark igniter.
Before you start you should make sure that the ignition system has fresh batteries. The batteries are usually located within the igniter button but not always. Some BBQs will have a battery pack located somewhere on the BBQ and others you can remove the igniter button by turning it left to reveal the battery.
First verify that the rotisserie burner can be lit manually. Take a BBQ lighter or long stick match and then put the flame right at the base of the burner where the electrode is and then slowly turn on the burner valve. It should light within four seconds. If it does not then shut the burner off and check for any restrictions in the gas line for the burner.
If it does light with a match then the spark electrode could be dirty, out of position or simply the wire for the ignition system is loose. Press the igniter button and watch the electrode for a good bright spark at the burner. If you do not see any spark you can verify that the igniter wire has not come loose and also gently adjust the position of the electrode end a little bit closer to the burner using a pair of needle nose pliers(It should not be touching the burner). It does not need to touch the burner but have a really small gap.You can use a small wire brush to gently clean the electrode of any debris that might be causing a weak or no spark
If you are unable to remedy the non-spark issue all is not lost. You can still use the manual lighting procedure I described to light the burner. And remember to be careful when trying these procedures. I do not want you to get injured from delayed gas ignition. Be careful and have a safe holiday.
Jul 04, 2010 | Ducane 30400042 (LP)
One of the burners on my Dacor 4 burner gas cooktop no longer ignites automatically, it just continues to spark, but it will light with a match. Is this something I can fix myself, and if so, what should I...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Mar 28, 2010 | Dacor Preference SGM304 Gas Cooktop
I was given a ducane 20002301 2 burner with rotisserie and when I ignite and have on high there is not much flame. I know very little about gas grills
Could be two things, the first is a bad regulator, easy to replace and not very expensive. The other is a blockage in the burner orifices. For this you have to take the burners out and check inside the burner venturis and then see if you can unscrew the orifices on the valves and clean out any blockage.
Nov 16, 2009 | Ducane 455 inch 2 - 3 Burner with...
When i turn on a burner, it lights, but all 5 igniters continue to ignite
I have the same problem all but one burner. When using the other burners the igniters keep sparking after being lit. What do I replace?
Oct 04, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
Ducane 30400040 Stainless Steel Grill Logo
289 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
