Question about Diamondback ® 400Tm Treadmill
Diamondback 400tm treadmill code is E01 cause by static electric . Need to be resert, unplug the unit,
I have an ninja 4 in 1 cooker. it comes up with an eo1 message. what can i do?
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be reset
or Cooking pot is not inside the cooking system housing. Insert the cooking pot.
Search Results
SOLVED: When I turn it on I get E01 - Fixya
www.fixya.com/support/t305866-when_turn_get_e01 Dec 19, 2007 - When I turn it on I get E01 When I turn on power it is giving me E01. ... I had the same E01 error code. .... How to fix on a ninja crockpot e01. According to the manual it means the cooking pot is not inserted into the device.
ninja cooking system e01 error Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags Find solutions to your ninja cooking system e01 error question. ... ...fix error code eo1 and err i getting an error code eo1 and err and it not cooking For one, you ...
SOLVED: How to fix on a ninja crockpot e01 - Fixya
www.fixya.com/support/t17203774-fix_ninja_crockpot_e01 Mar 19, 2013 - how to fix on a ninja crockpot e01 - NINJA SEARious Slow Cooker question. ... According to the manual it means the cooking pot is not inside of the device. Same thing happened to ours .... you can use it. Here is a tip that will tell you how to fix the EO1 error code. ... ninja cooking system e01 e01. Feb 07 ...
Ninja cooking system e01 - Fixya
www.fixya.com/support/t23385060-ninja_cooking_system_e01 Feb 7, 2014 - ninja cooking system e01 e01 - NINJA SEARious Slow Cooker ... I have an E01 error code on my West Bend slow cooker, how do I fix it?
[PDF]3-in-1 Cooking System - The Home Depot
www.homedepot.com/catalog/.../3f/3f5a04f4-303f-482a-a702-eeb5ecab0bdb.pdf In the event of a loss of power, an error .... The Ninja® 3-in-1 Cooking System Steam Oven offers a revolutionary new way to cook your .... "E01" Appears on the.
ninja 4 in 1 cooker eo1 error - Google Search
Apr 02, 2017 | Kitchen Appliances - Others
Tip
What is the cause for static on my treadmill?
Winter is the time of year we receive calls regarding static electricity primarily on treadmills.In fact, many of the OEMs state they expect a certain amount of static, especially during this time of year.
Listed below are some of the sources which may be responsible for the static problems:
Items that gyms have control over:
  1. Worn motor brushes
  2. Worn belt/deck
  3. Lubrication maintenance
  4. Lack of humidity in air
  5. Dusty climate
  6. Bad ground
  7. Unit should not be on carpet
Suggested Solutions:
  1. If motor brushes are worn, replace
  2. If belt/deck are worn, replace
  3. Always keep belt/deck lubricated
  4. Run humidifiers in gym
  5. Keep equipment as clean and dust free as possible
  6. Check ground of machine (power outlet, power cord, drive motor)
  7. Install a rubber treadmill mat
Items that gyms have NO control over:
  1. Dehydration of user
  2. Dry skin of user
  3. Wool or synthetic materials (nylon, spandex, polyester)
  4. Run pattern of user (shuffling feet vs. smooth stride)
  5. Shoes
  1. Encourage users to drink more water to avoid dehydration (which results in dry skin)
  2. Encourage users to use lotion and drink more water (less friction with hydrated skin)
  3. Suggest users to wear clothing of natural fibers (cotton)
  4. Suggest change in run pattern
  5. Encourage wearing good fitting shoes (old shoes may be too worn causing friction) and shoes without nylon mesh
It has also been recommended users spray themselves with a product such as Static Guard or mist themselves with a mixture of water and fabric softener to avoid static buildup. Allow for sprayed areas to thoroughly dry before using treadmill.
on Mar 10, 2015 | Exercise & Fitness
Im trying to walk but my treadmill turns on but it does not start
Either loose or broken drivebelt. Most have an adjustment near the low end to tighten the deck belt. Look up the service manual online.
Jan 28, 2015 | Diamondback ® 400Tm Treadmill
From the first use my treadmill keeps bip-ing and shows error E01. It is new, i just opened it from the box. It just won't start
HI There, what style or brand of treadmill? You said this is a new unit. Can you call the manufacturer for a replacement or service?
If this is a Horizon unit, this happens everyday to their customers!
If it's a Horizon T101, unplug treadmill, remove motor cover, look at motor control board, to the right of the PCB you may see ONE small blue block, this is a small adjustment pot, or potentiometer.
If you have found this to be exact, and there is only ONE pot there, you can turn this pot gently to the right all the way til it stops and the back it off just a hair and retry the tread. This is a current adjust that has caused trouble for Horizon since about 2011. If you need additional help google jatinah electronics. Good Luck!
Jan 20, 2015 | Exercise & Fitness
Static electricity in house
shocks indicate an electrical problem and must be checked out by an electrician
if it is a board and the company has no replacements , it will have a part number on the board
Very few manufacturers make their own board but use generic makes so go to e-bay and see what you can find
static electricity is from wool or nylon socks on carpet to when you touch something that connects you back to the carpet
if that is not your environment ten it is faulty power wiring
Nov 10, 2017 | Diamondback Exercise & Fitness
E03
1)No belt speed. Lube the deck belt with silicone or wax.I2) adjust the speed sensor see the diagram attached. 3) control board faulty, see the block diagram. 14ebe32e-7422-48c5-949d-75454392ec99.gifaf471ebc-987e-406c-9a1d-5154021ee004.giff the problem persist, time to replace the old board deck.
God bless you
May 20, 2013 | Diamondback ® 400Tm Treadmill
Treadmill causing shocks
What is the cause for static on my treadmill? Winter is the time of year we receive calls regarding static electricity primarily on treadmills.In fact, many of the OEMs state they expect a certain amount of static, especially during this time of year.
  2. Worn belt/deck
  5. Dusty climate
  6. Bad ground
  2. Dry skin of user
  5. Shoes
Feb 20, 2013 | Life Fitness 9500HR Treadmill Next...
Tread shocks while using it
  2. Worn belt/deck
  5. Dusty climate
  6. Bad ground
  2. Dry skin of user
  5. Shoes
Feb 12, 2013 | Precor C964i Treadmill
Got carl lewis treadmill MOT566 IT SHOWING ERROR CODE E01 WHAT DOES THIS MEAN
1) this means a) problem with the speed sensor b) main motor problem c) main motor board faulty. see the block diagram attached.
God bless you
Jun 24, 2012 | Exercise & Fitness
Error code E01-22
The error E01-22 means polygon motor synchronization error.
The possible causes for the error is problem with ;
- engine pcb
- laser unit
- lvps
- sc pcb
You can try to reseat the connectors, else you may need to replace the board.
Nov 04, 2010 | Panasonic Office Equipment & Supplies
Diamondback ® 400Tm Treadmill Logo
200 people viewed this question
Top Diamondback Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Diamondback Exercise and Fitnes Expert? Answer questions, earn points and help others
