Question about Averatec 3200 Notebook
When I start my computer the Averatec logo displays and then it goes to a black blank screen with what would be the cursor blinking at the top left but if I hit the space bar it won't move and that's all. It wont boot up!
SOURCE: My Averatec turns on to the logo screen but keeps resarting
Hello All,
i didnt have a solution for these problems but please help me i have one problem
please provide me with the configration for card screen what i have for averatec 3200 laptop on my mail please :
Mohammad.Qassem@jo.wi-tribe .com
Thanks everybody
Mohammad Al-Qassem
Posted on Sep 27, 2008
dante777
  • 623 Answers
SOURCE: Averatec 3200 Series Laptop
Sure you can just re-install XP, but you will loose all of your documents and programs.
That's simple and if you have not installed anything - you can go that way.
If you want to keep everything on your laptop, you just need to repair the existing Windows installation.
This is how you do it:
  1. You have to boot form your Windows CD.
  2. In the setup screen press "Enter" ("setup WIndows now...").
  3. Important!!! - do NOT choose the Recovery Console by pressing "R"!
  4. Agree to the EULA by pressing F8.
  5. In the next window, which shows existing Windows installations, choose the repair option by pressing "R" and let it replace your corrupt NTLDR file.
If the automatic repair doen't work, then you have to copy the file manually to your C: drive.
  1. Boot from your Windows CD.
  2. Enter Windows Recovery Console (see above and press "R" in the first screen.
  3. At the command prompt, assuming drive D refers to your CD Drive, type in the following and hit "Enter" after each line:
    • copy D:\i386\ntldr C:\
    • copy D:\i386\ntdetect.com C:\
  4. Press "Y" (for "yes") when prompted to overwrite any existing file.
  5. Restart the computer
This way you keep whatever is on your computer and just replace the damaged file.
Posted on Feb 04, 2009
byteguy
  • 2229 Answers
SOURCE: Averatec 2300 wont install windows XP
If you get the Windows splash screen (which you indicate you do), then the system is working. Unfortunately, when Windows starts, it is trying to use the video card drivers. It appears that the drivers may be corrupt. The initial way to check this is to hit F8 as it is starting to see if you can start windows in safe mode. If you can, go into the device manager and remove the display adapter you see there. When Windows starts, it should find it and either ask you for the drivers or start with generic drivers that work until you provide the correct ones.
Posted on Feb 06, 2009
SOURCE: Averatec laptop won't turn on normally
is the clicking sound coming from the cd rom or hard drive
if either of this are bad , it will do all that
Posted on Jul 20, 2009
joecoolvette
  • 5660 Answers
SOURCE: my averatec laptop will only
1) Laptop on use a flashlight, and shine it at the LCD screen. Shine at various angles.
Do you see faint images?
2) You can also plug in a VGA monitor to the back of the laptop, (Laptop OFF, monitor off), and toggle over.
(It can be a VGA monitor that looks like a small TV {CRT}, or an LCD flat screen that has a VGA cable attached)
Plug the VGA monitor's cable into the blue VGA port on the left side, of the Avertec 3200 Notebook PC.
(Example of VGA connectors,
http://en.wikipedia.org/wiki/VGA_connector
Turn the VGA monitor on. Give it time to 'come to life'.
Turn the laptop on.
Are there graphics on the external monitor? If not press, and hold down on the Fn key, (Blue Fn next to the CTRL key), then tap the F2 key.
(The F2 key is the toggle over key for an external monitor. You can use the laptops LCD screen, or it's screen, and an external monitor)
Graphics show on the external monitor? Your graphics chip is good.
Problem is with the screen Inverter, or the Backlight.
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert the electricity from the laptop, for the LCD screen, and the Backlight.
90 percent of the time the fault is the screen Inverter.
The Display Assembly essentially is;
1) Top cover of the laptop. (Display Cover)
2) LCD screen
3) Display Bezel. (Thin plastic frame in front of the LCD screen, and surrounds the LCD screen)
4) Inverter
5) Backlight
6) LCD screen frame
With the Display Bezel removed, the screen Inverter should be at the bottom/front.
This is an example of a screen Inverter for an Averatec 3200 from a quick search,
http://www.laptopaid.com/averatec-3200-lcd-inverter-board-76-030105-02-tested-1629.html
I haven't worked on an Averatec 3200 Notebook PC before. I have worked on 100's of other laptops.
The sequence for removing the Display Bezel follows a pretty standard approach.
Looking at the Display Bezel I see four screw covers. (I'm looking at a PDF Users Guide)
One at the top Right corner, one at the top Left corner, one at the bottom Left corner, and one at the bottom Right corner.
These screw covers made of a rubber-like material. (Synthetic rubber) They are slightly rounded on the top. They have a type of rubber cement that holds them in place.
I use a computer pick to gently pry them off. If you carefully pry each screw cover off, and set them down sticky side up, (Screw side), you can usually reuse them again.
Screw covers (4) removed, use a Philips head screwdriver, and remove all 4 screws.
The Display Bezel will still be held in place. It has plastic tabs on the outside edges that snap into the Display Cover. (Top cover of laptop)
A fingertip is used on the INSIDE edge of the Display Bezel, next to the LCD screen.
(WATCH your fingernails against the LCD screen)
The fingertip raises the Middle/Inside edge of the Display Bezel, just slightly.
Now use another fingertip on the opposite side. Raise the Middle/Inside edge.
The Display bezel should start 'popping' out. (As the plastic tabs release they make a popping, or snapping sound)
To illustrate this technique further,
http://www.insidemylaptop.com/replace-damaged-lcd-screen-dell-latitude-e5400-e5500-laptop/
http://www.insidemylaptop.com/replace-lcd-screen-inverter-dell-inspiron-1525-laptop/
(One more, to show you where I believe the screen Inverter is for the Averatec 3200 Notebook PC, and what an average screen Inverter circuit board looks like,
http://www.insidemylaptop.com/remove-screen-inverter-dell-studio-1737-1735-laptops/
When the Display Bezel is loose, you slide it to one side a little to ease it around, and off, of the cover latch.
The cable connectors going to the screen Inverter are shaped differently from each other, so that when you go to reinstall them, there is no chance of mixing them up.
With the tools you have available, I would replace the screen Inverter ($7 plus shipping), and see if this repairs the problem.
If not the problem is the Backlight. Most of the time you have to buy the LCD screen, as the Backlight is an integral part of it, and should be replaced by a professional.
[ An LCD screen is composed of layers. The layers are held together in the correct alignment by the LCD screen frame.
This alignment MUST be aligned as it was from the factory.
This gives you an example of replacing a Backlight,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
Make a mistake here, and you can throw your LCD screen in the trash ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Aug 21, 2011
After the power on (green light steady) the dell logo proceeds then a blank screen comes up with a cursor to the top left of the screen. Please help The cursor comes to blink so I dont get anything...
It must be a software problem... try to restore your software most dell computers have a particion where all the software needed to start you pc is stored....
Here's a video tutorial of how you can do it
Aug 23, 2011 | Dell Dimension 8400 PC Desktop
One minute it was working fine, the next it was a black screen with the cursor blinking in the upper left corner. I tried re-booting it, but it just goes back to the black screen with blinking cursor. Any...
Are you getting the Acer logo on start up? If so you might have a software issue on the hard drive, or the hard drive itself is defective. I suggest using your recovery disc to re-install windows and drivers providing you have them.
Dec 18, 2010 | Acer Aspire One PC Notebook
When I turn my Toshiba A45-S151 laptop on, I first get the screen that shows the Toshiba logo and has the four icons under the logo. Usually the next screen is black, has a cursor in the top left corner,...
That blinking cursor is the way in which the BIOS is telling you that Windows is not loading because its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Oct 18, 2010 | Toshiba Satellite A45-S151 Notebook
Brand new Dell Vostro 430, in troublefree use for two weeks, sudden does not start up any more. After turning the Vostro on: - it shows the startup screen with the Dell-logo in the center, the intel...
Press DEL on startup and select "last best known config that worked" If that doesn't work you have probably corrupted the Win registry.Will need to take back to store, beware that if its a software fault you will have to pay and may lose all your data n the HDD!!!
Oct 16, 2010 | Computers & Internet
When turning my Lenovo on...the Lenovo logo pops up for a few seconds and the screen goes black with a blinking cursor in the top left corner. No way to exit or type anything onto the screen
That blinking cursor is the way in which the BIOS is telling you that Windows is missing - its most critical, core files have been corrupted beyond repair. The only thing you can do is to reinstall using the recovery cd or your own Windows install disk.
Oct 07, 2010 | Lenovo IdeaPad S10-1208Uw Netbook
Have presario 6000. Would not boot but received message that new keyboard needed. Purchased "universal" aftermarket keyboard. New message "Hard drive failure imminent" and still would not boot to allow...
Prepare to Diagnose the Computer
Perform the following actions to prepare the computer for troubleshooting a startup problem.
1. Remove the battery and AC adapter from the notebook.
2.Remove any optical disks (CD or DVD), and disconnect any external devices or peripherals such as USB devices, printers, docking stations etc.
3.Plug the AC adapter directly into a functioning wall socket.
4.Press the Power button to turn on the computer.
NOTE:After the battery, optical media and peripherals are removed, the Notebook PC may startup normally. If this occurs see Windows starts after the battery, optical media and peripherals are removed .
Symptoms and Resolutions
When the notebook stops responding or displays an error message, let me know what symptom that most closely resembles what is seen on the Notebook PC screen.
* Screen is blank with no cursor or text
*An error message is displayed on a black background
*An error message is displayed on a blue background
*PC stops responding on a red Compaq or blue HP logo screen
*PC Stops responding on the Windows logo screen
* The Microsoft Windows 'Advanced Options Menu' is displayed
* PC stops responding with a blinking cursor is displayed in the upper left corner of a black screen.
*Password is requested but password is forgotten or lost.
*Microsoft Windows starts, but a 'serious error' message is displayed that prompts you to send an error report to Microsoft for evaluation.
* Microsoft Windows starts , but the PC stops responding or restarts automatically
*Display is very dim during and after startup
*Microsoft Windows starts, but runs abnormally slow
Jan 28, 2010 | HP Pavilion dv9000z Notebook
After power on screen show nokia logo then blank off
Your device is experiencing software issues. You try by removing the battery for 30 seconds and then replacing it. This is soft reset. If the device still fails to load software, then you should visit your local repair shop for a replacement.
Mar 13, 2009 | Nokia 5310 Cellular Phone
Computer displays black screen with blinking cursor
Its seems its not booting correctly. Just Insert Windows CD and fix the windows. Another solution is to press (I think) F1 or F11 or F12 (depending on the model) when booting the machine. It will take you to recovery mode. Use it to restore the boot section ONLY.
Mar 06, 2009 | Sony VAIO VGN-CR220E/P Notebook
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Averatec 3200 Notebook Logo
60 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
