Question about Toshiba Satellite A105-S361 Notebook
Slowdown to very slow for loading any program. And I just added a gig of memory - now at max of 2gig RAM. Sound is also "watery". Slowness is big issue--
  • JPHH Apr 01, 2011
    Define watery sound
    Is it clicking or grinding sound?
  • Jim Lowe Apr 01, 2011
    Neither - delay in sound - breakup as if doing slow-down/catchup - voices sound like gargling - music sounds broken up. No grinding or clicking.
  • 37 Answers
Press the windows key plus the R key on the keyboard or click on Run command for XP, type %temp% and delete all files there
Do a clean boot
http://support.microsoft.com/kb/331796
Run a Hard Drive test available from different manufacturers like Seagate
http://www.seagate.com/www/en-us/support/downloads/seatools
If not run a system restore to a previous date when it was working. Start menu, all programs, accessories, system tools...
Backup and start a full format and recovery
I guess the watery sound may be caused by some driver settings or related to the slowness, try checking in control panel or uninstalling and reinstalling driver.
Posted on Apr 04, 2011
  • JPHH Apr 04, 2011
    Of course continue with each step until issue solved, otherwise is not necessary to try them all
    If everything fails I would assume hard drive issue
W3400 runs very slow, 64 bit, 2gig ram xp-pro
Your hard drive has the defective, there are bad sectors already in you drive, that's why it run slowly even though you formatted it.
Mar 27, 2012 | E-Machines W3400 PC Desktop
Gateway desktop fx 7026 memory issue, has 4 slots came with( 2 )2 gb sticks = 4 gigs it came with. when i add 2 extra gig it doesnt recognize.
the specs i read says 8 gig is the max. here is what it says for RAM
RAM
  • Installed Size 4.0 GB / 8.0 GB (max)
  • Technology DDR2 SDRAM
  • Memory Speed 667.0 MHz
  • Form Factor DIMM 240-pin
  • Features Dual channel memory architecture
  • Configuration Features 2 x 2 GB
check to make sure you have added the right type of memory. also look at your user manual. it should tell you where and how to place the added sticks. sometimes they have to be added in pairs or have to be in specific slots. also if you dont have the manual it is on the gateway site. you should type in your model and serial number and get all the info you need.
Feb 12, 2011 | Gateway FX7026 PC Desktop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have 1 gig ram added 2gig of ram to my P5VDC-MX mother board.
Your system might only be able to recognise 2gb of RAM. Tiger Direct has a RAM finder for almost every computer. Check it out to see if you have too much.
Jul 02, 2009 | ASUS P5VDC-MX Motherboard
PC2700 or PC3200 DDR memory in this mobo ?
MEMORY ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
May 14, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Runs very slow, can memory be added?
More memory can always help. How much Ram is installed currently?
Also, do you run any anti virus or anti spyware programs? Malware has been known for making machines crawl.
Ram on that laptop can be upgraded.
2GB Standard 4GB Max
DDR2 SDRAM
SO DIMM 200-pin
Mar 18, 2009 | HP Compaq Presario Laptop with AMD Turion...
DDR2's only showing half installed RAM
IF THE SYSTEM SAYS YOU HAVE 1GB RAM THAN YOU HAVE 1 GIG OF RAM, EVEN THOU SOMEONE TOLD YOU YOU HAD 2-512MG=1GB.
HERE IS HOW I SEE WHAT YOU ARE SAYING YOU HAVE 2-DDR-2 1 GIG STICKS THAT MEAN IF 1 IS INSTALLED THAN YOU HAVE 1 GB AND IF YOU COULD GET 2 STICKS WORKING TOGETHER THAN YOU WOULD HAVE 2GB RAM.
1 CHIP SET = 1GB RAM
2 CHIP SET = 2GB RAM
YOU MOTHERBOARD MAY NOT ALLOW THAT MUCH RAM, OR WHAT I MEAN THE BIOS MAKE UP THE AMOUNT OF RAM.
TO RULE OUT ANY BAD CHIP SETS OR GOOD RAM OR BAD RAM.
TAKE THE PEACE OF RAM THAT IS WORKING OUT AND REPLACE IT WITH THE OTHER PEACE AND SEE IF IT WILL RUN.
IF IT WORKS THAN LEAVE THAT ONE IN PLACE AND INSTALL THE SECOND PEACE IN THE SECOND SLOT.
IF BOTH CHIP SET ARE GOOD THAN BOTH SHOULD WORK OKAY TOGETHER.
IF THERE IS A PROBLEM, IT MAYBE SOME DUST IN THE MEMORY LOTS
OR THE SLOT MAYBE DAMAGED.
OR
THE CHIP DESIGN LAYOUT MAYBE THE OPPOSITE SIDE, THIS MAY MEANS THE CHIPS MAY FACE EACH OTHER, OR FACE OUTWARD FROM EACH OTHER.
ROD
Mar 14, 2009 | EliteGroup P4M800-M7 Motherboard
Added new ram (2gig + 2gig) acer inspire 5610 and it won't boot back up. worked great before i added memory.
Unfortunately the max supported RAM size is 2GB. you cannot exceed that. Sorry for the dissapointing news!
Remove 2GB and it should boot back up fine!
Hope this helps, please rate well!
Mar 01, 2009 | Acer Aspire 3690-2196 Notebook
Error message after installing memory ram upgrade.....
The memory appears to be the right kind.
Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
Dec 20, 2008 | Dell Inspiron E1505 Notebook
Toshiba l45-7423 laptop has two memory slots. With 512 in each, runs ok. With 2 gig in top slot, 512 in bottom slot, runs ok. with 2 gig in bottom slot, says it has memory errors. this limits me to 2.5 gig...
HI embreelynn,
just want to check, did you left the top slot open when you put the 2gig in the bottom slot, if you do, I suggest you try it with the 512 in the top slot and the 2gig in the bottom, the reason is that some mobo implements "banking" which means that you'll have to fill in the 1 mem slot before the using 2nd, 3rd and so on.
hope this helps, regards.
Jul 12, 2008 | Toshiba Computers & Internet
Toshiba Satellite A105-S361 Notebook Logo
59 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
