Question about Kenmore Dryers
110 74202200 Gas Drier will not heat.Blower works, Drum Turns, Vents all clear. Checked Gas line Gas getting to Drier. Looked at burner: It is clean, no rust, no corrosion, Wires in good shape. It appears to not turn on the Gas flow. There are 4 sensors on this assembly and appears some switch on the Gas input.I do not have any manuals. How can I determine what switch or sensor is not working?
  • Kenmore Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Mar 31, 2011
Why does our new frigidaire gas stove bggf3042kf make a high pitch whistle when the oven is heating?
Could be some blocked vents on the burner. Remove the burner and make sure all the gas vents are clean and clear.
Mar 22, 2015 | Frigidaire Kitchen Ranges
Our dryer has no heat. The drum turns and we checked the vents. All clean. Also we checked the fuse. Is there a heating device? It's 5 years old. Thanks Cathy
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 23, 2010 | Whirlpool LEB6300 Electric Dryer
Frigidaire Gas Dryer, won't heat to dry clothes, we have cleaned the vents , were full, now clear, why won't it heat up. Gas turns on drum turns.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 10, 2010 | Frigidaire AGQ6000ES Gas Dryer
Gas dry will not heat
Do this first
Remove all exhaust vent tubing and clean it out thoroughly.
Any lint build up will prevent the burner to operate
A moister sensor stops the burner when it senses lint build up
Reattach the vents now and proceed to the next steps below
If thoroughly cleaned & no build up is present start the dryer and listen for the spark ignitor to click. If it does not click the ignitor is bad. If it does click and no heat appears to come through the dryers drum within 30 seconds the moister sensor is at fault
May 17, 2010 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
Kenmore Gas Dryer Model # 97281800 - will not turn on. The dryer will not turn on, does this machine have a Fuse?
kenmore 97281800 drum turns good ,all vents are clear,only blows
very little.take the cover off blower compartment blows a lot.only warms the cloths. runs very well just does not dry. WHY does the blower not blow very much when its all together? is that the reason the heat cycles mostly off? three hours to dry a well wrung out load
KEN
Dec 23, 2009 | Kenmore Dryers
The dryer does not heart
is it gas or electric?what's the model number?if you checked the thermal fuse located on the blower wheel housing and that's ok,check the heating element with a meter,if it's gas you have to read out the ignitor,the sensor and the gas coils with a meter,if it's gas and you have parcial heat change out the gas coils,did you check the thermal fuse part 3392519 or on some dryers it's a 3390719 with a meter,if you did you have to remove one of the wires to get a true reading on anything you're reading out,also unplug the dryer before you check these things,also when you clean out the dryer you gotta take off the duct that the lint filter slides into and vac out the inside of the dryer,if the vent line is long,i use a leaf blower to clean out the line,remove the line from the dryer and the wall,stick the blower in the hole in the wall and blow the line out from the wall to the outside hood and make sure nothing is blocking the hood like a cage,some hoods come with a cage so animals can't crawl up the line,if you have this you gotta clean the cage every month,if you need more help send model number and if it's gas or electric
Dec 19, 2009 | Kenmore Dryers
Burner not full force
Could be your gas pressure is too low. Also, there is a particular type of spider that likes to get into the gas line at the gas valve and spin a little web in there. I have often seen this as the cause of low gas pressure. If neither of these is the cause, I would suspect a faulty gas valve.
Dec 15, 2008 | Heating & Cooling
Gas dryer fires up once and that's it
suspect coils on burner once burner fires and heats up area coil may fail on next firing 2 coils are present.. whirpool sends both in kit
Apr 26, 2008 | Whirlpool GGX9868J Gas Dryer
Drum turns, but no heat
Most likely a faulty thermocouple. The gas will get turned off if the themocouple does not sense the pilot light.
Oct 09, 2007 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
158 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
