Question about Bosch RotoZip RZ05-1100 RZ5 Base kit
I have a Roto Zip RZ10 F012MD1001 and it quit working. I took it apart and found one of the brushes was worn out while the other brush looked good. Is this a typical condition for this unit? I have had it for about 4 years and have been using it quite a bit. How difficult is it to replace the brushes with new ones? Also, are there drawings to show how to replace brushes? Thanks. Larry
2 Suggested Answers
SRF518
  • 232 Answers
SOURCE: On the 4th or 5th use of my rotozip rz5 it quit
go to tool parts direct online.
Posted on Oct 18, 2009
Took my mr coffee burr apart a little spring fell out now the grinder doesnt work where dose the spring go
Im first wondering why u took a good grinder apart ??? could it be that it was working only intermittently ?? if that is so , im betting the little spring is either the spring that pushes the start switch back up when u let go (otherwise it would run forever) or it might be a motor brush holder tension spring , that's most likely why its working only intermittently the brushes are worn down and need replaced , a neet hack 4 this is to use electric drill brushes ! I found they fit and can be sourced from a well stocked hardware store !!
Dec 21, 2016 | Coffee Makers & Espresso Machines
How can i replacethe carbon brushes on my angle grinder as they are totally and completely worn off
Buy the new brushes from the manufacturer. You already have the old ones out - put the new ones in the same way you took the old ones out.
Jul 27, 2014 | Makita 9005B 5" Electric Angle Grinder
My craftsman 12 amp 18"
If the brushes are really short, that could be a lot of the loss of power if they are not making good contact with the commutator. If you can not find your model number, see if you can locate an identical one or one of the same motor. You may have to try going into Sears to see if there is one on the sales floor and get the model number off that one.
Aug 24, 2011 | Electric Lawn Mower
When i pulg in an turn on my roto zip model rev01 the lights come on but saw does not, took apart an brushes looks good, what else could be wrong?
depending on how old the saw is, the trigger may be shorted out. try and get into the trigger assembly to confirm.
Dec 19, 2010 | Bosch RotoZip Spiral Saw RZ10 - 2100
Hoover F7458-900 SteamVac The brushes quit
My Hoover F7458-900 was doing the same thing, brushes not turning and since it is about 7 years old and out of warrenty I decided I had nothing to lose so I took it apart after reading all the other posts on this problem. The brushes are actually turned by a turbine motor (no belts involved) that runs off air produced by the vaccum motor of the unit. The air turns a metal spindle that then turns several nylon gears in the turbin the last of which turns the brushes. The nylon gear that engages with the metal spindle was worn down to the point that it was no longer engaging with it and thus not turning.
The only fix for this problem is to buy a new turbin motor which is not that expensive about $34 plus shipping since they don't sell just the nylon gear. Hope this helps
May 23, 2010 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
I was cutting 1/4" wall tile. On the 3rd or 4th cut my rotozip RZ5 quit working. There is power at the outlet. The machine was pretty warm. Is there a fuse or thermal reset or do I need to send it in foer...
I have had similar problems in the past using my Roto-Zip on jobs. You may want to check the internal brushes in the machine have not been clogged with the dust from the ceramic tiles. The unit may have simply overheated from the stress of cutting the tile. This will also affect the brushes in the Roto-Zip. A can of compressed air may help clear any dust built up around the brushes. If they brushes are caked with to much dust, you may have to take the unit appart and manually clean the brushes. But, be careful because the brushes are spring loaded. Hope this information is helpful.
Aug 17, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
Same problem. New last fall, quit after 30 min.
The brushes for the trimmer is no longer available, so unless you can find someone who has old stock of the part, your going to have to replace this one.
Jun 15, 2009 | Remington Factory Reconditioned 17-Inch...
My ROTO ZIP RZ10 burned out after less than 3 hours (Total time, not continuous use) I'm using it with 1/4" shaft Kutzal bits for wood carving. I keep it clean, blow it out etc. Does this tool have a built...
Hi again, I think you will be happy you opted for the warranty solution, I told you they stand behind their products, Thanks for sticking with it and I'm glad we could help Fixya!
Mar 02, 2009 | Bosch RotoZip Spiral Saw RZ10 - 2100
Bosch RotoZip RZ05-1100 RZ5 Base kit Logo
69 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
