Question about Garden
My husqvarna hedge trimmer wont start after being in shed for 2 years cleaned spark plug and filter put new fuel in and still nothing how do i set the jets
  • 731 Answers
Small engine carburators are prone to clogging.
remove the carb and disassemble it placeing the body parts in a jar of clean fresh gasoline.
let them soak for a good 15 minutes them remove and dry and low out the ports with compressed air ( canned air will work) then reassemble
Posted on Apr 01, 2011
Husqvarna Problems
Have you changed the fuel tank vent.? Could possibly be a vaccum being created in the fuel tank, starving the carb of fuel.
May 21, 2013 | Husqvarna 128LD 28cc 2-Stroke Gas-Powered...
Husqvarna wont start
check for spark at plug if good then small amount of starting fluid in carb if starts then fuel prob. re post
Jun 02, 2012 | Husqvarna 122HD60 Hedge Trimmer 21.7cc,...
My 2003 Husqvarna 326HD60 hedge trimmer was starting ok, but today it failed to start. They is fuel and the plug is wet, but it appears not to have any spark. The switch is set in the off position, but how...
Put switch in 'on' position, remove the spark plug and connect it to the HT lead and earth out the side of the spark plug, pull over the engine to see if you are getting a spark. Check the timing gap between the ignition module and the flywheel. 0.25 filler guage
Oct 23, 2011 | Husqvarna 28cc Gas Line Trimmer
My 10 year old weedeater hedge trimmer ran fine last year when I put it away for the season. When I tried to start it this year it wouldn't even fire. I put fresh fuel mix in and a new spark plug and...
I would check for spark and check the fuel lines, especially if fuel is left in it. Also if fuel left in you will have to empty the lines and carburetor or pull it enough to clear. Another thing to consider is that if fuel was left in it that the carburetor may need a rebuild, replacing the diaphrams.
I hope this is helpful for you.
Aug 19, 2011 | Weedeater 19 in 25cc Gas Hedge Trimmer
My ryobi cs30 gas trimmer (3 years old) has been difficult to start this year, has been getting worse all year and now wont start. What's up?
Most likely it is the spark plug, but could be a dirty fuel system. I'd start with the spark plug then go from there. you can also use a good quality fuel injector cleaner in your gas to help keep all your small engine carbs clean. If the problem persists there is a fuel filter inside the gas tank that plugs onto the end of the fuel pick up line that could be clogged. Worst case a carb kit can be gotten for them for about $20 bucks. Hope this helps. Please vote yes, thank you.
Nov 01, 2010 | Ryobi Gas Hedge Trimmer
Craftsman hedge trimmer won't start.
Have you changed the H T lead and then check the cut of swicth for faulty wireing
Jul 19, 2010 | Craftsman 22" Gas Hedge Trimmer
Trimmer starts and runs for 15 seconds and stops. won't start for a few minutes and does the same ,
Check the air filter, replace the fuel if it is last year's, clean the spark plug or replace. Also lube the blade. Good luck...Lee
Jul 14, 2010 | Craftsman 22" Gas Hedge Trimmer
Stihl 011 av wont start
Flooded? Try a new plug, or get that one cleaned up. If it is sparking and wet, it should fire, even if it doesn't run, it should spark. Did you put the jets or the needle valves back to where they were? I think they start out at 1 1/4 turns out , then adjust the low and high. If it is fouling out with too much gas, the low speed jet is open too far.
May 07, 2010 | Oregon Scientific Complete Carburetor for...
My tanaka chain saw wont idle and when i pull the gas trigger it quits or bogs down
clean spark plug and gap, remove air filter and clean, look at the spark plug and tell us what color it is, You may need to adjust the fuel mis to get it to run right or you may need a gas filter. Post here with more information.
Aug 28, 2009 | Tanaka Hedge Trimmers: 20" Dual - Sided...
Garden Logo
231 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
