Question about Dremel Variable - Speed Multipro Rotary Tool 395
Changing dremel heads
No manual with an inherited dremel want to change heads
not having any luck please advise
    Novelist:
    Scholar:
  • 125 Answers
I have exactly the same unit a 395. The kit comes w/ a wrench to unscrew the nut holding whatever you have locked in. If you can't find the wrench then I suggest you get an adjustable wrench and lock it into the flat side of the nut. There is a place where it will lock in so that you can tighten or loosen the nut. Some of the 395's come as a kit w/ all the different attachments, accessories, heads and tools. If it came with a plastic case the wrench is usually slotted running parallel just in front of the handle. You will see it when you open the case and take a top view look at the handle. It is sometime hard to see but it's just there. Good luck.
Posted on Aug 05, 2008
Dremel User Manual
i would advise you to contact the company making them and ask if they can send you the users manuals, in my experience they will send it too you.
Nov 09, 2013 | Drills
I need help attaching the new bit to the dremel model 1100
Hi leigh abear...
I will send you to the dremel website where you can watch a video on the dremel model 1100 and it will explain how to use it and change bits,cutters,ect.
Do change your bit without going to the website push down on the large button on top to lock the tool, and then you wil loosen the bit holder bu turning it anticlockwise to loosen the grip on the tool you have in the bit holder.
Please take time to rate me
http://www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=1100
Sep 09, 2011 | Dremel Garden
Dremel Stylus only charges for 2-3 minutes then stops
This is the charger, its getting a reading from the battery that its charged when it isn't. I don't know exactly how that charger is wired but, to be suroe it is the charger, as I have had similar problems beforehand.
Jun 17, 2011 | Dremel & Stylus Lithium Ion Cordless...
I can't find instructions for dremel versatip to change the heads how do you do this
The pdf manual is here: http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00554v-1.pdf
BUT it doesn't explain how to change the bits. If I remember correctly there is a grub screw near the tip that you loosen with a small flat blade screwdriver to change the tips. If your model is different then perhaps posting a picture would make it easier to give a better description.
Apr 05, 2010 | Dremel 1550:30 Versatip Tool Kit
Change sandpaper head on dremel motor tool
if your talking about the barrel sander there is a screw on top that you loosen and the barrel will slide off put the new one on tighten screw and your good to go
Jan 09, 2010 | Hand Tools
HOW TO CHANGE DREMEL TOOL?
There is a small pin sticking out of the side of your tool. You must hold it in and then change the bit. yor must use a wrench if there is a place for one. Or your fingers if its made to use with your hand. Just make sure you get it hand tight before you use it.
hope i was helpfull to you
Aug 12, 2009 | Tools & Hardware - Others
I inherited a Dremel Pro from my son who passed away...
you should have a little wrench that came with it
and on the neck of the dremel there is a shaft stop button
push the button and manually rotate the dremel head till
it clicks then hold the button and use the wrench to loosen the bit
Mar 27, 2009 | Dremel 300 1/40A "Multi Pro" Rotary Tool...
Blade Change for Bosch 1581
the screw is a flat head but you need a long series screwdriver you have to loosen the screw first then turn the blade sideways remove then place new blade in sideways turn to straight then tighten screw again its not too hard at all best of luck glenn.......
Nov 11, 2008 | Saws
Changing blade on Dremel scroll saw
I would suggest calling Dremel direct at 1-800-437-3635 and asking for tech help. You might also try their website at Dremel.com, but I have been there and you need to know the exact model number. Let me know and I will dig deeper.
Oct 22, 2008 | Dremel 16472 Carbide Coated Scroll Saw...
How do I change bits????
there is a screw at the tip of the dremel, take it out and it is pretty basic after that
Aug 05, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
1,035 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
