Question about Hoover F7220900 SteamVac V2 Upright Vacuum
My brushes are not spinning. I took the brush assembly piece out and cleaned out all the fibers, lint, etc.. Turned back on and still doesn't spin. What is the next step and what do you think it may be?
    Problem Solver:
  • 10 Answers
I think that needs repairing
pandora beads
Posted on Apr 01, 2011
Hoover steamvac 50 stopped spinning
Hi! The brushes can stop spinning if something is obstructing them such as carpet fibers, hair, dirt or debris. Remove the brushes from the cleaner by grasping the plastic outer housing and pulling firmly away from the cleaner. Remove any debris and run it under running water to clean. On the back of the brush-block assembly there's a plastic drive pin that rotates all the brushes when turned. Turn the drive pin and ensure that all brushes are making a complete 360° degree turn. If the brushes are getting stuck or if a brush falls out then the brush-block will need to be replaced. Follow the link here to order a replacement brush-block for the Steamvac Search Results. Below is a list of models this brush will fit.
F5912-900, F5914-900F5915-100, F5915-900, F5915-905, F5917-900, F5918-900, FH50041, FH50042, FH50043, FH50044, FH50045, FH50046, FH50047, FH50048CA
Hope this helps!
Jun 20, 2014 | Hoover Vacuums
Brush won't spin when carpet cleaner is running
see this causes and fix it. God bless you
If the vacuum cleaner brush is not spinning, the brushroll bearing might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearing. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll assembly itself might be jammed. Try removing the brushroll assembly and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning, the brushroll itself might be jammed. Try removing the brushroll and cleaning all hair, string, lint, etc. from the brushroll bearings. If that doesn't solve the problem the brushroll may need to be replaced.
If the vacuum cleaner brush is not spinning the cogged belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the drive belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
If the vacuum cleaner brush is not spinning the belt might be broken, stretched out too much, or might have fallen off. Check the belt and replace as needed.
Sep 27, 2012 | Vacuums
We are trying to replace the belt on the bissell 89q9 model. We purchased belt 8 and got in onto the brush however the brush doesn't spin anymore. Even trying to turn it by hand doesn't work. One...
Remove the beater brush assy & remove the
shaft & brgs that go through it 7 clean out the
hair,fuss ect,so it will turn
You need to take your vacuum apart once a year or more
to clean things so they continue to work
May 22, 2011 | Vacuums
Brushes won't spin
First, please be sure to unplug your Steam Vac and remove both the clean water and the dirty water tank.
There should be a square stem that sticks up in the center of your brush assembly. If this stem is broken you will need to replace the complete brush assembly. If the stem is good; turn your cleaner on it's side and check in the area where the brush assembly goes (with the brush assembly removed). In the center of this area there is a square hole where the stem from the brush assembly goes. The square hole is in the bottom of the turbnie that spins your brushes. Using a large flat blade screw driver (not so large that you'll damage the hole), stick it in to the square hole and try to spin it. It should spin freely, if it is very hard to spin or won't spin at all, your turbine is bad and will need to be replaced.
Hoover part number for brush assembly:48437022
Hoover part number for turbine: 43191008
May 19, 2010 | Hoover SteamVac F5914-900 SpinScrub...
I have a similar problem as many do with this model, "clean Roomba's brushes".. We took it apart last night, cleaned out all of the dust we saw. we removed the cover, the housing for the brushes and...
The machine is trying to tell you that there is something still restricting the brushes being able to rotate. The brushes are spinning on an axile that might have some hair or carpet fibers caught in it still. Look on the outer edges of the brush assembly and see if any of these things are rapped around those ends. Cleaned that off and put a little WD-40 in there and that should get you going.
Dec 03, 2009 | iRobot Roomba 530 Robotic Vacuum
I have a hoover steam vac f5899-100 the brushes doesnt spin...everything else works but tha. we took the brushes apart to clean
if after you cleaned the brushes and still doesn't work. it will have to be the turbine assembly that the brushes fit into.
Jul 20, 2009 | Hoover F5899-910 SteamVac Vacuum
Ratchet noise, beater will not turn, belt not broken, in carpet mode the Dyson d07 makes huge ratchet noise and the belt will not turn the beater brush.
Ok, so I had the same ratching noise and took the advice of many sites directing me to clean the brush. But like most I cleaned the brush and the noise continues and the brush does not spin. Reluctant to take it to get serviced I dug a little deeper and now it works just fine. This is what you need to do as removing any hair from just the brush part will not be enough.
Remove the entire brush bar from the bottom of the Dyson, this means pulling the bar out of the drive belt. This is not to difficult just use a little muscle as the belt will stretch. Once the bar is out grasp hold of the two plastic end caps on the brush bar which the brush bar actual spins in. These two caps are connected by a slim metal rod which runs through the brush bar. Place one hand on each side and begin to twist and pull until one of the caps comes off. Once the cap is off of the one side you can pull the other cap from the other side through the brush bar as this cap will be the one attached to the slim bar I mentioned above. If like mine you will see a ton of hair wrapped around these caps and inside the ends of the brush bar. Clean them out as best as possible.
After you clean it out, run the cap with the rod back through the brush bar, attach the other cap and twist and push together. Make sure the caps lineup which each other just like they were when you pulled it out. You'll notice how much more freely the brush bar spins between the two caps then before you cleaned it. Now, pull on the drive belt and feed the brush bar back through and attach as it was to begin with. This did the trick for me.
Apr 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brushes wont spin
Greetings from GoVacuum,
The Hoover SteamVac's are notorious for this exact problem. There are several things that can be causing this probelm.
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture, I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine. I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose (garden hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
One you have the brushes out of the machine, the first thing you should look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this female receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
I hope this helps you with your problem. If not, please feel free to email me at chris.jones@govacuum.com, and I'd be happy to walk you through the diagnosing. I also can provide you with a blown up parts schematic to your machine, please just get the model number off the back of the machine and provide, and provide me with the full model number. I do carry all parts for your machine, and would be happy to provide any technical support you need.
I tried uploading the pictures to this solution, however Fixya will not allow the pictures because they are too big. Please email me, and I'll send you the pictures.
Chris Jones
GoVacuum.com
Oct 03, 2008 | Hoover SteamVac F5914-900 SpinScrub...
NO SUCTION
took mine to repair shop for this problem. Dog and people hair caught up in housing you can't reach.
Oct 28, 2007 | Hoover U8143-900 Upright Vacuum
No spinning.
Most common problem when the brushes stop spinning on this model or any "SpinScub" model is that screen filter is clogged as suggested above. If that isn't your problem then likely the turbine has gone bad. Some genius at Hoover designed a metal gear to drive a Nylon gear (Inside the black part that says "Assembled in Mexico". If the brushes jam hard and sudden, the metal gear just shaves the nylon right off. Solution: You will need a new turbine unit. Cost for the part is about $36, installation takes about 15 minutes (about 6 screws and two tubes).
I refurbish and repair vacuums and steam cleaners for a living and see this all the time.
Jun 23, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F7220900 SteamVac V2 Upright Vacuum Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
