Question about Refrigerators
The icemakein my refrig is not making ice. The arm is in the on position and you can get water out of the door.
    Sergeant:
    Champion:
  • 202 Answers
Hi..... sounds like your water valve stoped working...
Posted on Apr 01, 2011
  • 2 more comments
  • Kevin Stead Apr 01, 2011
    And how can you fix the water valve? I have the same issue with this. Is this something that is easily repaired?
  • Nathan Van Boven Apr 01, 2011
    You can't fix a water valve ... you have to buy a new valve
  • Kevin Stead Apr 03, 2011
    But is the new valve easy to put in on the back?
  • Nathan Van Boven Apr 03, 2011
    Yes is its....
Samsung refrig model rf26xaebp stopped making ice but i still bet water thru the door
The solonoid valve for the ice maker may be faulty or the icemaker may be froze up. Try thawing out the icemaker with a hair dryer. If thats doesn't fix the problem you may have to replace the soloniod or ice maker control. Be sure the arm above thre the ice bin is in the down position. Hope this helps.
Dec 30, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
I don know how to turn on the ice maker of a french four door refrigerator
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Aug 07, 2013 | Whirlpool Whirpool 26 cu. ft. French Door...
Service manual LG french door refrig. LFX25950
at the front of the Ice Maker (IM) under the bottom the is a square button. push it. the IM should cycle. if it does not replace the IM
Sep 04, 2012 | Refrigerators
Ice maker not working, no water or ice dispensed.
Cause found to be faulty ice/water control board which is located at the back left hand side of the condensor behind the water solinoid valves.This is the single most expensive part of the ice maker!
Oct 13, 2009 | Westinghouse Refrigerators
How do I turn on water to ice maker or do I just turn on the ice maker
make sure the supply water is turned on under your sink or behind the refrig. also it helps to turn on you i/m by lowering the arm or turning the switch to the on position.
Jul 14, 2009 | GE Profile PCF25PGW Side by Side...
MY ICE MAKER FEELER ARM IS STUCK IN THE UP POSITION. CAN YOU PLEASE TELL ME HOW I CAN FIX THIS? MODEL LFX25950SB LG REFRIG
Water is getting into the area where the arm pivots and freezing. This prevents the arm from dropping down when it should. I use a hair dryer to melt the ice in the area of where the arms comes out of the base. As soon as the arm drops, the ice maker will make more ice. This LG in the door icemaker is junk.
Jul 14, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Ice maker won't work
Check your wiring to the timer motor. UNPLUG IT
Take off the cover look for any loose wiring. If all the wiring is in place you may have a bad timer motor.
Jun 28, 2009 | Samsung RS2630WW Side by Side Refrigerator
No ice
if you have just connected the water it could take up to 2 hrs to fill with water and then 2-4 hours befroe it drops ice also if this a brand new refrig that has just been plugged in it could take as long as 6-12 hours to get everything going. remember to throw out the first 2 or 3 harvests of ice. btw make sure the wire arm on the side of the icemaker is in the down position. thanks Peyton
Mar 06, 2009 | Maytag MFF2557HES Stainless Steel French...
Kenmore Frig 59658692890
ok there's a handle in the ice maker 1 position turns it on another turns it off just do that and the ice should stop coming down if it dosent just remove the water connection to it
Apr 07, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
