Question about Brother XL-2600
My bobbin thread won't pull up. I tried what was listed to do, but it didn't work. Please help me~!!
  • 415 Answers
Here are some things to check:
1. check the threading and tension of the top thread. It may look like it's threaded correctly but not be. When you pull on the thread is there some tension but still pulls out? Make sure it isn't catching somewhere on the path. Also make sure it's not too loose. If it's too loose it won't be able to pull the bobbin thread up enough.
2. check the bobbin threading and tension. Does it have some give but not reel out a ton? Is it catching? Is the bobbin in all the way - hear a click when inserting it?
3. Do you have the right needle for the machine? Is it inserted correctly? Try sewing through ordinary cotton first. Is it stitching? If so then you may not have the correct needle size for what you are trying to sew through.
Posted on Apr 10, 2011
The bobbin turns when I manuall pull the thread but won’t turn whem I step on the foot pedal
that would be correct
pulling the thread is what turns the bobbin
the needle thread pulls the bobbin thread up and is what makes it turn
Sep 19, 2017 | Sewing Machines
Bobbin won't move
try changing the needle
rethread the machine top & bobbin
make sure the bobbin is wound correctly & inserted correctly
into the bobbin case
if these suggestions don't help then you might think about having
the machine checked at a sewing machine shop
Aug 05, 2012 | Brother PC-420
Singer 8280 sewing machine tension won't increase
Make sure your needle and tread match your project. There simply isn't such a thing as a "universal needle." Also try lengthening your stitch. Heavier fabrics typically need a slightly longer stitch. Upon commencing to sew always grasp the 2 threads and slightly pull as you begin your seam.
I assume your garage sale find has a manual. Be sure your bobbin is unspooling in the correct direction. If it didn't come with a manual.. http://www.singerco.com/uploads/download/430_8280_es.pdf
Good luck.
Jul 04, 2012 | Singer 8280 Mechanical Sewing Machine
My 974 is not stitching and wont pick up the bobbin thread
First check that the needle isn't bent. (The simplest thing is to try a new needle.) Next check that you have a correctly wound and installed bobbin. The hole should be facing up and the bobbin thread comes off the bobbin to the left. Make sure that you threaded the bobbin correctly (notch A at the center and then to slot B to the left. (About 7 if you have the center front of the bobbin area at 6 on an analog 12-hour clock.) Pull the thread diagonally across the bobbin and then close the faceplate with the thread going through the opening of the slideplate. Hold onto the top thread while trying to bring up the bobbin thread.
If the bobbin thread still will not come up, remove the bobbin and clean the bobbin case. You may want to clean under the case as well, see page 81 of the manual. This is page 83 of the PDF: http://www.singerco.com/uploads/download/652_288-974-972-244-2405-588-875-1195-3130-3140.pdf .) Do all of the oiling of your machine while you do this maintenance if you haven't done it in a while.
The bobbin case has several parts that combine to provide good bobbin thread behavior. First there is a tension set screw that keeps the bobbin thread at the desired tension. If it is too loose or too tight the thread can't be pulled from the bobbin. (It's easy to strip the threads of the case, so be very careful.)
This is easiest to check on other types of sewing machines with a vertical bobbin case. For those, you remove the bobbin case and thread the bobbin through it correctly. Dangle the bobbin case from the thread (carefully). The bobbin case shouldn't slide on the thread but you should be able to pull out more thread if you hold the center of the bobbin and bobbin case. (Hold gently so that the bobbin turns.)
Next the bobbin race and hook need to grab the bobbin thread and twist it with the top thread. If these are damaged (perhaps by a bent needle), they won't work properly. These are at the back of the bobbin case.
Try replacing the bobbin case or parts of the bobbin case as needed. The Singer 947 is in the same line as the 244 and should use those parts. http://parts.singerco.com/CPpartCharts/2_2999/240_SERIES.pdf has the parts list. Try contacting a Singer dealer to get the parts. Unfortunately, my usual vendors only seem to list the manual as an available part for this line.
I hope this helps.
Apr 08, 2012 | Singer Sewing Machines
Machine jammed and pulled bobbin up out of it's case
since the machine jamed, I would suggest changing the needle incase it got bent or damaged
the reason for the birds nest under the fabric, the thread came off the thread take up lever, if it does it again you can try a piece of tape over it so the thread won't come off of the thread take up lever again
I use to have trouble with mine doing that.
Feb 09, 2012 | Sewing Machines
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Top thread from spool somehow gets out of the needle when sewing. Sometimes top thread breaks; other times it just escapes the needle. I redid threading from top and from bobbin to see if that would fix....
Try loosening the tension and pulling a longer string of thread. Also, if the needle is not at the highest point, when you start sewing, the thread will pull out.
May 27, 2011 | Brother LX3125 Sewing Machine
Can't bring up the bobbin thread
Sounds like hook/needle timing is off. Check it by doing the following with the power off:
remove bobbin, bobbin case, and needle plate.
push needle all the way to the left.
Turn handwheel toward you watching the needle and bobbin housing hook. The point of the hook should line up right above the eye of the needle.
If not timing, clean bobbin area removing lint and thread.
Check bobbin tension, should get slight resistance when pulling thread.
Make sure using only Husqvarna Viking bobbins.
Make sure the bobbin is unwinding in the correct direction.
Remove fabric. Pull extra long bobbin thread (about 3 inches). Hold upper thread tail in left hand, turn handwheel toward you for 1 revolution. Is the bobbin thread caught by the top thread and pulled through the opening of the needle plate?
If you are still unable to sew, take to an authorized Husqvarna Viking dealer for service or have them send to Husqvarna Viking (SVP) Technical Service Dept for repair. A list of dealers close to you can be found at the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Sep 27, 2008 | New Home HF-2022
Brother XL-2600 Logo
224 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
