Question about Panasonic KX-TG2343 Cordless Phone
Have replaced the battery twice in 3 months. Does not hold a charge (goes dead within a 5 minute phone call). Do I need a new ac adaptor? I love this phone!!
  • pwck Apr 01, 2011
    I don't have a comparable adaptor to try ... really liked this phone. Have looked a new & don't need all the extra technology attached ... I still talk to people!
  • pwck Apr 01, 2011
    Yes ~ solution was very helpful; however, it was the answer I was anticipating, but really didn't want to hear ....
  • 5,081 Answers
Have you tried charging through another AC adapter. The AC adapter going bad can be possible but It must not charge at all. I am confused how it is charged enough to work for 5 minutes.
try with an different Ac adapter. If the problem still persists then the internal charging system must have failed.
Posted on Apr 01, 2011
Why My Inspiron mini will not start?
It is unfortunate that the computer is not turning on. Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    (6)Try turning on the computer.
    If the computer doesn't turn on then check hoe the Power LEDs on the system, battery and AC Adaptor react. Then I can check and help you further.
    Thanks and Regards.
    Kiran Kumar.
    #iworkfordell.
Jun 22, 2014 | Dell Inspiron Mini 10 Notebook
Acer Aspire 5738Z won't hold charge
Sorry. It seems that your battery is dead.
If your laptop is working fine on AC power only (with the battery disconnected), then your battery will need to be replaced.
Jun 16, 2010 | Acer Aspire Notebook
When i charge my camera the green light only stays on for 5 minutes but then goes off its not charging properly and when it goes dead the lens then stays out until its charged but i cant charge it?
if you charged the battery on your camera it should have blinking green.
If your using the KLIC-7001 please clean the 3 metal contacts on your battery using a clean dry cloth, then try to charged again., make sure the charger that you are using is working fine example AC adaptor or the USB cable. now if you still encounter the problem call kodak to setup the camera for repair call toll free 1 800 235 6325., Gudluck!
Oct 31, 2009 | Kodak EasyShare M863 Digital Camera
How do you know when your batteries need replaced on Panasonic TG2344?
1. call length is diminished
2. battery takes a long time to - or never fully - charges
3. Handset will not turn on.
4. Handset gets hot during use.
5. Approximately 2 years of regular service.
Any of these indicate it is time to replace it.
Thanks for using Fixya - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 04, 2009 | Panasonic KXTG2344 Cordless Phone
Battery will not charge compaq presario v5000
I would try replacing your ac/adaptor (power plug) before troubleshooting any further. It sounds as if the adaptor is faulty. Check eBay, you can get a replacement for less than 10 dollars.
Sep 20, 2009 | Computers & Internet
HTC S710 - Battery issue
Hi guys
if u buy new battery for around 35$... its creepy thing that it again sucks within
6 month
so follow these procedure that i really got good response
1)Buy the new battery from any other dealers (u can use Nokia (std) or LG, Micromax, Onida... etc)
having same specifications as 1050mAh Lion-POLYMER 3.7v and having equivalent Size that fit into the case.
2)Now open ur dead battery, remove the sticker slowly, u wil get the polythene bag carrying the charge sheets
3)Please note that dont not disturb this polythene bag... (cutting, drilling or pinning), else it starts burning.
4)U will see a circuit above the polyhthene bag having two poles (+ve n -ve) just cut the poles of bag from the circuit and keep the bag aside
5)Now do the same procedure with new batt and remove the polythene bag.. and soilder with
the dead battery circuit. (check the +ve n -ve by multimeter)
5)Re-assemble with insulation tape and recondition it perfectly.
now check poles bofore starting.
Note : i got good result from this and i m getting 18-19hrs standby and 11-15hrs usage. Do it on ur own risk...and i m not responsable for ny harm)
Jun 02, 2009 | HTC S710 Smartphone
Wont turn on
you have one of 3 things wrong here.
1:) the battery is dead, and needs to be replaced ( suggest e-bay china seller for cheapest )
2:) the AC adaptor or dc socket on the motherboard is Faulty.
3:) motherboard fault, regarding charging circuit board.
Go for the most cost effective option First. New Battery. Then AC Adaptor. Finally would be motherboard replacement.
Mike @ compurepair.
Dec 16, 2008 | Toshiba Satellite A100-S8111TD Notebook
Motokrzr
Well it sounds like a combo of both. Definitly get the battery replaced again. The phone itself probably needs new software. take it your service provider's corp store to get the software updated.
Sep 23, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
HP Pavilion DV1000 not charging the battery
This is going to be a problem with the power management system on the motherboard, it's a common problem. You will have to replace the motherboard in order to fix this. This is a good machine and can be fixed, but if you think it's time for a new one (and can stand the pain) go for it, besides this one will be totally obsolete soon, and you'll probably be ready for a new one within the next two years anyway.
Aug 06, 2008 | HP Pavilion dv1000 Notebook
Panasonic KX-TG2343 Cordless Phone Logo
115 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
