Question about Sharp Office Equipment & Supplies
I own a Sharp EL1607S printing calculator. The print has become eligable. I have opened the unit but cannot find a ribbon to change.
SOURCE: ink problem
It has a little ink roller under the plastic on the right side as you are looking at it. It is made of black plastic and pulls straight up to come out
Posted on May 13, 2008
marsrover
  • 682 Answers
SOURCE: replace ribbon
http://www.sharpusa.com/files/cal_man_el2630P.pdf.
Posted on Mar 09, 2008
SOURCE: Replacing inking roller/ribbon?
i had a problem with this as well and found a user manual online. I thought the whole thing came out but it doesn't. If you pull up on the little red thing on right and then the black one on the right you have it. Imagine that! That's all that you change. Then just put some new ones in and your good to go.
Posted on Apr 10, 2009
  • 66 Answers
SOURCE: I cannot seem to add on my sharp el 2192 calculator just not gett
you may need an expert hand to do this:
open the case (4 screws at the back)
get the inner side of the buttons cleaned with nail polish remover/thinner.
after a while put all back.
power it on and check.
Posted on May 30, 2009
SharpCSR
  • 11 Answers
SOURCE: Where do I feed my paper into the Sharp El-1801P calculator
Hello, my name is Curtis, I am a Sharp Customer Servicer Rep. Normally the calculator would have a thin slot on the back, where you would feed the paper through, then once you press the paper in till it hits an inner wall, you would press the feed key which is on the upper left side of the calculator. If there are any problems doing this please call our technical support line at 1-800-237-4277, I am very glad to hear you like the calculator though!!!
Posted on Jun 30, 2009
Calculator does not print since new ribbon was installed
Take the paper roll and ribbon out and see if those gears move. If they do, then you have the ribbon badly placed. They are also notorious for the ribbon itself not being flat and sitting correctly.
Jun 18, 2016 | Sharp EL-1197PII Calculator
How do you change ink on a canon p20-dh calculator
For accounting offices and stores, calculators that produce a printed paper are indispensable. Canon's desktop or commercial printing calculators use ribbon tape, and you'll need to change the ribbon when it is used up. All Canon desktop and commercial printing calculators use the same method for changing the ribbon.
  • Turn off the calculator.
  • Pull up on the tab on the far side of the printer cover to remove the cover.
  • Pinch together the ribbon lock (the arrow shows you the direction to pinch). Lift the ribbon spools off the shafts and discard them.
  • Separate the new ribbon spools. Guide the ribbon tape around the four guiding pegs and set the spools on the shafts. The spools should be peg side down.
  • Rotate the spools so the peg at the bottom of the spool goes into the hole of the spool holder. Release the ribbon locks.
  • Rotate the spools to make the ribbon taut, keeping the ribbon positioned around the guide pegs.
  • Replace the printer cover and turn the calculator on.
How to Change the Ribbon in Canon Calculator eHow
Feb 06, 2016 | Canon Office Equipment & Supplies
Sharp EL-1197PIII Calculator won't print using the blank ink. Ribbon is correctly installed.
I still have to believe that your ribbon is not quite seated properly on this. I would check that again. If this is not a "cartridge" then Check to see if it is upside down.
Jan 15, 2015 | Sharp EL-1197PIII Calculator 12-Digit...
I have replaced the ribbon twice now but the print still comes out very light
I'm having the same problem. This is my second Sharp EL-2630PIII calculator and the first one did not have this problem (prior job). I can change the ribbon and the print is still so light I cannot scan it as part of my work papers... which is a huge problem as an accountant.
May 21, 2014 | Sharp EL-2630PII Calculator
Sharp Problem
I assume that this calculator using a ribbon. If that is so, remove the ribbon and check the ribbon itself. If it is damaged, you need to replace it. If it is in good condition, you may have problem with the print head.
Nov 09, 2013 | Office Equipment & Supplies
How do you change the ribbon
Hi mkline519,
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
Jan 13, 2011 | Sharp EL-2192Rll Calculator
PRINT COLOR
Hi...it appears that the ribbon is on upside down..The black has to be on the top and the red on the bottom. Just switch spools and turn the ribbon over..either that or there is a spring off the ribbon platform solenoid on the right side of the printer just below where the ribbon comes off the spool. If the spring is off or broken the ribbon platform will rise too high and print in red. Remotely the solenoid (little blue thing) could be bad or out of adjustment.
Hope this helps..this is usually all it can be.
Squipps
Nov 27, 2007 | Sharp EL-1750PIII Calculator
109 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
