Question about Kodak Office Equipment & Supplies
After removing my printer head to clean it and change the ink cartridges, my printer recognized a new printer head and said it needed calibration and says it is printing. why is it not printing but saying it is?
  • 3 Answers
Check to ensure the ink cartridge is seated correctly and the flim is removed from the new ink cartridge.
Posted on Mar 31, 2011
Put new ink cartridges in my kodak all in one ESP5020 does not recognise or print black ? Why have reinserted inks, clean print head calibrated to no avail not sure what to do next...
Sometimes one gets a cartridge that has a defective chip and cannot be recognized by the printer. Return the cartridge where you purchased it and get a new one. If the new one is not recognized, you will need to have the printer serviced or replaced.
Hope that helps,
Bax
Sep 28, 2013 | Kodak EASYSHARE 5500 All-In-One InkJet...
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
I have an ESP5 printer. The red will not print. I have carried out all of the processes normally: Changing the cartridges, cleaning, calibration etc. With no positive result What do I do now.
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or
poor ink cartridge contacts.It can also be related to fault of the head or damage to the unit.
Apr 26, 2011 | Kodak ESP 5 Printer
Printer doesnot recognise ink cartridge
  1. Remove the cartridge and reinstall it.
  2. Power cycle the printer, and then remove the cartridge and reinstall it.
  3. If the cartridge heads are blocked then soak them in window cleaning solution or warm water and then clean with a soft cotton swab.
  4. If the cartridge has been filled and still the printer does not print then the circuit of the cartridge may have failed.
  5. If the printer still doesn't recognize the ink cartridge, replace the ink cartridge with a New Retail cartridge.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 15, 2011 | Office Equipment & Supplies
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Black ink is not printing
The head is either blocked more than you can clean off, ehich happens and the only solution is a new head or printer, or the print cartridge you fitted is not recognised and is not being switched on by the printer to use. Use a Kodak print cartridge if you have used a compatible version and see if this works.
Sep 16, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Epson Workforce 600 "ink cartridge cannot be recognized" error
My printer quit printing blue after I cleaned the print heads. What can I do? I tried recharging the cyan cartridge and cleaning the print heads again. it's still not working! GRR!!
Aug 22, 2009 | Office Equipment & Supplies
53 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
