Hello, I just purchased a pair or brand new Mission MX3. They sound good, but one of them doesn't handle the bass. It gives a saturated sound, as soon as the bass kicks in, it makes a crackling sound. I tried swapping the speaker cables between the two speakers and the crackling sound was still present on the same speaker; so i am sure there is no problem with the amp. Do you think the speaker is DOA? Thank you for helping me, it stresses me out!
    Brigadier General:
  • 8,546 Answers
Yup. You've proven it. Take 'em back.
Posted on Apr 01, 2011
Testimonial: "Thanks"
I have a pair of linn komponent 104 speakers i was wondering if i can add a sub woofer to my amp to give the sound more bass as the speakers dont have a good bass sound
The Linn's should have a good bass, clean & tight but not boomy. Have you got them correctly phased? Red-to-red, Black-to-black? Bass is killed if one speaker is anti-phased.
Nov 11, 2014 | Car Audio & Video
Only bass driver working on the pair. tweeter and mid range cones not working.
hi,
check the tweeter and mid range. its coil may become faulty.
for checking the speakers carefully remove the speakers one by one, remove its connections.
and check the speakers with a AAA cell. is it producing cracking sound. if not the speakers coils are burned.
ok
Feb 01, 2011 | Mission 782 Main / Stereo Speaker
Mission m-cube sub fuse keeps blowing
If you have replaced with the correct rating and the fuse blows off then you will need to check for higher current drain in the sub woofer or the network. After replacing the fuse load up the subwoofer slowly, reduce the bass and as you increase check at the point the fuse blows off. Now we need to analyse if the rating of the amplifier you are using is rated for the subwoofer. If your subwoofer has a higher rating you can increase the rating by about 25% and check again. Some amplifiers give a very higher voltage on full bass which could result in such a condition. Moderate this and check again. If the fuse stays Ok you can continue with this new rating.Otherwise the output of the amp at higher volume needs a confirmation. Hope this helps. Good day
Jul 20, 2010 | Mission M-CUBE System
Yamaha DTXtreme IIS Drum Moduel repair
Listen to the output with headphones to check for noise.
OFTEN the output of a drum machine is CORRUPTED by an inadequate sound system. The waveforms generated by a drum machine tax the sound systems. A bass drum output can drive the speaker cone such that it goes beyond the linear range that the speaker and amplifier can handle and this appears as "noise". The noise may sound like a buzz or totally break up.
Turn the volume down and see if EXACTLY the same noise appears at low levels. If not, then saturation of the amp and speaker is likely. Continued use while it is doing that will often destroy the speaker.
Nov 28, 2009 | Yamaha Music
I have just been given a pair of aiwa speakers sx-fz1800,there is two cables comming out of the back,which one do i use.
One pair goes to bigger speaker (woofer) and other pair for smaller speakers in box, to get full frequency response, you need to hook both cables.
Sep 10, 2009 | Audio Players & Recorders
Ok, I have a pair of infinity dual voice coil 12" subs, and a pair of audiobahn quad voice coil 12" subs. Boths sets of speakers can handle 450w. Which set of 12's would be best to hook up to this amp, and...
i recomend you just use the best single woofer in a well built box and that will give you better sound at lower gain volumes it sounds like you have too much junk laying around but to get good bass run your sub at 2 ohms if the amp is stable at that impedence
Dec 16, 2008 | Phoenix Gold Xenon-200.4 Car Audio...
Home Entertainment
It depends on what you want. Is your existing solution a surround sound system (You only mention a subwoofer, what other speakers do you have?)? Do you want full 5.1 or 7.1 surround sound? If you don't have this, and want it, your amp will have to be replaced, but your sub will fit in just fine. If you currently only have front left and right speakers, you will need to purchase a centre speaker and another pair (5.1) or two pairs (7.1) of speakers.
Sep 13, 2007 | Audio Players & Recorders
Mission speakers...i think i've blown one of them...
I'm guessing you mean one of the bass drivers (as standmount or floorstanding speakers don't have subs as such). Place your hand lightly against the driver when playing some music at normal volume, there should be some vibration (this increases the louder you play). If there's no vibration, you're probably right.
Contact Mission, who can send you a new driver, contact a Mission dealer to see how much it'll cost to go through the dealer network. I'd recommend going down the latter route if you are unsure of what to do yourself.
Just noticed you posted this in March, in which case, I hope you got it fixed (or are enjoying your new pair instead!).
Mar 18, 2007 | Mission 702 Speaker
168 people viewed this question
 Grubhead
Grubhead
