Question about Scotsman Ice Machine, Cuber, 1930 lb. Unit, Head Only
Have a scotsman ice machine - model cme506ae-1a. none of the lights come on when i plug the machine in. what could the problem be. there is power going to machine
3 Suggested Answers
  • 112 Answers
SOURCE: how do i get to the sensors for full bin to clean
These units have a real problem with the bin controls. I can't begin to tell you how bad. There are two - for lack of a better term - paddles - that are basically just pushed into the left and right side of the drop area that have small lenses in them with a low level beam that when broken indicates a full bin. You have to reach in from under the bin opening and feel to the left and right, pull the paddles toward the middle and there should be enough slack on the wires to get a good hold of them and clean the lenses with a Q-tip soaked in grapefruit juice. Pop them back in and try them - if that doesn't work (and sorry but most of the time it doesn't) then they will have to be replaced.
Posted on Dec 11, 2010
  • 112 Answers
SOURCE: Bin control not responding/out of adj.Mach. #
Model C0330SA-1A sump temp sensor failure
Sump temp sensor is not reading water temperature of water running over evaporator plate.This sensor is located in the water supply tube that runs up to the top of the evaporator plate. just pull the sensor out of the tube and replace it.
Jul 10, 2014 | Scotsman C0330SA-1A 350 Lb Half Size Cube...
Scotsman cse60a 1a
the only time you will get voltage is when the machine is calling for water. turn power off What are the ohm's at blue and purple with one wire disconnected
Oct 08, 2013 | Kitchen Appliances - Others
Scotsman ice machin model cme506AS-1F BIN FULL AND UNT OFF
Pull and clean bin full sensors or replace them then power unit back up.
Jun 26, 2012 | Scotsman Cooled Modular Contour Cuber Air...
Scotsman cme456as-1a
Pull and clean water level switch. Check to see if water solenoid is getting power to it if so check to make sure you are getting water through it. FIRST check water filter make sure its not stopped up. if that is clear check make sure water line is not kinked. If your unit is not getting water then the unit will run high pressure and lock out on refrigeration.
Jun 14, 2012 | Scotsman Cooled Modular Contour Cuber Air...
How do i check for low discharge temperature or maximum length freeze cycle on a scotsman cm3 model#hd30b-1a
First check to see if the bulb of the TEV is secured and insulated well where it can sense the temps and open the valve correctly.
The tech manual
locale of discharge thermister
Page 20 tells how to check
Let me know Kimosabe what yall come up with
Apr 16, 2011 | Scotsman Ice Maker CM3 30inW Cubed Ice...
We have a code 2 on the water light, cme506as-10, the solonoid isn't kicking in, Help
check float switch if its not functioning control will not no it is out of water so it will not engage fill
Aug 31, 2010 | Scotsman CSW45 15" Ice Maker with 26 lb....
Bin control not responding/out of adj.Mach. # CME506AE=1A, can you steer me to a manual & part #. the unit is Scotsman ice mach. THX
Feb 01, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman Ice Machine, Cuber, 1930 lb. Unit, Head Only Logo
718 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
