Question about Dryers
The dryer belt is broken, where to get it or can you get it for me? Thanks!
  • Dryers Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend
http://ping.fm/zJDAM
heatman101
Posted on Mar 31, 2011
How to change a broken belt on gas dryer
Hi
Thanks for using FixYa. Please check this video on how to replace the belt in dryer. Also check the tensioner pulley and replace it if its bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 27, 2010 | Whirlpool LGR8648L Gas Dryer
I have an kenmore 80 series dryer and it stoped all of a sudden. I cleaned out the duct system, when I press the start button no sound.
If the belt has broken the belt safety switch will shut the dryer down and it will not start.
You can verify easily if you have a broken belt by manually trying to move the drum. If the drum turns and the motor does not move then either the belt is really worn or has broken which would activate the belt safety switch.
You did not mention if you checked the circuit breakers for the dryer so that is on the to do list also.
Additionally if the dryer got too hot there is a one time fail thermistor that will have to be replaced before the dryer will operate again.
Thermistors fail due to clogged airflow in following areas:
the vent ducting,
the lint filter,
air passages around the lint filter
or the outside thru the wall vent flapper assy.
Kelly
Mar 10, 2010 | Kenmore 63942 Dryer
Press the start button and drum doesnt start but the dryer makes a humming noise.
motor running but drum not turning, good chance drum drive belt is broken or has jumped off drive pully.
UNPLUG POWER CORD TO DRYER.
open dryer and look for broken belt, if belt is broken use modle number from dryer to purchas the correct belt for dryer install belt and reasmbele dryer. reconect power and test dryer.
Oct 23, 2009 | Dryers
Dryer will not turn on
most of the dryer when the belt break the dryer will no longer run open the door manually turn the barrel if it moves frely the belt is broken there is a switch connected under the belt tensioner causing the machine not to start if the belt is broken thanks from gilles
Mar 14, 2009 | Dryers
Motor runs but drum doesn't go round
siuspect broken belt
Jan 24, 2009 | Dryers
Simpson Sirocco 350 Dryer not heating
there is an oval cover on the back of the dryer. Remove this cover and you will probably find a broken fan belt. A replacement costs about $20 Aus.
NOTE: If you have been using the dryer for a while in this condition there will certainly be moisture inside the dryer. Replace the belt and leave the dryer for a few days to dry itself out (motor and electricals) before firing it up.
Oct 08, 2008 | Maytag 7.0 Cu. Ft. Electric Dryer
Maytag Dryer
hi thanks for the question the belt has stretched replace the belt thanksthe appliancedoc
Sep 15, 2008 | Maytag SDG4606A Gas Dryer
HI thanks for your question on this dryer, theres a belt break switch. it stops the dryer from coming on because the belt is broken. check the belt if you need more info get back to me
Mar 18, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
