I HAVE A MITSUBISHI TV ABOUT 3 YEARS OLD.I THINK ITS ABOUT 42 IN AND IT SITS ON A STAND MADE FOR IT TO SLIDE.I MOVE AND IT WAS SECURELY INSIDE MY TRUCK A 10 MINUTE DRIVE,PLAYED FINE ALL DAY UNTIL TONIGHT IT KEEP GOING OFF. WHAT IS WRONG I CANT FIND MY MANUEL.
  • 927 Answers
Good Day, neighborhood;
I drove to Walmart, one night, came out of the store and my car would not start. What's wrong.
First, I would try resetting the TV by unplugging it from the ac outlet for 3 - 5 minutes. and try it again.
If that did help then I would call a factory authorized service center to come ot and give an estimate.
It sounds like you may have some poor connections on some parts inside the TV.
Good Luck, big IRISH.
PS The car thing was to illustrate that it could be anything.
Posted on Aug 05, 2008
I have a Philips TV model--42PFL4030/27. 3 out of 4 hdmi ports have stopped working. I was removing a hdmi cord and it felt very warm on the end and i heard a possible popping sound. Am i just out of...
you are not out of luck..all need is a tech to look at your tv...maybe you have partially damage the output chip that is inside the tv...but if you think that doing a repair is too expensive then you must invest in a new set.good luck.
Sep 23, 2011 | Philips 42PFL3603D/27 42 in. LCD TV
My 3 year old Proscan 42" LCD TV picture suddenly
On the far left and right inside the back on panel are inverter boards. Replace or look for capacitors buldged, swollen, or cracked on their tops. Replace defective caps with original value and make sure replacements are 105 degree for longevity. Common problem, let me know if this helped.
Sam Farrell
Feb 17, 2011 | Proscan 42LA45H 42 in. LCD TV
To transport a loewe spheros 42 plasma unit with rotating stand does the tv unit detach from the stand? I understand that the plasma tv should be transported in an upright position only is this true?
Yes, it should be transported in upright position.
When we moved, our moving company arranged a crating company to crate our Spheros unit. They built a crate around the TV and secured it in an upright position along with the rotating stand. They then put a tilt sensor (you get the serial number of the tilt sensor) to make sure that the moving people don't tilt the crate. They also un-crate it at your destination. The only problem is that the TV is already quite heavy to begin with (~180 lbs), and with the crate, it becomes almost impossible for the movers move it in perfect upright position....though our movers really tried hard.
Sep 30, 2010 | Loewe Spheros 42HD 42 in. HD-Ready Plasma...
We have lost the picture on our 42 inch hp plasma tv model pl4260n, we get sound but no picture?? is this a known issue? probably 3 to 5 years old , just happened in the middle of destination truth. nobody...
If it is not a loose connection (internally), it may be most probably related to your picture tube. Check it out and if found faulty get it replaced. If your are in any warranty period (I don't think so since it is 3-5 years old), don't do anything and just inform them, or else you will loose your warranty security.
Apr 17, 2010 | HP PL4260N 42 in. Plasma HDTV
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Have to move to Germany , is the TV working there?
PDP4224M will work in Germany. I know that, because it displays any system from my Samsung SV-5000W.
Mar 09, 2009 | Akai PDP4225M 42 in. Plasma Television
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
