I have a Maxwell 8GB USB drive. When I insert it to my laptop, which is running Windows XP, it cannot see any of the 8GB present on the drive. When I try to troubleshoot it, by going into Device Manager, it states that the "Device is working properly". I have also noticed that read/write red flashing light on the USB drive itself, is no longer showing. I have tried formatting the USB device, but keep getting the dialogue box stating that no device is present in Drive E:, which is where the USB is located. I would very much appreciate your help, as I have some important files that I need to access from the USB drive. It was working perfectly, up to a few days ago. Which was when I lasted used it. Regards, Mike
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Posted on Mar 31, 2011
When i insert my USB flash drive called sanDisk cruzer 8GB in the laptop,am told that i need to format the disk in drive G before i can use it,when i try to format it, it says that windows was unable
If there is any Media Error not possible to format the drive otherwise use the following method on Windows 7
Open a Administrator command Prompt and type the command one by one
1.list disk
you can find the avilable disk and note your USB Drive Disk Number
2.select disk 1 (change the number)
3.clean
4.create partition primary
5.format fs=ntfs quick
6.assign
if no problem in usb it will format your USB Drive
Apr 03, 2014 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Usb storage size went down from 8gb to 4mb
First, download this Toshiba flash drive format tool
http://softadvice.informer.com/Toshiba_Usb_Flash_Drive_Format_Tool.html
and use to format your pen drive again with this software.
Nov 06, 2013 | Computers & Internet
USB flash drives
http://www.brighthub.com/guides/usb-flash-drive.aspx
complete guide to usb drives
at least 4gb you might be better of getting something larger say 8gb depending on your budget
hope it helps
Jun 12, 2012 | Microsoft Windows XP Professional Full...
I forgot my sandisk 8GB USB 2.0 Flash Drive 's vault password. How can i set a new password if i can not remember the old / current password? This is my first time trying to access the vault feature....
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards, "
USB Memory Drives"
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
, "USB Memory Drives"
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
Jun 07, 2011 | SanDisk 8GB Ultra Backup USB 2.0 Flash...
I have a Sandisk 8GB cruzer. When I insert it into port the U3 yellow box doesn't come up so I can't set a password. What do I do?
There is a known problem with the U3 software and Windows 7. Are you running Win 7?
Sandisk has upgraded and compatible software available here:
http://kb.sandisk.com/app/answers/detail/a_id/3682/~/u3-launchpad-update-for-windows-7
Good Luck, Mikeywaf
Feb 28, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Is the PNY 8 GB Flash Drive attache compatable with windows 98? If not then I will have to use it on my other laptop with windows 7. Is there a manual on how to use this flash drive? Thank you.
USB devices are incompartible with computer manufactured prior to the turn of the mellanium. USB devices became functional during the innovations of windows XP Vista and 7
Feb 06, 2011 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
When I plug my Maxell 8Gb 360 usb thumb drive into my computer at work, which is running XP, the OS can see the whole 8Gb, but I cannot put a 4Gb file on the stick. However when I use my windows 7 laptop...
Your PC is infected ,which is running for XP 7and you should remove the virus.
Please download f-secure bootable disk and clean at the time booting.
How will you confirm?
Follow the steep. Press win key +R >type gpedit .msc and soon an windows will open.
Press win key +R>ms config and soon an windows will open.
Press win key + R REGEDIT an windows will open soon.
Go to tools option >folder option >view>check on show hidden file
Check off hide protected operating system file
Check off hide extension known type file.
BUT still there are no hidden file in drive C:
Think your computer has affected by serious virus.
start>program>accessories>system tools >system restore >set earlier date. If you have the strong
virus you can not do that.
You will take more infomation click here
Hope it will help you.
Good by
Jan 06, 2011 | Maxell 8GB USB 360 USB 308 - 503202 Hard...
NEED DRIVER FOR PNY 8GB USB ATTACHE
If you're using the drive on a PC with Windows XP or Windows Vista, you don't need a driver - just plug it into the PC and Windows will recognize it and install USB drivers automatically.
Dec 07, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
'Please insert a disk in to the removable disk drive k"
Same thing happens to me .My 8gb silicon usb flash drive got the same error, please insert a disk into drive, the name of my drive weas changed into Removable Disk instead of the name(Sanctuary which is what i used) It said ni media ,and it was registered as XXXXXXXX U167CONTROL USB DEVICE can anyone help me with this.
Nov 25, 2009 | Electronics - Others
8gb USB scandisk glitch / freezing issue
Hi ,
Try to set up the U3 device not to run at insert , you can do that by left click on the U3 icon and then choose the right item from the menu.
it may help you at start up phase.
Mar 26, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
