Question about Microwave Ovens
My tappan microwave Model number TMS137T1B2 is plugged into a live outlet yer appears completely dead. Is there an internal fuse or circuit breaker inside th case of the oven?
SOURCE: GE Spacemaker microwave JVM140G just stopped
NO internal fuse. It is most likely, the magnetron, and or High power diode. As related In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Posted on May 10, 2010
mikedem7
  • 25 Answers
SOURCE: A circuit breaker tripped and
there is an overload fuse inside the unit.
Posted on Aug 19, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp Microwave Model R-1830: No power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open oven thermal cutout (TCO) on the top of the oven cavity / body or an open thermal fuse on or above the magnetron.
These should read closed (virtually zero) on a continuity check.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it went dead or when you plugged it in or opened or closed the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site but the best place to order Sharp parts is Tritronics.
Posted on Oct 13, 2008
jmgldsmth
  • 2005 Answers
SOURCE: Kenmore over the range microwave 721.63684300 - nothing works
you must remove the MW take off the cover then look for a large metal can (capacitor) and a white (ceramic) fuse...look and, smell and, you should find the cause
Posted on Apr 22, 2009
housejess
  • 317 Answers
SOURCE: Wife left our GE spacemaker 2 running for 20
theres a fuse inside the unit
Posted on Nov 07, 2009
Reset button
Unplug,then plug back in,wait 10 minutes,or try another outlet,circuit breaker could of turned off at control panel in house,reset it.
Mar 04, 2017 | Microwave Ovens
Hotpoint model 6671P convection microwave keeps tripping mains panel Fuse when start is pressed. Could this be a problem with a fuse in the Microwave or is is a dud magnatron? How best to test?
Too many watts on same circuit. Plug it into a different outlet and see what happens, not on same circuit. So one that stays live when micro trips circuit breaker.
Mar 05, 2015 | Hotpoint Microwave Ovens
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Oct 21, 2010 | Microwave Ovens
No power to microwave
Hi
When your microwave oven doesn't work at all, it means interior fuse inside the microwave has blown (usually a part inside the microwave makes this fuse blow). Sometimes a bad fuse holder inside the microwave cannot hold the fuse tight enough and the fuse will blow as well. If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work. It can also be due to a stuck or faulty door switch which might have blown the interior microwave fuse.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 14, 2009 | Microwave Ovens
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave
There won't be a reset button.
Is it dead? No display, no lights, etc.?
If your outlet is live but your microwave is dead, then you likely have an open internal fuse, thermostat or thermal cutout.
Please post back if you need more help and think you or a friend want to work on it.
Nov 01, 2007 | Microwave Ovens
GE Spacemaker 2.0 Microwave just died!
If you're getting power at the outlet, the most common problems causing a "dead" condition are a bad thermostat (or thermal cutout / thermal fuse) on or near the magnetron, a blown internal fuse, or a problem on the control circuit board. I would suspect the thermal cutout / thermal fuse in this case. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If it seems to be a problem on your control board, we repair these for $39.95 nationwide in most cases. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you need more help, feel free to follow up here, but please include your model number (e.g. JVM1190, etc.) I appreciate your thoughtful rating of my answer.
Oct 02, 2007 | GE JVM1190 Microwave Oven
Microwave Ovens Logo
37 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
