Question about Reddy HEATER R115 115,000-BTU PORTABLE KEROSENE FORCED AIR HEATER
My reddyheater115,000 was working just fine now it only hums when you plug it in HOW DO I FIX IT
  • 6,826 Answers
The pump,is locked up,in the rear of the motor,or the motor has gone bad,I have a pdf file on this model if you need it,let me know,roniecon@gmail.com
Posted on Mar 31, 2011
My Cube 30 hums when I plug my guitar into it, buzzes really loud when on effect channel, clean when plugged into AUX
You have a bad ground somewhere. Try different cables and check the effect channel port if it is tight and secured.
Jun 02, 2016 | Music
I took my 2002 Ford Windstar LX 3.8L to a Ford Dealership to have three recalls fixed. My brakes, rear axle, sub-frame brackets. When I got it back it has a loud humming when I pick up speed from any
a hum is a very vague request a hum can be from tires ,engine ,driveshafts rear or front axles etc advise to bring back to dealer who preformed work on vehicle and advise them that the hum wasnt their prior to repair work also the work should be under warranty
Jul 24, 2013 | Cars & Trucks
Motor hums
What is the model number?
Oct 18, 2012 | Washing Machines
I have an older model Harman Kardon AVR and have started hearing humming from the speakers that are attached to it. Is my receiver going bad or is there something else I need to do to fix this problem?
you may have a bad Earth power 110 V AC cable connection which makes such hum / buzz even nothing connected..
Check the connections between components and make sure they are secure before proceeding to the next Step. Sometimes, loose connections can cause a hum.
  • Separate the audio cables from the power cables; electromagnetic interference from the power cables can cause stereo hum. Use cable ties to secure the audio cables away from the power cables.
  • Plug in a surge protector to the outlet, and then plug all the components into that surge protector
  • Connect a ground plug to the surge protector and then plug the ground plug into the main outlet. A ground plug is available at any hardware store, and turns a three prong connection into a two prong. Ground plugs help eliminate 60 cycle hum.
  • 5 Connect the ground wire from your turntable to the ground wire connection on the receiver. If this doesn't work, looking on the back there should be a grounding point,
    Unplug your receiver.. Split a wire and attach one of the splits to the receiver where you will see the text, "ground" or something similar. Attach the other end to something metal such as a pipe that goes into the ground. Secure with electrical tape. Plug in.
    connect the ground wire to a screw on the electrical outlet.
    Read more: How to Fix a Hum on a Stereo Receiver ' eHow.com http://www.ehow.com/how_5183193_fix-hum-stereo-receiver.html#ixzz1PpFHs1Mv
    Take care and please remember to rate "AS THUMBS UP" Thanks
  • Jun 20, 2011 | Harman Kardon AVR 85
    Have an older (6 + Yrs) VX-10A model, that's worked fine up until now. I recently moved, hooked up the same stereo and surround sound speakers, which worked fine, but the subwoofer made a loud hum as...
    Disconnect the input and see if it hums in the absence of an audio source. A bad audio cable shield or unwisely-routed audio cables will allow entrance of unwanted signals from external power sources, magnetic fields, even dimmer-controlled track lights. Sometimes, simply reversing the orientation of the ac power plug can eliminate humming.
    Mar 03, 2011 | Velodyne VX-10 Subwoofer
    Re: Boston digital BA735. Hum with or without input signal.
    Hmmm I just got the same problem. They worked fine on my old Dell desktop but when I plugged them in to my son's old Dell PC (maybe 1 year newer than my old one) they all hum like crazy - as you say even if it's just the power plugged in and nothing else. Yes it does have the original power supply. I get no music (but still it hums) from digital out/in but when I switch to analog out/in I hear the music and it still hums, plus the sound is distorted. Wierd.
    Jul 14, 2010 | Boston Acoustics BA735 Computer Speakers
    Humming when no input in jack; works fine with rca inserted; worries me that somethings is not right even though works fine with RCA or XLR plugged in, right channel only
    Sounds like it could be feedback hum. Is there anything near it that could cause a reaction when unpluged? Such as a turntable, cassette etc. If so move them and see if it goes away. Even then it won't hurt the amp. I think otherwise worry when there's a hum when they are plugged in. PS check any earth connections too!
    Jun 21, 2010 | Adcom GFA-5802 2-Channel Amplifier
    Hum in sound
    the tv is picking up a 60 cycle hum from the bond wire.they did not filter the main audio board.to fix it buy a 3 wire to 2 wire ac plug without the bond wire. plug it into the wall socket an it should fix the hum. it fixed mine an now no hum. fletchb321.
    Jul 24, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
    Loud humming coming from subwoofer
    This can be caused due to an increase in local interference. The hum is decreased when you plug in the satellites because the interference is spread over a longer area. You may notice that speakers tend to hum around things like cell phones and power outlets. To see if this is the case, move the speakers to another part of the room if you can, slide the desk around, plug the computer in at another room, something like this. If the hum gets louder or quieter, it is interference at your new place. This can be solved by finding a new area to set up your computer stuff at. Since it's mostly the subwoofer, try elevating it off the ground, there may be a power main running under the floor.
    Sep 04, 2007 | Audio Players & Recorders
    Heating & Cooling Logo
    70 people viewed this question
    Top Reddy Heating & Cooling Experts
    Mack Baxter
    T bone 1963
    Paul Carew
    Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
