Question about Minolta Office Equipment & Supplies
Bizhub 253 error code c-c172 can't find issue or how to clear error anywhere. Please help
  • Minolta Master
  • 6,161 Answers
Press the Utility/counter select details then stop00 stop01, then select system 2, => Image Controller Setting and select either Controller 0 or Controller 1 depending on the type of controller (i.e., Controller 0 = Emperon controller or Controller 1 = IC-409
Posted on Feb 22, 2015
5 Suggested Answers
SOURCE: error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
Posted on Aug 26, 2009
  • 51 Answers
SOURCE: Bizhub C253: Error Code C-4551 will not clear.
open front door and switch-off machine
press utility buton hold press-on then swietch-on machine, on the screen right top corner u see dot (remove finger from utility buton)
after fue second u will see trouble reset touch under u will see ok switch-off machine wait 10 sec and switch on
If the error code still is on the machine u have to change cyan laser
Posted on Oct 09, 2009
Bizhubman
  • 108 Answers
SOURCE: how to clear error code c 3421 on konica bizhub
C-3421 = Fusing heaters trouble
To Reset:
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If error code returns a technician is needed to replace fuser section. Call local dealer with error code and tell them to make sure a tech brings a fuser assembly.
Posted on May 19, 2010
copyalbania
  • 96 Answers
SOURCE: My Minolta Bizhub-200 prntr. has a C2557 error
moz-screenshot.pngmoz-screenshot-1.pngC2557 - Abnormally toner detected black tcr sensor.
Reinstall image unit black
Reinstall toner cartridge
Change Image unit
Change toner carridge.
Posted on Aug 12, 2010
Why is error c-c172
Check the setting of System 2 > Image Controller.
Aug 06, 2014 | Konica Minolta Bizhub C550
C451 reset errore c-c172
• A dynamic link error occurs in the program
on the MFP board due to an insufficient
memory space available, a ROM fault, or
other reason when the main power switch is
turned ON.
have tech come out might need to have the firmware re-flashed or the MFP or image control board replaced, have the Memory checked also $$$$$$$$$$$$$$$$$$$$$
May 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
Errore Trouble code C-C172
Refer to Konica Minolta Bizhub C451 Printer/Scanner/Finisher's User Manual or Call Service Center.
May 01, 2014 | Konica Minolta Bizhub C451...
Bizhub 353 c-c172
You meet a Bizhub C-353 with a Code of C-C172, which is a problem that will require tech to look at. It deals with your control board and Non Volatile Memory which houses special info and counter information, it is either bad or the main board, hopefully the tech can come out and re flash the copier software, Or replace NVRAM chip, worse case the main board, he might check all the connectors on the boards for a loose connection or a bad pin, unless you want to that let say 50 connectors, any you might cause more problems worse case the tech say main board need to be replace, you can not get the software for the copier on line. It is located on a secure server at Konica Minolta website for dealerships and KMBS they like to protect there software.
Feb 24, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Konica minolta bizhub c450 error code c- d370
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
May 14, 2013 | Konica Minolta Bizhub C 353, Bizhub...
Machine showing error D370
when machine waqs working atonce power failure occurred and after that it showed error D370
Oct 26, 2012 | Konica Minolta Bizhub C 353, Bizhub...
ERROR C- C172
Hi:
I Form Afghanistan I have a Konica Minolta bizhub C451
Prablem is cod C-C172
Plise help me tanks for you.
Merikh Printing Co.
mpoagency@yahoo.com
Dec 29, 2009 | Konica Minolta bizhub C250 All-In-One...
Error code c2152
good to
Imax Konica Minolta C451 Bizhub
I have a problem is the cod C2151 what to do Thanks
Sep 24, 2009 | Konica Minolta bizhub C450P Laser Printer
440 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
