Question about Garden
Since I moved to a new apartment, the original fish in my aquarium died. I changed the fish and they live but the plants died slowly. Why? acidity of the water?
  • millart Apr 02, 2011
    That make better sense and thank you for your suggestion.
  • 32 Answers
Just like any other living things, plants and animals require certain conditions to thrive. for the fish it will be adequate food, enough air supply and room temperature. for the plant, adequate light and water is critical. you mentioned the acidity of the water, to be on the safe side make sure the PH of the water is neutral or near neutral at PH 7. if you meet all these conditions, your pet and plants should be fine. thanks
Posted on Mar 31, 2011
  • millart Apr 01, 2011
    how do I check the acidity?
  • finley nyaata Apr 01, 2011
    You can either let a certified lab test your water for you or you can do it at home. if you choose to test you water at home you will need to collect some tab water in a small container and let it sit for a minute. then using PH testing stripes provided by a certified lab like Excel water technologies inc. The color code is from dark blue to dark pink. if the stripe turns pink the water is more acidic and needs to be treated by a neutralizing filtrate that contains calcite or ground limestone ( calcium carbonate ) to raise the PH. Thanks.
What order do I put replacement filter media into the frf-1919 aquarium filter?
The goal for the filter would be to keep the water pump clean, so normally you would place the mechanical filter media where the water enters the filter. The water should not be able to go around it, but instead have to pass through the media. Mechanical filtration pulls out pieces of things. If you accidentally get too much food in the tank, and it makes it to the filter, this is what you want to pull out and clean at the faucet. Remove the debris, run some tank water through it so you remove the chlorine, then put it back in the filter.
Carbon/charcoal and sometimes white rocks called zeolite will be doing your chemical filtration, removing heavy metals, and other chemicals, so they can go next. The biological filter media is what is most important. Have this media - a large amount of surface area that water moves through, but will not get clogged up - next to the pump part of your filter. NEVER change these. These are the home for your beneficial bacterial cultures. Detritus (decaying organic material, solid waste, uneaten food, dead plant matter) and liquid fish waste become toxic ammonia. These bacteria consume the ammonia and turn it into toxic nitrites. Another bacterial culture living in the same place turn toxic nitrites into nitrates. Nitrates are plant food, here comes your algae if you leave your lights on all day but don't have live plants in your tank. Nitrates gradually build over time, and fish gradually become accustomed to higher levels of nitrates. This is why we do Regular Partial water changes, to keep nitrate levels low. If you don't do Regular Partial water changes, and suddenly change a lot of water, or add a new fish that doesn't get the long period of time to acclimate to these higher levels, fish can get sick and some may die.
Biological filtration is the most important thing in your aquarium, second only to water. Know where your bacteria live and DO NOT clean it, replace it, dry it out, bleach it, wash it under tap water, and so on. Just leave it alone the same way you leave your fish alone.
Fish can survive just fine without mechanical and chemical filtration, so there is really no need to continue to use those in your aquarium, other than keeping your money in the pockets of the people who tell you that you have to have them and you have to replace them. Any company that tells you the biological filter media must be replaced is lying to you and I would urge you to never buy their products again.
A bulk amount of carbon and nylon mesh bags can be purchased from any decent pet store or supplier, as can foam that can be cut to fit into your particular filter. Personally, I recommend not bothering with either of these, and adding more biological filter media in the extra space you now have. You can never have too much beneficial bacterial in your tank.
Sep 10, 2014 | Fish
Is it safe to use an exotic terra snake cave in an aquarium as a fish hide?
I think using a cave marketed for reptiles would be fine. Three things to consider:
  1. Was the cave previously used in a reptile habitat? When I use rocks from outside I usually boil them to kill any bacteria or microbes that may be harmful to the fish. If the cave is not plastic or wood, I would recommend doing the same.
  2. Is the cave painted? Some people are concerned about paint harming their fish. I assume most paint would be fine, but make sure it won't flake off in the water.
  3. Living Plants? I hate to state the obvious, but the plant will die and the fish may or may not have difficulty if they eat the plant.
All in all, I wouldn't worry too much about the cave. Just make sure it's clean and let your fish enjoy it!
Jan 20, 2013 | Fish
What are the reasons for phosphates in my aquarium?
The reasons for phosphates in an aquarium are uneaten food, plant decay, fish *****, aquarium salts, dead fish, PH buffers and even the water itself.
Sep 02, 2012 | Acurel Fish
Will using plastic aquarium plants have any effect of my fish?
Many of the popular home aquarium fish are by nature herbivores; however we feed them colored fish flakes. Putting fake plant life among their habitat can seem as though you are taunting them with something they would like to have, but is ultimately inedible. Overall, it will not harm your fish in any way, they will adapt easily to the change.
Aug 29, 2012 | Alpine Fish
Are there any disadvantages to using artificial plants in my aquarium as opposed to live ones?
There are several disadvantages; in fact the only advantage I can think of is that they are easy to maintain. Real plants help fish survive in many ways, leading to the reasons why artificial plants are at a disadvantage.
Real plants can act as a source of food for your fish
Fake plants cannot keep your tanks carbon dioxide/nitrate levels low
Real plants fend off algae growth
Why is lighting my aquarium is so important?
Proper aquarium lighting allow hobbyist to observe the fish in your aquarium. More importantly, proper aquarium lighting provides vital energy to photosynthetic plants and animals. Aquarium lighting is essential any system that contains photosynthetic organisms such as plant, corals and anemones.
Aug 21, 2012 | Fish
Is it ok to leave my aquarium lights on all the time?
No. The lights on your aquarium should never be on for more than 10 hours a day. The fish and plants need to rest and by leaving the lights on all the time; they will get stressed out and may even die.
Jul 31, 2012 | Fish
Does a waterfall in my coy pond work the same as a water pump?
Yes and no. Waterfalls in outdoor ponds do providecirculation by moving the water around and keeping it from becomingstagnant. This does however, create acurrent which is not always ideal when trying to grow plants or if you arehousing small fish in your aquarium. Astrong current can make it difficult for plants to take root and can be tootiring for small fish to succeed in.
May 13, 2012 | Fish
Are substrates a requirement for every aquarium?
Gravel or any other substrate is not required in everyaquarium. However, it can be verybeneficial. Here are a few reasons why:1. 1. Fish Habitat: The more comfortable your fish, the more likely they are to do well inan artificial environment. 2. 2. Biological Filtration: Gravel works as a filtration system tocollect any material that grows naturally in the water and to save it can bebeneficial to the habitat. This is truespecifically regarding different nitrates in the water.3. 3. Place for plants: Obviously live plants can't grow out of theglass of your aquarium. Therefore someform of substrate is required so the plants can root themselves.4. 4. Aesthetics: Without a substrate lining, unappealing gunkwill gather pretty quickly on the bottom of the tank. If nothing else, gravel acts as a concealerfor unappealing byproducts.
May 13, 2012 | Fish
Garden Logo
180 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
