Dell Inspiron 537st has a steady amber power light, the fans running and no display. I have tried taking the memory out and reseating it and also the other cards installed. I have also tried a new power supply, but the same result. Any ideas, Thanks
  • 721 Answers
You need a motherboard.
Posted on Apr 16, 2011
Have a black screen on dell 1521
try taking the battery out, pull out the power cord, and push and hold down the power button for 10-15 seconds. Then put everything back and try to start normally. If the problem still continues, try turning it off and pulling the memory out of the laptop and then reseat it...sometimes this may cause the problem but without any sorts of beeping or display occurring, it's very hard to help you on this one. I'm wishing you the best though. :-)
Feb 26, 2014 | Dell Inspiron 1521 Notebook
STEADY AMBER POWER LIGHT, NO POST, BUT FANS WORK
I the power light is a steady amber the computer is receiving electrical power, but an internal power problem might exist. Try these:
Make sure that the microprocessor power cable is securely connected to the system board, remove and then reinstall the memory modules, remove and then reinstall any cards.
Oct 09, 2013 | Dell Studio XPS 9000 (DXCWPP12) PC Desktop
When I power on the desktop the power button LED turns to steady amber and the fans race constantly at high speed. The system does not seem to complete POST or boot into the O/S. I changed the CMOS Battery...
Can you check at the back of the computer to see what the diagnostic lights are indicating 4 led's (eg yygg - yellow yellow green green) - post the result and i may be able to provide a soltuion
Sep 24, 2013 | Intel K83v0 Dell Motherboard Inspiron 560...
Power led light is a steady orange but pc will not power up
If the power light is blinking amber, the computer is receiving electrical
power, a device might be malfunctioning or incorrectly installed.
- Remove and then reinstall the memory modules (see "Memory" on
page 112).
- Remove and then reinstall any cards (see "Cards" on page 116).
- Remove and then reinstall the graphics card, if applicable (see "Cards"
on page 116).
• If the power light is steady amber, there may be a power problem or an
internal device malfunction.
- Ensure that all power cables are securely connected to the system
board (see "System Board Components" on page 107).
- Ensure that the main power cable and front panel cable are securely
connected to the system board (see "System Board Components"
Copy and paste this link to your internet browser for your computer's manual.
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_inspiron_desktop/inspiron-531s_owner%27s%20manual_en-us.pdf
You can also go to support.dell.com
Jan 08, 2013 | Dell Dimension 4600 PC Desktop
I have a dell inspiron 530s and it won't power on at all but there is a steady green light on on the power supply and a amber colored light on inside whats wrong???
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Dec 27, 2012 | Dell Inspiron 530 Desktop Computer
My dell GX 270 computer has amber mother board light,No display,processor fan runs,power supply fan rotates.
hi ansilesh
If the power light is steady amber - The computer is receiving
Ensure that the microprocessor power cable is securely connected to the
system board.
it might also be a failed mainboard already since you are experiencing a blackout.
hope this helps
janc30
Feb 11, 2011 | Dell (002TR) Motherboard
Inpirion 531s no boot no beep
It could be a faulty power supply try replacing that with another one ,if that doesn't work it's very lokely the motherboard is kaputt!..Good luck John
Aug 04, 2009 | Dell Inspiron 531s Desktop Computer
Dell 8400 steady amber light, no diagnostic LEDs, high turbo fan
you will need to change your processor is like it is bad.
Apr 04, 2009 | Dell Dimension 8400 PC Desktop
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
