Question about Microsoft Xbox Console
Xbox i have an xbox with aladdin xt plus modchip in it.i used slayers 2.7 to format and setting. i used 80geg hdd and have it stored games. it works for 3months until recently i noticed often it pause while am using it..i noticed the fan is not working..i have it change but the same is not working normally..it pause or hang eventually.when i turn it off and on it again after a minutes, it works back again for 3mins the hang again.please i nedd help..
Decided to solve the problem of my xbox unit,i apply to desolder all probable loose connection in the regulator section and have the mother board clean thoroughly. then assemble again and it works..my suspect is severe over heating due to fan malfuncyion causes my unit to established poor contacts. thus run abnormal...anyway its ok now..thanks to your reply ......pagadian
Posted on Aug 06, 2008
SOURCE:
Xbox 360 won't delete anything, plus it won't format
You can try connecting the HDD to a computer and formatting that way. FAT32 if all else fails will need replaced. Sounds like HDD has problem.
I’m happy to help further over the phone at https://www.6ya.com/expert/jay_25de800b00457e27
Mar 09, 2013 | Microsoft Xbox 360 Console
Xbox cant read disc but the disc is new
That is strange. The game may simply be defective... it's uncommon, but it does sometimes happen. I would recommend returning it to the store where you bought it and exchanging for a different copy, if possible.
May 01, 2012 | Majesco Jaws: Unleashed for Xbox
If my laser is broken, can i still use the ps2 hdd without ever having to use a cd if i format the hdd in another ps2 and then switch it to mine?
yes, you can, but you will need to use Ps2 with modchip in other to boot hdd loader via memory card or pendrive..
Good Luck....
Sep 16, 2009 | Sony PlayStation 2 (PS2) Console
Mod xbox help
That means the bios on the modchip has gone bad or the modchip itself has gone bad. I would recommend getting it replaced, if it is an Xecuter3 you should be able to hold Power+Eject to go into recovery mode.
Dec 07, 2008 | Microsoft Xbox Console
Xbox hdd upgrade
how do i format my xbox hard disk into my pc
Jun 15, 2008 | Microsoft Xbox Console
Original XBOX error code 07
Found out through Microsoft that code 7 is a HDD failure. Only wat to fix is to replace the HDD.
May 10, 2008 | Microsoft Xbox Console
Xbox mod
there are sites on the internet which allow you to buy modchips. i find the best one is http://www.mod-chip.com/.
but, to play PAL games, you can attempt to follow these instructions: http://www.xbox-scene.com/xbox1data/sep/EEluZpyZylASxnbxII.php
i'm not an xbox technitian, but in my opinion, a modchip would be useful when attempting this.
Mar 17, 2008 | Microsoft Xbox 360 Console
Original xbox
16 - dashboard - Clock cannot be set.
Basically it comes down to this. Error 16 has to do with not finding the menu setting with which you can set the clock of the hdd. This happens to a lot of people that erase their hdd (original/upgraded) or MS dashboard files and after that they don't immediatly install the hdd but leave the xbox without power longer than 5 hours.
It's all about the hdd can't find the menu with which it can set the clock. This is mostly because the xbox hdd is empty (you removed dashboard or fux0red it via ftp). The problem arises when xbox searches for menu to set clock with, can't find it and voila: error 16. Well read on please!
So you have an error 16 huh? Don't worry "nothing" is broken!
You have an xbox hdd that is locked. And normally you can boot in original and modded mode. Retail or upgraded doesn't matter. You start playing around with xboxdash.xbe etc. using ftp programs. While doing this you "accidently" remove your MS dashboard and also your alternate dashboard (Evox, etc.) so there is no dash anymore on the xbox hdd.
You end the ftp session and after that you shut off your xbox. Normally when you would start up again it gives you an error 13/14 ( no dashboard found). No worries with a slayer Evox cd (and a hardmod), all is ok. BUT this is only WITHIN 3 hours or so.
This is because the internal clock of the xbox will only be kept alive by the capacitors for only 3 or 4 hours. So when you leave your xbox unplugged from electricity for over 5 hours after you have played with the .xbe's AND you have removed your (ms and evo-x) dash from your xbox than you are fux0red. Why do you ask?
Why can't I boot from disc?
Its as follows Xbox starts booting==> (almost 1st thing a xbox does is) searches for internal clock==> doesnt find internal clock because there hasn't been any electricity on the xbox for 5 hours so battery that kept clock alive is empty and clock is gone==> searches for the proper dashboard menu to set clock with ==> doesnt find msdashboard or evo-x dashboard menu becuz you have removed it from the hdd for whatever reasons you had==> xbox gives error 16: cannot set clock.
So what do you do about it? Two options!
1. There are some bios'es around that allow the chip to boot past the clocksetting. (do a search!). So how do you get that bios on your chip because you cant boot to a flash program or something? Well you need to have an external flasher.
It seems the m8 bios will take care for you of booting past the clocksetting. Or use the latest Xecutor bios
2. This is the more easy and newbie friendly strategy
-Get a friend with a modded xbox.
-Unlock his hdd with eeprom management from a slayer evo-x cd.
-Than, place his hdd in your xbox.
-Boot with your chip on.
-Now the xbox DOES find a dashboard when you boot in original mode and you can set the time in the msdashboard clock settings.
-Shut off xbox and remove your friends hdd
-PLace his hdd back in his xbox and lock it again
-Install your hdd
-(clock has been set) So boot up with slayer cd.
-Install normally whatever you wanna install
-lock hdd
If you get an error 13 after this, please read up on the error 13 explanation!
13 - kernel - Dashboard launch fail (due to missing/bad key, or anything else that would prevent it from running) and the dashboard didn't specify why it failed.
The error it gives is because of the incompatibility between the (older) dashboard (4920) that older slayer cd installs and the new dashboard/kernel versions found in some new xbox's and found in xbox's that have been connected to xbox live (when you go on xbox-live, it'll upgrade your dashboard file to i believe it is now 5659.03. This dasboard is incompatible with the dash that (old) slayer cd installs (for example 2.5 or lower) for you.
(In detail, in the eeprom chip there is a kernel which is incompatible with the dashboard (4920) that slayer installs.)
So what do you do to fix it? You can use the dashupdate found on most new xbox games! Be sure to 1st unplug your ethernet cable before you do so!!!
Besides that, just use a good installation disc and all is fine. Use a 2.6 slayer or something similar
Dec 26, 2007 | Microsoft Xbox Console
Xbox error code 16
-Install your hdd
-lock hdd
Nov 27, 2007 | Microsoft Xbox Console
Xbox
-Install your hdd
-lock hdd
Oct 23, 2007 | Microsoft Xbox Console
Microsoft Xbox Console Logo
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
