Question about GE GSH22JFT Side by Side Refrigerator
No power to anything other than interior lights
  • 132 Answers
The thermostat has failed. You will need to replace the thermostat
Posted on Apr 01, 2011
How do I fix no power to interior?
What kind of vehicle do you have ? Sounds like you have BCM - body control module problem ! http://en.wikipedia.org/wiki/Body_control_module
The first thing to do would be check the BCM for DTC'S - diagnostic trouble codes ! You would have to take to the dealer or to someone with a up scale scan tool ! A code reader for the OBD2 system won't work for this ! If no DTC'S , check power an grounds for the BCM . If everything is good there change the BCM , there again you would need to take it to the dealer . The BCM needs to be programed an the dealer is the only one who can do it.
May 29, 2015 | Cars & Trucks
Why won't my car start? no lights interior/exterior.
It seems that the battery is incapable of holding a charge. You might try disconnecting the battery cables and try charging the battery again over night. Reconnect and see if anything works - if nothing works - it's time for a new battery.
Apr 10, 2015 | 1996 Jaguar Xj Series
Blow fuse for interior lights and windows
The short is probably an electronic device which shorted a semi conductor in it's cicuit. Even replacing a fuse will only blow them out right away. Do you notice anything electronic that do not work? For example the radio or something. Anyways I am from houston as well.
Feb 04, 2010 | 2005 Volkswagen GTI
Battery drains if interior light fuse is plugged into fuse box.
I'd remove panel as/if necessary so that I could remove connector at power trunk latch, and see what happens from there. If interior lights work o.k. and no drain, then you found your source of drain/short.
Jan 31, 2010 | 2004 Suzuki Forenza
Removing the radio disconnected the interior lights.
It sounds like the power wire fed the lights as well. Most of the time its just a piggyback and when you break the connection it disrupts anything powered by it. Although I must admit that this would be a wired wiring but stranger things have happened.
the very first thing I would check is the fuse under the dash. If you it any of the wires taking the radio out you may bhave blown the fuse that protects it and it is very common for a fuse to control and protect more than one item such as a radio , interior lights and cig lighter all at once. If the fuse is blown then problem solved. If not your going to need a tester to find out what wires are poer, negative and what goes where.
Joe
May 19, 2009 | 1992 Nissan Maxima
Instrument panel and interior lighting not operating, 2004 F150
sounds likke u got grounding problem with ur wiring. if ur fuse pops wen u install a new fuse. this means ur grounding wire is cut or touching with metal. if doesnt pop,then it is ur power wire that is cut or touching the metal (grounding out)
Jan 12, 2009 | 2004 Ford F150
Samsung Model RS2630SH
if fridge freezer sits down after power outage on a rs21dcns where interior lights are lighting but nothing else is working press power freeze and power cool buttons together for a few seconds should repower unit
Feb 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
GE GSH22JFT Side by Side Refrigerator Logo
37 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
