Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Freezer is too cold and icing over into the refrigerator - also makes a noise when the door is open and then shut. Refrig is not staying cold at all. HELP
  • 132 Answers
It sounds like your automatic defrost cycle on your refrigerator is not working.
Try manually defrosting the fridge.
If this works then you will need to get the auto defrost repaired.
Posted on Apr 01, 2011
Refrig door was not completely shut fof about 24 hrs temp was 50. Makes a loud noise when running and about 8 hrs after discovery has only gone to 46 degree
Listen to sound where is it coming from bottom back? Or inside near back wall . noise could be ice on or around evaporator fan if you can unplug for 12 hours leave doors open this will melt ice . if it is ice that will fix it.
May 08, 2015 | Gladiator GAFZ21XXMK Bottom Freezer...
Subzero 532 refrig fan(& compressor) doesn't shut off
the higher the number on a fridge the warmer it is so setting it to 1 is close to 0C
when working on a fridge or freezer always turn it off at the wall
if the fridge is keep cold but not cold enough set it back to say 3
if the compressor is running and the back fins / wall is hot then the fridge is working
use a piece of paper between the door seal and the fridge edge to ensure that it is sticking to the fridge and sealing off properly
Jul 16, 2017 | APW Wyott SubZero Refrigerator Freezer...
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
10 year old refrigerator is not cooling in the refrigerator section. Freezer still working. Will cleaning the coils solve problem?
check the damper door between the refrig and freezer compartment and make sure its not iced up and cannot open and let in cold air from the freezer,you may need to remove some plastic diverters that channel the cold air from this door,then if its iced up deice it with a hair dryer and watch movement when you adjust cold control in refrige now
Mar 23, 2010 | Refrigerators
Side by Side Refrig./Freezer ices up and shuts off
Good day,
You said it was iced up. That is an indication the defrost system is not working. The thermostat (round Disk??) if it popped out is probably due to swelling. Replace it.
Since the machine is empty, unplug and leave the doors open for 24 hours.
1. Air sensing thermometers will rise rapidly when the door is open. Not a trusted method.
2. The compressor will not run because you open the door. there is a time delay for refrigerator thermostats to react.
3. Leaving it unplugged with the doors open will guarantee that hidden ice in supply and return chutes has completely melted. IMPORTANT.
Below is a good tutorial on defrost systems.
Hope this helps , but if you need to post back please include make,style and complete model number.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa and
please rate me.
Jack.
Jan 06, 2010 | Refrigerators
Roaring sound
I have had the same issues. I have owned my LFX25960 for 18 months. All the cooling, noise, and condensation problems are related to 2 fans. One for the freezer/refrigerator compartments and One for the Ice Maker. The fans, apparently, are not sufficient to move enough air through the coils located behind a plastic panel in the freezer compartment. The part numbers for my fans are 1. Ice Maker 4681JB1029E and Refrig/Freezer 4681JK1004E. It is not impossible, but fairly difficult to replace them yourself. You have to remove the large slide out freezer drawer and glides. Then work the back freezer panel loose from the bottom. Be careful not to break it. It is plastic.
Routine maintenance: Pull the refrig out from the wall and blow-out the coils and fan located on the lower right rear. You might find it easier to do this by removing the cover on the lower, back of the refrig.
Apr 17, 2009 | LG LFX25960ST Stainless Steel French Door...
WARM REFRIGERATOR
Sounds like the damper isn't opening. Put you hand on the Left wall of the fridge side, at the top. If you feel No Air. Then there is your issue. Bad Damper Motor. Also check the back wall of the freezer, there sould be No Frost. If there is then you have a defrost issue. Not a damper problem. One more thing. Make sure when you shut the fridge door, the light goes out. About a half inch or so before the door is completly shut, the light will go out, if not then thats your issue. Let me know how you make out.
Bill
May 12, 2008 | Frigidaire FRS3R5EMB Side by Side...
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
REFRIG SIDE NOT COOLING
The sweating inside is from the door not making a proper seal, and you are getting condensation build-up. The door not shutting is not as unusual as you may think. First check the gasket condition, a new one may not be a bad idea. On these refers with the revisable doors, try removing the freezer door and then loosening the fridge door hinges and adjusting the mounts. Its a trial and error procedure so don't get frustrated. Another trick is to wad up a wash cloth into a ball and wedging it into the door gap after you open it on the hinge side, then close the door. You should have some tension, but not too much. This bends the door a little. If you can get the door to make a good seal it should solve the other problems with the temperature. If not, you are going in the right direction by locating and cleaning the vents. All the cool air in the fridge comes from the freezer.
Nov 13, 2007 | Whirlpool ED5SHAXM Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
91 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
