Question about Garden
We have a Huskee model 13AB606H7304490003 and both spark plugs were taken out and thrown away and we have no way of finding out what size plugs are needed
    Brigadier General:
  • 3,911 Answers
Somewhere on the engine is a label telling you who made it and a model number. Most likely a B&S engine but there are some Kohlers and Tecumsehs out there. Take your info to a mower or small engine repair shop and they will sell you the right plugs. There are just a few types.
Posted on Apr 01, 2011
Replaces battery and spark plugs in my huskee lawn tractor it cranks over but won't fire has full tank of gas and battery is charged what could be the problem?
No spark? Check out ignition coil. Make sure the fuel is turned on if you have an on line hose switch for that.
Mar 28, 2017 | HP Garden
HOW DO YOU REMOVE THE SPARK PLUG FROM A HUSKEE 26750 TSC ROTOTILLER
repair manual
Huskee 26750TSC Operator Manual
page 14 shows the spark plug
above the stamped OHV metal cover on the motor
plug might be covered with one of these hard plastic caps
they break often and you can buy new ones
or a stock rubber insulated plug connection
would then suggest a tube spanner or plug spanner
Tiller Spark Plug Parts
cant say if its spark plug is a long threaded long headed type
or a stumpy
Oct 17, 2016 | Garden
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
My HUSKEE Supreme model 12A-569K730. Won't turn over fresh oil, gas, new spark plug clean air filter. What else should I try?
is there a bowl with a screw on bottom attached to carb if so take the screw out an look for a tiny clogged pinhole on bottom .
if not then you'll likely need a carb kit the rubber is not working correctly an has air holes
take out the plug an let it hang is it sparking
prime it does it fire up any meaning a kit or cleaning
May 03, 2015 | Garden
I have an old coleman powermate 6560 . Its missing the spark plug (which got thrown away) and i can't find ANYTHING on what spark plug to use in this generator.model number is PM0645250
The J8 spark plug is typically used on almost all small motors. You can google J8 cross reference for a list of alternatives that will work.
May 02, 2015 | Coleman Electrical Supplies
Model 13aj771g031 huskee lt4200 lawn tractor 18 1/2 HP engine. 2009 yr. Need to find out deck belt size. Got far enough to find out its part 44 on sears part diagram but that's as far as I got. No size or...
It is a "G" deck which is the 42" Cut.
Deck current part number 954-04060C which is 1/2" x 96-1/2"
Just Google 954-04060 and you find several online suppliers.
Pricing depends on the supplier and if it is OEM or aftermarket.
Mar 28, 2015 | Sears Garden
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
Kia Sedona spark plug coil
all different shapes and sizes, to find one follow a spark plug wire away from the spark plug and it will lead you to a coil
Mar 14, 2012 | 2002 Kia Sedona
What engine will fit a 2001 windstar that uses a shorter spark plug. I had a tune up and the guy used the plugs for 2001 windstar. They do not work well. The plugs that were taken out were shorter. ...
never mess with spark plugs always use the factory recomend type for your engine and always use standard plugs not the fancy expensive iridium, platinum, gold, silver, its a gimmick you wont ever notice a difference and those plugs cost average $16 dollars a piece..my NGK stock plugs cost $2 yes i do have to replace them more often and regap them but i taught myself a trick so i dont have to do that anymore..it the gap for example say .035 i set it for .034 and leave them in for about a good 50k and as they wear down it'll probably be at a gap of .036 and at top speed plugs will operate more efficenltly with a slightly larger gap.
Aug 14, 2010 | 2001 Ford Windstar
23hp briggs on huskee only runs with full choke>>>??????? any help??
Pull the plugs, reconnect spark wires, and holding plug against engine (to ground the shell) crank engine. Good spark both plugs? Reinstall them, and check the fuel system -- dirty fuel filter, or dirt in carburetor or lines.
Aug 01, 2010 | Garden
Garden Logo
96 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
