Question about EZ Dupe (EZD1TDVDPIO) DVD Duplicator Burner
When I try to make a copy it say it fail - EZ Dupe (EZD1TDVDPIO) DVD Duplicator Burner
  • EZ Dupe Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd burner then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Posted on Mar 31, 2011
Problem in copying of Toshiba 523
If you try to copy, can you see the scanner light moving across? If not the lamp has failed. If it always works first time, that could be a failing lamp or a poor connection
Mar 23, 2014 | Toshiba Office Equipment & Supplies
Why won't my Bixolong SRP-275 print the second copy of the receipt? It only printers the first copy, and the second copy is faint at best. thanks,
So it is printing the second copy, just faint? If everything is set correctly in your pos system in regards to fonts, etc, then unfortunately that sounds like a hardware problem. It could possibly be the power supply failing not supply enough current to drive the thermal head, or a main board problem, or even the thermal head might be failing. You could try cleaning the thermal head (black shiny thing you can see when you lift lid up) with isopropyl alcohol. Failing that you need a tech.
Feb 04, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Backup failed--a shadow copy could notbe created, insufficent storage available to.create a shadow copy storage file, or other shadow copy data.------ox800423if
The drive you are trying to backup to has run out of space, you need to make sure your backup drive/partition has enough room available for the backup your trying to run.
Nov 09, 2010 | Computers & Internet
Lenovo's Backup and Restore app fails. Besides a generic "backup failed" (no message for the failed restore). I'm running version 4.0.
then try to reinstall the lenovo software
if it does not work do not go for a application backup
use the same feature for windows
or
try for the manual copy and paste
Jan 28, 2010 | Computers & Internet
When I turn on the 1525 Dell laptop...a screen comes up saying windows could not start because the following file is missing or corrupt.windowssystem32configsystem. The page then suggests attempt to repair...
it is nothing but windows registry error. do one thing in another pc download the Hiren's boot cd from internet, write that file in a cd, try to boot from that cd & repair the registry. otherwise just format the operating system & reload the OS.
Jan 10, 2010 | Dell Inspiron 1525 Notebook
Can't Copy Large Files From camera's memory card! so many people have this problem and no one has the answer. thanks for any help.
Perhaps you're hitting a faulty memory card. Have you tried a different memory card in your camera to perform the same?
If possible, also try that same card in another camera capable device such as another PocketPC device or better yet, a memory card reader and perform the same operation tests on that card.
the copy would fail at the same file, once so much space had been
filled. At that point, It could no longer add additional files. You could
try copying a large directory of files and see if the copy always fails at the same spot or if you can't copy files once the card hits ??MB. i.e., on the faulty part card, as soon as I hit the size mb, It could no longer add more files. also Use a card reader that accesses the card directly as an external drive...
Aug 24, 2009 | Kingston (DX100-SWC)
Changing processor results in windows xp pro failing to install
I'd try upgrading the bios with the working cpu and then try again.
Let me know what happens. I like the weird ones like this.
Feb 26, 2009 | Abit KT7A Motherboard
EZ Dupe (EZD1TDVDPIO) DVD Duplicator Burner Logo
74 people viewed this question
Top EZ Dupe Computers & Internet Experts
Gene
alwaysreddy
Are you an EZ Dupe Computer and Internet Expert? Answer questions, earn points and help others
