Question about RCA D52W19 52" Rear Projection Television
Rca d52w19 rear projection changed flyback and cp150 cap. fuse fl231 is good . have bowed screen and 3d effect. convergence shows in menu but cannot adjust at all.
  • karl hilbrecht Apr 01, 2011
    what board is ir650 and 651 on
  • mudguy67 Apr 01, 2011
    it is on the convergence power supply board
  • RCA Master
  • 8,617 Answers
IF the FL231 fuse is good and you still can not adjust the convergence then the Convergence power supply board would be the most likely problem. You can get the replacement boards from www.tvrepairworld.com
Posted on Apr 02, 2011
Screeen is bowed and i have a ghost or 3d effect on the screen. the tubes may need to be converged, but not sure how.
This RCA DLP tv model have auto convergence at it menu,lost it from the menu or can't get to converge,this tv have a convergence fuse mean the convergence fuse FL(231) near the FBT-flyback tranformer is dead.U have a soldering iron,a roll of desodering braid or a desoldering pump and a roll of solders,also can do basic soldering.Try website like Ebay.com to buy a convergence fuse(FL231) to do the replacement.
Feb 07, 2011 | RCA HD52W59 HDTV Projection Television
I can find where to line up the pluses for the colors
No,convergence screen set up menu appear,Mean convergence is dead.Replaced the FL231 all three of these caps convergence fuse,near the FBT,big black block of plastic,flyback tranformer.Resolders FBT also.Done this will solved ur convergence problem in this RCA tv model.Ebay.com to buy the FL231 convergence fuse for the replacement.
Mar 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA big screen TV picture now looks like 3D without the glasses. The picture also bows in at the top and bottom in the middle of the screen. What would cause this?
Go to menu then setup if you donot see convergence on menu then you have a blowed Fuse FL231 it will be on Bottom board to left side onthe righht side of FBT flyback transfomer there is 3 of them in a roll small brwn rectangler looking caps But are fuses the one in the middle is it. Call Mats for fuse 1-800-628-1118
Sep 26, 2009 | RCA Televison & Video
3D looking pic. on my RCA-P52813BL
The prob.is ur covergence.Go to menu setup look for convergence,see no convergence.U have an open Fuse(FL231)lacated right side of the Flyback Transformer.There are 3 in a roll small brown rectangle looking caps,but they are fuses.The one in the middle is dead.
Sep 02, 2009 | RCA P52812BL 52" Rear Projection...
Rca r52wh74 . Double picture .
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 it will be on right side of FBT flyback transfomer there will be 3 ina roll they are small brown rectranigler looking caps but are FUSES. It will be the one in the middle.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA Projection TV Model #p46921, Has bowing effect of pictures
Go to Menu then setup look for convergence if you do not see convergence on menu then you have a open FUSE FL231 it is on right side of FBT flyback transfomer there is 3 of them small brown rectrangler looking caps it will be the one in the Middle.
Jan 31, 2009 | RCA R52WH73 Projection Television
Rca hd52w59 3d screen colors are seroperated no convergence
i have found the reason for the fl231 fuse blowing is faulty solder connections on the flyback transformer is the main cause. I have came across only one bad signal board that cause this but this was very very rare 1 in 1000. This is a very specific fuse, .400 and it is recomended only to replace with exacte one. consult the fl231 problem in the tips and tricks section.
Jan 02, 2009 | RCA HD52W59 HDTV Projection Television
Bowed at top and bottom
No amount of cleaning is going to fix this problem, Go to menu look for setup see if you have convergences listed on menu if so try auto converge. If convergence is not on menu then you have a open fuse next flyback transfomer FL231 middle fuse.
Nov 10, 2008 | RCA D52W19 52" Rear Projection Television
Convergence
Go into menu look on setup see if convergence comes up then do auto converg. if you do not see convergence on menu then you have an open fuse FL231 square brown cap next to flyback.
Jul 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Convergence menu not available on my RCA HDTV. Model R52WH74YX58
So the set is completley without convergence? bowed and the 3d effect.]
There is a small brown rectangular fuse fl231> it is common for this to blow due to poor solder conections on what is known as the flyback. IF this is your problem then it not a difficult repair. i do them all the time at the shop in about 15 min. Getting the fuse is the most difficult thing.
Mar 03, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
