Question about Xerox WorkCentre Pro 416DC Copier
How to replace image drum in Xerox Workcentre Pro 416?
    Sergeant:
  • 192 Answers
Http://download.support.xerox.com/pub/docs/WCP_416Si/ocessuserdocs/any-os/en/wcp416_UG_en.pdf
Go to page 8-14 for a step-by-step process.
Please give me a 4 thumbs up if this has helped.
Posted on Mar 31, 2011
2 Suggested Answers
  • 2072 Answers
SOURCE: need to reset replace drum message on Xerox
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
Posted on Aug 19, 2010
TRYING TO PULL OUT DRUM FOR A
please open the right side door then open the front door and try to slide out the drum.
Aug 08, 2014 | Xerox WorkCentre Pro 416 All-In-One Laser...
My workcentre pro 416 is printing all copies as all black.
It sounds to me like the High Voltage Power Supply, Biasing Ground, or Blanking Exposure Lamp may be a fault. You could also have a problem with the Digital Scanner unit. But, there is nothing that you can do yourself: EXCEPT: If the unit takes a Toner Cartridge that includes the drum, I would try replacing that first. Then if no joy, your going to have to call out the big guns. Good Luck!!
Jun 13, 2012 | Xerox WorkCentre Pro 416 All-In-One Laser...
MY xerox work center pro copier 416 works well while photocopying,but i need a driver to operate from my PC
Here is the xeros link to drivers from A-Z.  There is no workcentre pro 416 listed.  Check your model number and scroll down to workcentre.  Good luck.
http://www.support.xerox.com/go/prodAtoZ.asp?Xlang=en_US
Oct 13, 2010 | Computers & Internet
Need to reset replace drum message on Xerox Workcentre Pro 416
Aug 19, 2010 | Xerox WorkCentre Pro 416DC Copier
Xerox WCP 416 , it showed message replace drum cartridge
It sounds like you are replacing the toner cartidges NOT the Drum Unit. Drum is located behind the toner cartidge and you will see it after removing toner. Pretty common mistake :)
May 12, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Unimessage pro driver error
try reseting the nvram. if no luck after that try changing the image control board.. with another one if it's avaliable.(maybe you have another machine around. If not then conect your printer to the network reset the printer so you can get an ip address.. usually it's a 192.168.*.* Then type that ip address 192.168.*.* into the top of your web address bar and you should be able to see you printer. If not i would change the image control board because it might be bad.
Feb 10, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Can't get the old drum to come out of the copier. It seems as if it is caught up on something. I have a workcentre pro 416
When you open the right side door, look toward the back, about 4 inches above the drum. You will see a pin about 1.8th of an inch in diameter. It is spring loaded but is most likely stuck in. Just pull it out gently and it should slide out, releasing the drum shutter, that should allow you to remove the drum wheh you depress the handle.
That is the most common reason that drum will stick.
Dec 30, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
Xerox Workcentre Pro 416 P
This would be the first thing to try..
  • Press the 0 and 8 keys simultaneously and switch on.
  • Input 400 using the numeric keys, and press the enter key.
  • Change displayed status counter to 0, and press the enter key.
  • Switch the machine off then on. Check that the machine returns to the normal standby mode. If the machine does not return to normal standby mode, perform the following checks.
  • Feb 18, 2008 | Xerox WorkCentre Pro 416 All-In-One Laser...
    Xerox WorkCentre Pro 416DC Copier Logo
    517 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
