Question about Whirlpool Dryers
Whirlpool Estate gas clothes dryer runs but the heat only lasts for about 10 minutes. the drum will be turning the heat will be on but only for about 10 minutes.After 10 minutes the drum will still be turning but no heat. the ducts are clear
  • 552 Answers
The gas coils have failed. These are the two round devices on the gas valve. You would need to open the dryer to access and replace the gas valves. Every make and model is different.
With the model number I would be able to better assist you.
Posted on Mar 31, 2011
Testimonial: "thank you, expert! model # is TGDS740JQ0"
The dryer is started and the flame starts to dry the clothes. The dryer runs for about 10 minutes then the flame goes out. The dryer continues to run but the flame is out and does not turn back on. ...
Remove the entire venting system and thoroughly clean the lint out. This does cause this problem you have for no heat after running for a few minutes
Sep 01, 2010 | Estate EGD4300VQ Gas Dryer
I have and electric estate dryer. The drum is turning but the clothes are't getting dried in the automatic cycle or timed cycle
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 14, 2010 | Estate TGDS840JQ Gas Dryer
Dryer runs but won't heat
As the clothes gently toss about inside the drum, a temperature control thermostatic disk regulates the heat. It is set for 160f for cotton and it mounts on the blower housing. As air is drawn into the drum and out the backside of the dryer the heat is regulated by this control. It sends 120 volts to the gas assembly. Right next to it is a fuse. The duct fuse is set to blow at 250f. Should that control fail to open and allow for heat to build to abnormally high temps. Note: the fuse will kill the heat source only on most dryer, the dryer will however continue to run. Lint and vent blockage can restrict the airflow and make the heat inside build to dangerous levels.The control thermostat powers up the heat for a minute then shuts down for a few minutes, then repeats this all throughout the drying process, the gas does not stay on! That would burn the clothes. If both of those items check ok and the dryer vent and lint has been cleaned, I next take a look at the gas assembly. I check the flame sensor first. If the flame sensor is open the ignitor will not glow. If that turns out to be good I next check the ignitor itself for continuity. If it turns out to be good I replace the coils. Those coils cannot be checked because they do not act up until energised. Sometimes the coils will work, get hot and fail, cool down and work again. I have some repair photos: HERE
Feb 12, 2010 | Whirlpool LGQ9858P Gas Dryer
Dryer ran all night now no heat
Remove back of dryer and take out the elament shield and replace element don't over strech it start at one side and work it around thank you for useing fixya rate me
Jul 13, 2009 | Estate TGDX640JQ Gas Dryer
Whirlpool gas dryer drum turns, heats for 10 minutes, then nothin
there is thermostat in the unite look at owner manual that what sounds like. basically it is sensor that tell the unite to turn off.
Jun 24, 2009 | Kenmore 63942 Dryer
Dryer does not release any heat
Is yours the gas model? If so I need you to look for some things. Open back door panel and see if while trying to light the igniter is glowing orange. Sea Breeze
May 22, 2009 | Whirlpool LGB6300 Gas Dryer
No heat
mcwilliams if you pull the over off the front of the dryer at the bottom you can see the gas burner assy. Put the dryer on time dry and start the dryer, you should see a glow from the ignitor, then hear a click, then the heat come on. In the auto dry mode, the timer advances along with the dryness level. No heat, No timer advancing. If you don't see a glow, there should be a thermosat on the heater can, see if it is tripped. If so if it is resetable, reset then try again. You may have a bad ignitor.
Feb 03, 2008 | Estate TGDX640JQ Gas Dryer
TGDX64OEQ1 Gas Estate Dryer
Sounds like the hi-limit temp switch is sensing too high a temperature and is shutting off the dryer. This is a safety feature and is usually tripped because the outlet air flow is restricted, and resets itself after it has cooled down. Check to see whether the rest of the vent in your house is clogged and clean it. It could also be an inlet fan or blower which introduces air into the drum. If this is not working, there will be no air flow into the dryer, causing excessive heat in the non-moving air in the dryer.
Feb 01, 2008 | Estate TGDX640JQ Gas Dryer
Dryers Logo
163 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
