Question about Kenmore HE2 Plus Front Load Washer
I just replaced the door latch on my kenmore front loader washer model 11047532601 the door locked light doesnt come on and the door locked light isnt coming on all i get is beep beep beep
  • 552 Answers
You have a bad CCU. This is the control board on the top of the unit. Remove the top, three screws on the back. The board clips into the position. You can try to unplug the wires one at a time, the control will probably have to be replaced.
With the model I would be able to better assist you.
Posted on Mar 31, 2011
You: Model #11047532601 Kenmore Residential washer doesn't turn on wath could be the cause???
see the following steps: use the common sense God bless you see the diagram.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Aug 01, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
417 front loader washer - door doesn't register as closed, washer won't start all lights are lit except "door locked" of course I"ve tried to close door fully, unplugged, etc. but no go
The door lock/latch mechanism has failed.
Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 07, 2009 | Kenmore Washing Machines
Will not lock, seems to be in the locked position. DS pushed "something" in that should be out.
You'll need to manually unlock it.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Kenmore Washing Machines
Kenmore 45986 door lock
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Jan 25, 2009 | Kenmore 43142 Front Load Washer
My kenmore front loader model 417 will not start
You have to replace the door lock(switch its all one unit) This will fix it.
Nov 16, 2008 | Kenmore 44102 Front Load Washer
A lot of these errors on these front loaders can be resolved by simply unplugging the washer for 30 minutes to reset the computer. You may also attempt to manipulate the door latch by using the manual release lever to see if you can get the latching mechanism to stay open. The following link explains how to do this:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
This is normally used when the door is latched with the door shut, but it still may apply in your case. If you attempt any of these preliminary checks and the latch still does not work properly, I would recommend replacing it. The next link explains how:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
Hopefully you will not require any replacement parts. But, if you do, a replacement latch can be found at searspartsdirect.com or repairclinic.com. Just type in your complete model number to perform a search for parts. I hope you find this information helpful. Let me know if you require additional assistance.
Sep 01, 2008 | Kenmore Elite 45986 Front Load Washer
Coded"F dl"
"Fdl" is a door lock error. It's usually attributed to a defective door latch mechansim and/or wiring harness from the Central Control Unit (CCU). More commonly, however, the door latch is the culprit and needs to be replaced. Post back with your model number (located around the door opening) and I can give you advice on where to get replacement parts. If you go to my profile and look under "Tips and Tricks", I have step-by-step instructions on how to replace a door latch on a front loader. I hope this helps you.
May 03, 2008 | Kenmore 4292x Front Load Washer
Kenmore 417.29042992 front loader washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 23, 2008 | Kenmore 44102 Front Load Washer
Unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
Nov 22, 2007 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
128 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
