Question about Refrigerators
I have a Samsung SRS594HNSS double door fridge/freezer. My freezer works perfectly but the fridge temperature is stuck at 13c. I have cleaned the fridge and turned it off to find there is ice in the bottom part of the fridge....please help.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 31, 2011
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
How do I get my new Samsung RF220 to be cooler in the refrigerator section? The temperature does not go below 52degrees F. It is set at the coldest setting.
Check for deformed rubber boot that runs entirely around edge of fridge door allowing cold air in fridge to leak out. 2nd possibility: Louvers in wall between freezer and fridge may be stuck in mostly closed position. Force them GENTLY to open. That will allow the cold air to pass normally from the freezer to the fridge to give you proper fridge temps. If these two easy cures don't work, here's hoping that Samsung owes you in-warranty service and parts on your "new" unit.
Oct 12, 2014 | Samsung RF220NCTASR 21.6 Cu. Ft....
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This...
I have a Samsung Waltz double door fridge, i had a noise from the fan for a few days and now the noise has gone so the fan has stopped and the fridge is not cooling as normal, freezer is working ok. This fan would switch off when the door was opened
Sep 14, 2010 | Samsung Refrigerators
My fridge is working but not cold enough. Freezer
DEFROSE YOUR FRIDGE IN ONE DAY OR TWO DAYS UNTIL THE ICES ARE MELTED AND CLEAN
Feb 15, 2010 | Samsung RF265AA Bottom Freezer French Door...
Samsung RB1855SW won't stop beeping and fridge malfunctioning
Thanks so much for the advice. I just gently pried the door sensor switch on my Samsung RB1855SL out with a butter knife and then pulled out the electrical connection and it fired up right away. It looks like some orange juice seeped in and corroded it. What a relief to have the fridge working again, not to mention to not have to listen to the beeping.
Apr 01, 2009 | Refrigerators
Blinking temperature control
You need to check the limit thermostat for the defrost in the back of the refrig section. I replace it with a standard bi-metal type from a Frigidaire to keep the problem from reoccuring.
May 16, 2008 | Refrigerators
Refrigerators Logo
674 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
