Question about Crosley CDE6000 Electric Dryer
What would cause my dryer to qit getting hot? the heating element looks good.
    Master:
  • 414 Answers
The Crosley dryers are similar to the Maytag dryers and actually share parts
Your thermal limit has probably failed, It is located below the lid of the dryer
in back of the drum. You must unplug dryer before servicing it or shut off its breaker
and lift the lid by inserting a putty knife in the gap where the lid meets the chassis
about 2 inches in from each end there is a spring clip which must be pushed back
to allow the lid to lift up. There are two limits in the repair kit so be sure to use the
correct one. The screw to remove it is 1/4 inch socket head and it is fairly long.
Make sure to clean the duct work in the front of the dryer below the lint screen as
the buildup in this area causes this failure. Hope this is helpful :)
Posted on Mar 31, 2011
  • Crosley Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
  • 552 Answers
If the heating element looks good I would suspect a power issue or thermal cut out issue. The small round device on the heater canister is the cut out. The cut out should have continuity. The dryer needs two legs of 110v and one leg of 220v.
Hoover dryer lights up element heats but machine wont run keeps saying clean filter ?
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
Dryer Overheats and or Dryer Gets too Hot
Nov 22, 2016 | Hoover Dryers
Kenmore elite electric dryer runs but then gets hot and then shuts off, replaced thermal fuse, dryer vent and tubing not plugged, dryer runs gets hot blows thermal fuse again.
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Apr 28, 2015 | Kenmore Dryers
The top right side and the right side of the get very hot when drying clothes
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Apr 26, 2015 | Dryers
I have samsung dv220aew/xaa dryer, that gets too hot and kicks code HE. New element, thermistor and cleaned thoroughly. Gets hot, codes on all heat settings. Any ideas?
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Apr 21, 2015 | Samsung Dryers
MY HOTPOINT AQUARIUS TCM580 CONDENSER DRYER STOPS WORKING AFTER ABOUT FIVE MINUTES USAGE AND IN SO DOING TRIPS OUT THE MAIN HOUSE FUSE, WHAT CAN CAUSE THIS PROBLEM
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Oct 05, 2014 | Hotpoint Dryers
Why does dryer gets super hot
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Aug 02, 2014 | Dryers
How can i hot wire my dryer so it will get hot
I would not recommend "hot wiring" your heating element, you could cause a fire. There are safety components in the dryer that will keep the element from coming on or getting too hot. First thing I would check is to make sure that your exhaust line is clear, one of the first killers to proper heating is lack of air flow. If the exhaust line is clear than I would look at the thermostats for your dryer. Depending on the model there could be anywhere from two to four different thermostats and frequently there is also a thermal link that if it goes bad the heat will not come on. Hope this helps and please do not try to hot wire your heating element!
Mar 18, 2014 | Kenmore 63942 Dryer
Dryer gets warm but not hot
I will assume you have the thermostat set on high and checked the dryer vent to make sure it is not clogged with Lint, Mouse Nests, or GI Joes. (I have seen all of these.) There are two common broken bits that can cause this.
First, and most likely, is the heating element. Most electric dryers have two strings of heating elements that run next to each other. If one of them fails then the dryer will get warm, but not really hot. Depending on your dryer you either have to pull the back of the dryer off or pull the drum to inspect the heating element. When it's cool and unplugged it should be very obvious if it's broken. The heating elements look like springs, and one part will be brown and broken, probably near a ceramic insulator. If you are not sure, you can measure the resistance of each string with a multimeter. For a TEMPORARY repair, you can stretch the existing element's broken ends and put it back together. I stress that this is a temporary repair only because it will cause hot spot in the element and could be a fire risk. (Full Disclosure: My Mom has a dryer with this temporary repair that has worked since 1998. I'll get to it eventually.) If this is it, you can get a fully assembled heating element for $$, or you can save a lot by purchasing a restring kit instead. With the restring kit, you keep all of the metal bits and replace only the heating element wire and brackets. There are very good videos on youtube about how to install these properly. The key point is to pre-stretch the element before installing.
It is possible to bypass all the door closed and belt present to run the disassembled dryer for a few seconds to see if both elements get hot and turn red. This is patently unsafe, and you'll probably die from burns, electrocution, or entanglement with the electric motor. YMMV. Emphasis on "seconds" here, as the elements will burn out pretty quickly without airflow.
The other thing this could be is a thermostat. I don't know of any way to test these other than by replacement. They are fairly inexpensive compared to a fully assembled heating element.
Good Luck.
Feb 19, 2014 | LG Dryers
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Estate Dryers
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
Crosley CDE6000 Electric Dryer Logo
621 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
