Question about TruTech PLV16190 Television
I have a19 Thin LCD tV mODEL nO PLV16190 WONT TRUN ON so what can i do
  • TruTech Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Good luck.
Posted on Mar 31, 2011
I don't know how to set up the 19' THIN LCDTV MODEL PLV16190
on the remote do you have an input button the input to TV needs to be set on satelite
Feb 18, 2015 | Televison & Video
TV wont trun on. Pull plug and wait 5min, still wont turn on. What can be done to fix this
Tv turn on?Front LCD panel LED power light indication flashing?Yes,than the power supply board is dead,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Jul 09, 2010 | Philips 32PFL3403D/27 32 in. LCD TV
NOTHING COMES ON
Open the back of the TV,and look at the can shaped items called capacitors on the board that the power cord is hooked to.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.Most of the time the big black capacitor on the power board goes bad,and bottom bulges out,but sometimes it is the other capacitors as well.I hope this helps.If you have any questions,please let me know.Thank You very much!
Tyler
Jan 27, 2009 | TruTech PLV16190 Television
TruTech PLV16190 no picture, no sound
Very likely have blown fuses and capacitors in both the power supply and the backlight inverter sections. Repair is best left to a technician unless you are tech savy and able to use a soldering iron.
May 03, 2008 | TruTech PLV16190 Television
Trutech t2000-d remote control codes
I have the same problem as well. I bought 3 different remotes and not one will work with the tv. Although all 3 gave Trutech codes (1116, 1504, and 1713).
Feb 02, 2008 | TruTech PLV16190 Television
Hello
If your TV is an LCD (flat/thin panel), then it's 19", not 20". Support for that TV is at http://www.1800customersupport.com/trutech. But, if you have a Trutech tube TV, then it won't be listed on that website, and they won't be able to help you. In that case, call Target Customer Service (1.800.440.0680), and they should be able to put you in touch with the manufacturer, who can sell you a new remote control.
Aug 26, 2007 | TruTech PLV16190 Television
TruTech PLV16190 Television Logo
85 people viewed this question
Top TruTech Televison & Video Experts
Bill Wright
Level 1 Expert
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
