Heller 600.. won't do spin circle coming up with E2 display
    Top Expert:
  • Washing Mach... Master
  • 77,499 Answers
This is caused by a defective electrical lid switch, in short the washer sees the lid as not being closed so it will not spin for safety reasons. I would replace the lid switch and that will solve the problem. The Heller line of washers is not sold in the USA (we are a USA based site) so I can't provide the exact parts replacement assistance. The lid switch should be very easy to replace based on other models, it will be located under the top lid of the washer.
Posted on Mar 31, 2011
Toshiba washing machine model AW9770SB after rinse
Run A diagnostic and see what error codes u get? the lack of spin is usually a result of a bad clutch or tranny problem. Loose belt if its belt driven and not direct drive. Also on a direct drive the motor coupler may be bad ( which connects motor to tranny) may be defected but when it goes u usually dont get much agitation either.
Sep 27, 2014 | Washing Machines
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
Error e191 sokkia 1030r
Sokkia 1030r displays e191 in horizontal angle window
Jan 19, 2014 | Sokkia Set210 / Set310 / Set310 / Set510 /...
Heller awm600 washing machine e2 error on spin cycle. Washes ok but does not spin properly and gives e2 erro, will not continue with cycle. Any suggestions? Thanks kayjay
BROKEN PIECE OF PLASTIC ON LID CAUSING MACHINE TO THINK LID IS OPEN ALL THE TIME. REMOVE LID, WEDGE BROKEN UP SATAY STICK INTO GAP, REPACE LID AND VOILA!! WASHING MACHINE SPINS AND ALL FOR LESS THAN 15 MINUTES WORK AND A STICK!
Jan 09, 2010 | Washing Machines
E2 error on homemaker washing machine. I have tried eveything including reducing load down to one item. It goes through the wash cycle OK, but will not drain, then eventually flashes the E2 error on its...
I have an E2 error on the display of a homemaker washing machine model no HMWM8000. It will not pump out. The PCB does not have any visibly damaged components, which part is faulty, and how do i test a water level sensor.
Sep 13, 2009 | Washing Machines
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
HELLER MOBILE AIR CONDITIONER
that's the way it should work, after you set temp to 20 degrees, display jump to the inside room temp in your case 25 or 29
Jun 10, 2009 | Haier Heating & Cooling
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
