Question about Roper RTW4300SQ Top Load Washer
I have a Roper RTW4340SQ0 and my washer filled straight to the top and would not cut off it flooded my house what could this be?
    Master:
  • 414 Answers
There is a pocket on the side of the drum which is designed to trap air, this air pressure
in turn operates a switch to shut off the fill valve. It has a clear hose running to it and
sometimes lint will get caught in the line at the drum connection. You can open the
top control panel (usually the two screws at the base of the panel) and the panel
will hinge up. Make sure you unplug machine before servicing. The switch will be
obvious as it has one clear line and two connections on it, It is round. Remove the line
and blow into it to be sure that any lint clogging this line is cleared. Reattach and test if
you cleared a clog. If the line is clear then I would replace the switch. model is under the lid
One other possibility is that the fill valve stuck open, but I have never
seen this happen in 10 years servicing top loaders and stacks. Hope this helps. :)
Posted on Mar 31, 2011
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Does the roper washing machine top loader model# RTW4340SQ0 have a place to put in the liquid softener?
I have the same question but have not find a manual or any other reference that tells me whether this model has a softener dispenser or not. However, I just found this info: http://www.repairclinic.com/PartDetail/Fabric-Softener-Dispenser/8575076A/1195942 which is linked to roper washing machine RTW4340SQ0 parts list. It looks as if the washer doesn't come with the softener dispenser as original equipment but that you can buy this dispenser at repair clinic and just assemble it to the agitator as shown in the video that you will find in the link
Jan 13, 2013 | Roper RTW4300SQ Top Load Washer
How do i put my roper RTW4340SQ0 tub back on its track?
could you please describe the problem you are having a little better?
There is no "track" the tub goes on.
Nov 28, 2012 | Roper RTW4300SQ Top Load Washer
I have a roper Model # rtw4340sq0 that when on the "super" water level setting, just continues to fill ( and drain) when it gets to the rince cycle.
Sounds like the water is siphoning out of the drain hose.
Check the drain hose behind the washer to make sure it's higher then the high water level in the washer.
Aug 03, 2011 | Whirlpool Washing Machines
Roper rtw4340sq0 top loader sicks in rinse mode.
The drive gear for the functioning unit sounds like it has gone south. Unless you are familiar with changing devices like this, I would call your local appliance guy!
Jul 24, 2009 | Washing Machines
Model RTW4340SQ0 clothes waster leaves oil-type stains on clothes
Remove agitator cap. Remove bolt underneath. lift off upper agitator and lower. Look for grease under agitator and on splined shaft and clean. Re-assemble be sure to put plastic thrust piece in between upper and lower agitator.
Jun 13, 2009 | Roper RAX4233PQ Top Load Washer
The washing machine model # RTW4340SQ0 makes a humming noise
Roper is a division of Whirlpool and your machine is still under warranty if only a few months old. You should be able to find a factory authorized service company in your area.
Mar 30, 2009 | Roper RTW4300SQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Roper RTW4300SQ Top Load Washer Logo
154 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
