Not doing anything!! full of water, not spinning, nothing!!!
  • Washing Mach... Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Mar 31, 2011
What is wrong and how do I fix my kenmore 600 series washer?
If this is a top load washer; then the "LID Switch" is broken. Go to www.sears.com/parts, enter your model number and you'll see the switch listed.
Aug 26, 2014 | Kenmore Washing Machines
Whirlpool W10240509A did not spin out all water. when i try to restart iti
mine just started doing this on the wash cycle then we have to turn it to drain and spin. Last night it filled with water and refused to do anything else so it said it was done, open the lid and still full of soap and water. Turn it to drain and press the start button and it does nothing, no lights come on. We bought it in 2012, before the washer we had was purchased in 2000, and we are still using the dryer from 2000.
Feb 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
My washer is full of water and won't drain or spin or anything. I intentionally stopped the washer to adjust it to spin the water off so I could restart the load with some more laundry...now it won't...
The best thing you can use right now is a wet dry shop vac attach it to the end of the drain hose to remove the water.
once you remove the water check the drain hoses and look for anything stuck in the or the drain pump itself and make sure there is nothing blocking the pump.
If all hoses are clear and there is nothing in the pump then you may need to replace the lid switch.There is also a chance that he drain pump is bad.
Jun 19, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer doesn't do anything. We start the cycle
Nothing will happen untill the water comes in. Check the water inlet SCREENS fer clogs
Aug 31, 2009 | Washing Machines
The wash cycle doesn't work, but spin cycle works!
Did you ever find out what was wrong with your washer?
Mar 23, 2009 | Whirlpool Washing Machines
Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jan 18, 2009 | Frigidaire GLTF530DS Front Load Washer
Spin/rinse cycle
It appears your pump has failed in this instance.
The motor may be spinning - but the shaft may be freewheeling in the coupling and not spinning the pump.
Dec 30, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
