Question about Dryers
When cool dryer starts and runs it will run for about five minutes and shut down. When try to start the motor hums and the tumbler will not rotate. Also if start even when cool the dryer will run, if I close the door and try to restart even after only a few moments the motor hums and the drum will not rotate.
  • Dryers Master
  • 43,501 Answers
Your motor is going bad...it will heat up rapidly and then not start....there is a slim possibility that the capacitor is just bad, but to check that you will need to give the drum a spin and then slam the door and start it before the drum stops again... if it then runs you probably just have a bad capacitor...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Mar 31, 2011
The dryer ran for two complete cycles. the third cycle the dryer would not start. When the timer was switched it made a humming noise.
That sounds pretty typical of a motor that has tight bearing and shutting off due to excessive heat being created at the motor because of the tight bearings on the motor. What will usually happen whena motor is very tight is that it will run a few minutes (or cycles) and get too hot and shutoff until it cools down and will start then shutoff agian once too hot.Along with it not starting because of the friction of the tight bearing the motor will make a humming noise and may or may not start.
GENE
Oct 17, 2011 | Roper Dryers
Kenmore dryer 70 series doesn't always start, sometimes it will just put out a buzzing sound after its been running and trying to restart, will start back up after 20-30 minutes.
Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem.
Oct 02, 2011 | Kenmore 63942 Dryer
When the button is pressed to start the dryer it begins to hum as iff the drum is stuck. It does this for about 5 to 10 seconds then shuts off. If I attempt to start it again nothing happens. sound like...
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Apr 17, 2011 | Whirlpool LER7646E Dryer
Dryer turns on, but with every cycle option, the dry and cooling lights are both illuminated, the former blinking. When I try to start the cycle, I hear a short hum, then nothing. The barrel doesn't turn,...
Possible that the motor capacitor is faulty and not lettingg the start up. Opne and get access and change the capacitor . If you are hearring then hum then when you touch the motor it should be quite warm which confirms the failure off the capaccitor or the winding of the motor.
The timerr runs accordingly not knowing if the motor rotates.
Hope this helps.
Aug 26, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Our dryer starts up and runs for a while (15-25mins) then a sound develops and the dryers stops working. It appears that whenever it cools down it will run again. On start up sometimes a strange sound is...
You definitely have a motor issue starting to develop. The motor bearings will usually allow the motor to run initially, but start to get loud after they heat up and eventually bind causing the motor to stop. The motor has a thermal switch on the side that will shut the motor off if it gets too hot, and will re-set after about 15 or 20 minutes.
The motors for this style dryer (I can't look up the exact part as I need the complete model # off your machine's model tag) are usually about $140-$160.
If you would like to get the motor and install it yourself, let me know and I can provide you walk-through directions on replacement of the part.
Aug 18, 2010 | Kenmore 800 6983 Electric Dryer
Hi, I think I need a new motor. When I push on the start switch, I hear a hum, but the motor doesn't start up. However, sometimes it does start. However, sometimes after running for a few minutes, it...
something could be lodged in the blower wheel, or otherwise jammed up the unit, ie; rollers, idler wheel.
either way something has caused your motor to work harder than it was designed to, or it has just gone bad.
there is a thermal switch within the motor to shut it off if it gets to hot. that is likely the reason it shuts off after a little while and when it cools down will restart.
there is also the chance that your push to start button has gone bad, but highly unlikely.
either way it will require tearing down to find the problem.
best of luck, have fun
Aug 03, 2010 | Amana NED7200TW Electric Dryer
GE electric dryer not working
It sounds like your motor is failing.You went to turn it on and it hummed... The motor got hot and triggered the safety shut off. When it cools you may be able to get it to hum again. But you will need to replace the motor.
Let me know if I can help you further.
Apr 15, 2010 | GE DWSR405EBWW Electric Dryer
Frigidaire dryer hums when button is pushed in but won't start
ok can u turn the tumbler freely,
if no well there is something stuck in you blower like a sock or something
if the tumbler turns freely
keep the door open and hold the door switch
try pushing the start button
and tuning the tumbler, yes all three at the same time lol you may need a hand
try tuning the tumbler when you hear a hum
if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
Oct 19, 2009 | Frigidaire Electric Dryer
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Frigidaire Dryer
If Dryer does not tumble , check the following:
" It won't tumble If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it."Source Repaiclinic
Sep 08, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
Top Dryers Experts
