Question about Hobart AM14-253 Free-standing Dishwasher
Hot water blasting out of relief at top right of hot water input
This AM14 has all kinds of special plumbing that we dont fully understand. It is now out of service because the water leak caused great damage to the floor. We need some specs for all the special plumbing that includes a water heater with a gauge on the feed line that rises and comes in the top with some kind of silver topped relief valve that also has an electric valve. In addition the exit water is plumbed in plastic and there is another valve that controls hot water injectged into the exit water to prevent the plastic pipes from deforming or "melting". We called Hobart out and the quoted $800 - they didnt spec what was wrong. Can we get the specs for the installation and the sequence of things that are supposed to happen when we fire it up so that perhaps we can make a better description of the problem. We dont have $800 of a unit that is only years old.
  • 49 Answers
Sounds like you have a booster heater. Hatco maybe or one built on the machine next to the pump motor.? the valves on top the chrome one is a vacuum breaker. easy to put 15.00 kit in. the electric one just fills and rinse gauge just tell pressure . Did a valve on the booster heater leak or its tank maybe. The AM14 is very simple crect temp and presure water going in and your in business if the machine is ok. Boosters have a saftey valve that will go pad and they let water out. just like all home water heaters do. they screw into the tank. yours should have a line to the drain. so if it does leak it goes down the drain not on the floor. all the things you describe on the upper right of your sishwasher are just the nopremal fill and rinse. both the crome thing and the electric have kits that can be put in. I would call hobart and say sendf me a itamized estment of repair so you know what your paying for. with part discritions and numbers and prices. Or call me LOL kidding
Posted on Sep 30, 2008
My pressure relief valve keeps blowing more so when it is hot any ideas please
Pressure relief valves open on high temperature as well as high pressure. They do go bad and are replaceable.
Consider calling the plumber. It is not very expensive part and the plumber can change it quickly.
If you just want to do it yourself:
  1. Write down the make and model of the water heater.
  2. Go to a real plumbing store and buy a new one.
  3. Turn off the heat source (the gas or electricity)
  4. Turn off the water inlet and open a hot water valve at any sink to take the pressure off the heater.
  5. Remove the old relief valve. It may take a long handled wrench.
  6. Install the new pressure relief.
  7. Close the sink valve.
  8. Turn on the water and check for leaks.
  9. Turn on the heat source.
Good luck.
Apr 11, 2015 | Water Heaters
Blowoff valve
Somebody get hot. I assume it is the relief valve on your hot water heater, just replace it if it has failed. Before you do that check the water temperature, it may be set to hot.
Nov 03, 2013 | Plumbing
Tricky and weird hot water issue
Bad single-handle faucet cartridge.
Bad check valve.
Bad mixing valve.
Test for crossover.
http://waterheatertimer.org/Crossover.html
Aug 15, 2012 | Honeywell Thermostatic Mixing Valve...
I have a gas Rheem hot water heater.....The flame appears to be on full blast, not just the pilot. I have run no hot water today, so we shouldn't be out of hot water. The water our of the hot faucet...
Sounds like you have cold water entering the hot pipe, or crossover.
(A) Put bucket under water heater overflow pipe, and stand back from scalding water. Gently open and close the TP relief valve on water heater. Check temperature of water to see if heater genuinely has hot water.
It could be the water heater has sediment build-up and is no longer able to heat the water, or the gas thermostat is bad.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
(B) If water heater has hot water, and hot is not getting to faucet, then you have a crossover problem somewhere.
1) This problem can be located at crossover point of a recirculation system, if re-circ check valve has failed.
http://waterheatertimer.org/Water-heater-recirculation-system.html
2) Failure of a single handle faucet cartridge can cause crossover.
Read how to test for crossover:
http://waterheatertimer.org/pdf/Crossover-on-single-handled-faucet.pdf
3) Other causes for crossover are a failed check valve elsewhere in the plumbing system, for example on the pool equipment. Also a failed mixing valve which is usually installed on top of the water heater so that some areas of the house like laundry room receive very hot water, while the kids bathroom receives lower temperature water.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 15, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    How do you prime the pump?
    all you have to do is open the lid fill the basket with water close the lid and start your pump and then open your air relief valve on top of the filter until you see water coming out of it
    Jun 14, 2009 | Waterway 1 Hp 115 Volt 2 Speed Side...
    GE Profile Smart Water Heater leaking at top/no hot water
    could be pressure relife valve as well- you need to tell us where water is comig from exactly in order to solve
    Nov 09, 2008 | Water Heaters
    Baxi combi boiler 80e safty thermostat light on
    baxi boiler relief valve blows off when heat is turned on when hot water is working it is fine
    Oct 15, 2008 | Protech Systems FasNSeal FSWMKE4 4" Vent...
    Powermax boiler 155, when boiler reaches operating temperature the presure relief vale blow's off at 3 bar, when it cools down the presure go's down too, right down to zero needing a water top up before a...
    Sounds likes you have a hot water system. Some where you have an expanion tank that is full of water and it should be half full. It will a round tank above the boiler and may even have a site glass on the end off it. It will have a special valve on it to lower the water level in the tank. The tank is to absorb the expanding water as it gets hot, and releases it when it cools down therefore preventing your relief valve from popping off.
    Oct 14, 2008 | Heating & Cooling
    Hobart AM14-253 Free-standing Dishwasher Logo
    270 people viewed this question
    Top Hobart Dishwashers Experts
    Jason
    Garth Jackson
    Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
