Question about Dometic Rooftop RV Air Conditioner
I've recently installed a new dometic air conditoner on my RV part #459516.521 new control box part # 3104999 and a new thermostat model # 3109228.001. The thermostst says EE and it wont do anything. can you please help with this, Thanks Dan.
  • danlturne34 Apr 04, 2011
    A simple reset was all that was required to fix my problem Thanks to the service manual you sent. It seems that dometic could have provided this info in the instructions.
    Top Expert:
  • Dometic Master
  • 9,472 Answers
You don't have the dip switches set right in the control boxes,in the kit you should have gotten step by step instructions on dip switch settings,thats why you are getting the EE code.This manual should help you through it.
Posted on Mar 31, 2011
I have a Dometic DuoTherm AC/furnace in my RV. Thermostat got knocked off the wall. Now only thing that will work is the fan in the Manual mode. Heat nor air will come on. What could this be.
If you have properly re-attached all the wires to the old or newly installed thermostat, then I would suspect that one or more of the control wires to the heat pump have either been severed or pulled loose from the heat pump.
Feb 15, 2015 | Dometic Rooftop RV Air Conditioner
Camping world tells me the board is shorted out. It blows a 15 AMP fuse. Where can I buy another duo therm, comfort guard thermostat? They tell me the one I have is no longer available even tho My Motor...
Contact Dometic direct, with your model and serial number and ask them status on new control box, and if no longer available, what is replacement for it.
here's a link to customer support number and e-mails as well.
http://www.dometic.com/enus/Americas/USA/Customer-Support/Contact/
Dec 08, 2011 | Dometic Rooftop RV Air Conditioner
Replacing the remote control for rv ac/furnace with standard thermostat
You are aware that the ceiling assy (control box) will most likely need to be replaced as well, to work in conjunction with new thermostat. If you contact dometic ( www.dometicusa) and give them your model number off bottom of roof unit and what thermostat you are trying to install, they will advise what is required.
Oct 17, 2011 | Dometic Rooftop RV Air Conditioner
I''ve been working on this thing for three weeks now. It is a Dometic Duo Therm model 57915.531 roof top ac on my rv. It will not run. This is what i have done so far: replaced the thermostat, there is...
check the compressor winding resistance from common to start
start to run
run to common
the two lowest should equil the highest
also check shorted to ground
check the capacitors the go bad a lot
May 16, 2009 | Dometic Rooftop RV Air Conditioner
13500 dometic ac for rv with anilog thermostat
My Unit is only about 5 years old; but it's working great now. I spoke to a man at an RV service department, he suggest replacing the thermostate and Jay box, which is the box inside my roof unit, accessable when I remove the filter. When I replaced the thermostate nothing changed, but the Jay box did the trick. The Jay Box came with a new thermostate anyway, and cost around $80. Good Luck
Feb 18, 2009 | Dometic Rooftop RV Air Conditioner
Dometic rooftop air conditioner coil freezeup
We did find a solution, the ducts leading to bedroom in RV was blocked. So far, it has been working since we cleared the way, it no longer freezes up. Thank you.
Nov 24, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
328 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
