Question about Hobart A200 Stand Mixer
The small wire for the magnetic bowl-shield sensor came off and I have no idea where it goes. If its not an easy fix is there any way to bypass the bowl hight sensor and the magnetic sensor?
  • 37 Answers
You would need to get an electric schematic usually one is in the side cover plate.Just a note if you bypass this safety and you call say hobart service out to fix it they will not work on it if the safety has been bypassed they would have to fix the safety before they work on it.did the wire break off of the switch itself or get pulled from the inside somewere.
Posted on Apr 22, 2011
My bowl lift lever on the hobart (bought off ebay) K5ss doesnt lock the bowl into place. What do I need to do to fix it, or at least figure out whats wrong if something needs to be replaced.
On a bowl lift mixer there is a small metal clip on the back of the bowl support arm, it works in conjunction with a small "NIB" on the back of the bowl, when you put the bowl on the support arm there are two pins that the bowl rests on, on each side of the support arm, you place the bowl on the pins then press down the rear of the bowl untill the nib locks into the clip, if the bowl is not locking in place then one of four things are wrong, one of the pins are not on the support arm, the NIB on the back of the bowl has come off (it is spot welded on) or the clip at the yolk of the support arm has worn down or broke in half and there would be no locking action without it. The pins or the clip are inexpensive if it is the Nib on the back of the bowl you will need a new bowl. Hope that helps if not pleases get back with us so we can FiXya.
Oct 14, 2014 | KitchenAid K5SS Heavy Duty Commercial...
Won't start
You would need the bowl guard (have a magnet #13 p 4) to engage with the reed switch (#54 p8) in order to activate the motor circuit. Is it a safety feature. I would not recommend to bypass it.
See IPC for detail
https://feg.hobartcorp.com/resourcecenter/Discontinued%20Product%20Documentation/F34656%20Rev%20B_lk.pdf
Mar 30, 2010 | Hobart A200 Stand Mixer
How to adjust bowl height on 20 qu hobart mixer.It is an old A200 1/3 hp Paddle is to high in bowl and will not mix dough on bottom and sides of bowl
you need to remove splash shield, tilt mixer back,with a long screwdriver adj. the set screwclockwise to decrease clearance for beater to bowl clearance,always use b beater when making adj. clearance should be .054" to .115".also make sure there are no deformities in btm of bowl which can cause you problems.dont forget to vote
Dec 12, 2009 | Hobart A200 Stand Mixer
D300 Floor Mixer faulty bowl guard switch
If you remove the bowl guard you will see a magnet that attaches on iy in a white housing.The scews come loose and prevent it from closing the switch.Also the switch which comes out of the top pedestal can be adjusted.Let me know.
Mar 29, 2009 | Hobart D300 Stand Mixer
A 200 mixer. the bowl lifting lever hits the bowl and guard.
If it hits the bowl its been dumped on the side and bent it. I have done this on sight I get a mapp torch and use a pipe wrench large one and heat it up at the bend where it goes in side and bend it out. or you can buy a new one take the head off four bolts under head and one roll pin inside easy to see and replace arm. The bending is quick and cheap. it will work like new be sure and clean and luber slides wd where it goes in neck.
Dec 23, 2008 | Hobart A200 Stand Mixer
Attachments do not reach the bottom of bowl when mixing
http://www.kitchenaid.com/custserv/faq.jsp?sectionId=222#troubleshooting
This is the FAQ from the Kitchen Aid website. It explains very well how to make the necessary adjustments under the question: My flat beater, wire whip and dough hook are scraping against the bottom of the bowl when I use my mixer. How can I fix this?
Dec 21, 2008 | KitchenAid K45SS Classic Stand Mixer
I have a 20 qt Hobart Mixer. The magnet that is needed to allow the unit to run, is missing. We have used a store bought horseshoe style magnet for the last year or so, but does not work now. Do you...
the magnet is in the front gaurd. I suspect you have it taped on the back. looked behind the gaurd and you will see a small nut with a threaded stud looking thing in the neck of the mixer this is a electricl switch the magnet works. maybe your magnet is not ligned up on it or the switch is bad and you need a new one. the head is held on with 4 bolts onder the head is the switch and another switch for the bowl lift. . Best solution is have your front gaurd on and sliding corretly get a new magnet for it and it will lign up. If I cam and fixed it only way I would is with gaurd magnet. Can you tell I am factory trained and been drilled by Hobart lawyers many times. LOL never bypass a Saftey
One thing if mixer does not run at all it could be many things On/oof switch, Timer, bowl lift shwitch. Gaurd switch, realy that runse it in gaurd models. so be to be sure you need me LOL kidding. Good liuck
Sep 11, 2008 | Hobart A200 Stand Mixer
Mixer has just stopped
On the newer A200s, there is a reed switch behind the solid portion of the bowl gaurd. On the cage portion there is a magnet embedded in a plastic holder. Without it, the mixer won't run.
Hobart part # 438525
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
Apr 04, 2008 | Hobart A200 Stand Mixer
Bowl Lift
Same problem here, went from working perfectly to mix cookie, now I can barely move it...help!
Dec 31, 2007 | KitchenAid KT2651X Epicurean Stand Mixer
Mixer goes really fast then stops
First thing, check the Hall Effect Sensor (part # 9703312) to make sure that it is seated snugly AND properly!  The Hall Effect sensor measures the speed of a tiny rotating magnet and basically tells your mixer how fast it should rotate.  I was experiencing the same problem that many others have described here--my mixer would go really fast no matter what speed I put it on and it would shut off after five seconds. I came to the FixYa site and saw that one solution that seemed to work was to replace the Hall Effect sensor.  So I went to a local hardware store and purchased a new Hall Effect Sensor for about $13.  After I replaced the "defective" sensor, my mixer still did not work.  So, I started experimenting with the three prong orientation of the control board--this can make a big difference. After a little trial and error, I found the correct orientation for the sensor and my mixer worked good as new!  But I was curious to see if the improper orientation was the cause of my original "defective" sensor.  So I put the "defective" sensor back with the proper orientation and THIS ALSO FIXED MY SPEED PROBLEM! There was nothing wrong with my original Hall Effect Sensor at all--it simply was not snugly or properly seated!  I'm not sure how it happened--possibly over time the sensor prongs may have become unseated from the vibrations of running the mixer on high speeds--but my original Hall sensor was not seated properly or snugly.  So before you run out and buy a new Hall Effect sensor make sure that the original one is not only snugly seated but also properly oriented!  If I knew how to add digital pics, I would have put pictures in my comments to clearly demonstrate what I found.  Unfortunately, I am not sure how to do this.   To sum this up: 1. Download the parts information and diagrams from the Kitchenaid site and find the Hall sensor (part # 9703312).  2. Make sure that the Hall sensor is firmly attached on both ends.  The actual sensor should be located next to a tiny magnet and this end needs to be securely seated.  And the other end of the Hall effect sensor has three small prong holes which also need to be firmly and corrected seated to the control board! Bottom line, my mixer is working like new and I put the original Hall Effect sensor back in the mixer. I'm going to hold on the new one as a backup...you never know.
Dec 29, 2007 | KitchenAid KP2671 Professional 6 Series...
Hobart A200 Stand Mixer Logo
134 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
