Question about Roper RAS8445KQ Top Load Washer
I have a Roper washing machine and it will not drain the water?
  • 1,959 Answers
Most common causes for a machine that won't drain are:
  1. Clogged drain tube
  2. Clogged drain hose
  3. Clogged drain pump
To diagnose, remove the drain hose from the drain tube and look for water in the tube. A clog will force water back into the machine. If this is clear, some debris could have worked it's way into the drain hose itself. Check this by removing the hose and inspect for a blockage. If both are fine, the problem is most likely in the drain pump. Many times, a piece of paper left in a pocket will work it's way into the drain pump and get lodged.
Posted on Mar 31, 2011
How to get Roper Washer to drain & spin? My Roper washing machine is only a few months old and now it won't spin out or drain water at any level. I even tried just rinse & drain. Model #...
since it is only a few months old, it must be under warranty. So try that first before touching any repair job lest you void the warranty.
Jul 30, 2014 | Roper Washing Machines
I want to keep the water in my Roper top load washer overnight so it will soak the load of whites I have started but the machine drains.
You should be able to select a soak cycle without having to turn off the water supply, but it may time out eventually and drain the tub. This p[events oversoaking the clothes
Oct 13, 2012 | Roper RAS8445KQ Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Where is the reset button on Roper washing machine top load water fills but nothing else happens
try to turn the timer dial to rinse and spin, and then see if the water will drain
Jul 07, 2011 | Roper RAS8445KQ Top Load Washer
Roper top loader problem with a RTW43408q0. Washer wouldn't spin at first. I ran that cycle again. It filled with water and didn't agitate or drain the water at all.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 21, 2011 | Roper Washing Machines
My Roper washing machine will not drain the water after the wash cycle.
heatman101
Apr 17, 2011 | Roper Washing Machines
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
WASHING MACHINE WON'T DRAIN ALL THE WATER
Check the drain hose for a kink, or inspect it for plugging with lint. Hope this helps!
Feb 16, 2009 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
74 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
