Question about Warrior Paintball Ion / SP8 3 Point Magnetic Trigger
I just put my warrior paintball trigger into my ion, hooked up the air and everything and it doesnt shoot
  • 396 Answers
You may need to adjust the trigger with the allen screws. One screw comes up under the
trigger and the other is straigh in line (you can see that one). Also, make sure you got the grips on right and didnt pinch or pull a wire loose( I did!). Will it fire with the eyes off (press the on/off once after power up to get to eyes off mode)? You should be able to see the magnetic part of the trigger as it moves toward the switch point inside the grip-frame. Is it traveling far enough into the frame to hit the switch area?
Posted on Apr 03, 2011
  • Joe  A
    Joe A Apr 03, 2011
    Here is a link to an Ion manual if it will help. Save a copy if you need it for future reference.
    Smart Parts Ion Manual
Tippman A-5 with low pressure kit, e-grip. When pull the trigger gun shoots fully auto until I manually stop it by re cocking the gun.
Sounds like the gun needs lube. Oil it and try again. 2-3 drops of oil in the hole
where the tank screws on then put the tank back on. Fire it and see how it does.
I havent heard of a low pressure kit for the A-5 but I think it is a waste. There is a rule
with pressure and paintball guns. Low pressure=high volume of air used.
Standard pressure=regular volume. I have 2 a-5's with e-grips and flatlines.
I polished the internals by sanding the bore of the tube (use fine sandpapaer) and
this makes the velocity very consistent.
One thing that comes to mind is that the hammer may not be getting caught on the
trigger latch. Makes sure your gun is assembled correctly. here is your manual.
http://www.tippmann.com/pdfs/products/A5/a5manual.pdf
Feb 15, 2011 | Tippmann A 5 Standard Paintball Gun
When i put my paintballs in the gun and i aim down they fall out the top where they shoot from
Sound like your ball detent is gone or broken.
The detent is a tiny piece of rubber that keeps the paintballs in the chamber and from rolling out the barrel. It's a cheap part, but you will need basic knowledge of disassembling a Tippmann 98 to replace it.
You can find ball detents here!
Feb 12, 2011 | Tippmann 98 Custom Act Paintball Gun
I have an a5 paintball gun with electronic trigger, when i hook it to air and pull the trigger, the hopper is not moving!!!
On the A5 the hopper or Cyclone feed is powered thru a small tube on the feeder side
of the gun. Make sure that tube is connected and if so, pull it off and see if air is flowing
thru it when you pull the trigger. If not, the internal passage may be blocked. Tear down
the gun and clean out the obstruction. If there is a pulse of air coming out the tube when firing
then it may be the Cyclone feed mechanism. Just unscrew the 3 phillips head bolts
under the Cyclone and observe the air driven gear drive. Air up the marker and see
what is moving or not moving. Complete replacement upgrade Cyclone gear drives
are available that say they increase performance if you cant get it moving.
Here is your manual
Sep 25, 2010 | Tippmann A 5 Standard Paintball Gun
My gun just beeps when i pull the trigger even when hooked up to hpa.battery is new.last time i used the gun just before it messed up i had it hooked to o2 and it would fire then beep ,i have a anti syphon...
You have probably messed up your solenoid, did you fire the marker straight up with the o2? I would make sure that all of the board settings are back to factory default especially the dwell and reattempt with compressed air. If the marker is still not firing get your hands on a new solenoid for it.
Sep 09, 2010 | Smart Parts Shocker NXT Paintball Gun
My tippmann 98 custom pro is shooting automatic by itself... i just installed my etrigger but when i hook the co2 up to it, it shoots automatic
The reason for this malfunction can be caused for two things, one is that the trigger is not sitting right or one of the springs is not in place another reason that may cause the problem is over lubing the hammer, but must likely is the trigger not holding the hammer in the rear position until you pull the trigger. Hope this helps.
Mar 05, 2010 | Tippmann 98 Custom Act Paintball Gun
I need to find the parts for the tippmann a5 urban warrior paintball gun
Home page | Special Ops Paintball SPECIAL OPS - A-5-A2 COMMANDO EZ-KIT. Regular Price: $ 79.95 ... Special OpsPaintball is a proud sponsor of the Living Legends scenario paintball game. ...
shop.specialopspaintball.com/ - Cached - Similar
Forum Brigade Tippmann A-5 Upgrades Gear Vests Articles Sick Deal Tippmann X7 Upgrades MarkersThey got it everything for an A-5 and they are inexpensive and ship quick!!!! ---WETWORK_SAT-SILVERBACKS ASSAULT TEAM
Oct 03, 2009 | Tippmann A 5 Standard Paintball Gun
Warrior Paintball Ion / SP8 3 Point Magnetic Trigger Logo
66 people viewed this question
Top Warrior Sport & Outdoor - Others Experts
Are you a Warrior Sport and Outdoor - Other Expert? Answer questions, earn points and help others
